Question about ASUS Computers & Internet
How do I exit out of the uefi bio utility mode it keeps going back to the same screen when I exit
    New Friend:
  • 24 Answers
When it boots back to the uefi bios page there should be some settings tab/s that you can change the boot from uefi only to normal the only other things i can suggest if you dont want to go into those settings to far for whatever reason , when it boots into your bios from uefi mode press f10 or whatever the defualt settings button may be for your bios, make sure you save and exit then aoll should be fine , FAIL THE ABOVE , ITS TIME FOR A BIOS UPDATE !!
Posted on Dec 10, 2014
Changed boot type from legacy to UEFI. Nowi cant even access bios and machine stops at acer screen. really need to enter back in bios and change back the boot type to legacy bios. Please need ur help
Changing the boot type will have no effect on whether or not you can still enter the bios.
The easiest way I find is to remove the hdd and RAM. Start up the laptop and it will do odd things. Power it off, replace the RAM with no hdd and go to the bios settings. Once there, reinstall the hdd and go to bios settings, reset back to legacy. Some systems will not support UEFI but if they do, a hdd without a system on a separate partition, will no longer work.
Dec 22, 2016 | Acer Computers & Internet
How to disable the video on a A780L motherboard
North Bridge Co nfig uration
BIOS SETUP UTILITY
Chipset
vxx.xx (C)Copyright 1985-200x, American Megatrends, Inc.
Select Screen
Select Item
Go to Sub Screen
General Help
Save and Exit
Exit
Enter
F1
F10
ESC
NB Chipset Configuration
NB CIMx Version : 4.4.0
> PCI Express Configuration
Primary Video Controller [PCI-GFX0-GPP-IGFX]
NB Power Management Features [Auto]
> Internal Graphics
Internal Graphics Conf
Internal Graphics Configuration
BIOS SETUP UTILITY
Chipset
Select Screen
Select Item
Change Option
General Help
Save and Exit
Exit
F1
F10
ESC
Internal Graphics
UMA Frame Buffer Size [Auto]
FB Location [Above 4G]
AMD 780L HD Audio [Enable]
Internal Graphics Mode [UMA]
Surround View [Disabled]
Options
Disable
UMA
T his item allows you to select the memory mode used for internal graphi cs device.
Options: UMA (Default) / Disable
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwiwq5ik2rXQAhWKP48KHU--AYMQFggcMAA&url=http%3A%2F%2Fmediapool.getthespec.com%2Fmedia.pdf%3Fm%3DQNJ2kCQfmVPhBYToYbwEQw%253D%253D%26v%3DPD&usg=AFQjCNGEH6Nge9c54_Uk8domc9vJiL0eTw
Nov 19, 2016 | Computers & Internet
Samsung 350v5c blue screen, no signal & won't boot
I would recommend resetting your BIOS back to the defaults.
  1. Turn your computer on and use F2 to access the BIOS.
  2. Using the arrow keys, navigate to the Exit menu.
  3. Look for the option (or similar) Load Defaults and press Enter.
  4. Press F10 to save and exit the BIOS.
  5. Your laptop should revert to the default BIOS and boot order settings.
Jul 08, 2015 | Samsung Np350v5c 15.6-Inch Laptop Silver...
Windows does not start up.error code 0x0
Try booting into "safe mode" It's hard to catch safe mode, but after your computer just powers on, press the F8 key and hold it. If you get a keyboard error you did it too soon. You should see something which says advanced boot options. See if you can boot into safe mode and transfer your files to a USB key or USB drive. It sounds like your software is messed up. If you're not able to boot into safe mode, the problem is more serious. Perhaps you recently made some changes in the bios or UEFI? When the system boots hold down the delete key, or the F1 key, and try to get into the bios/UEFI. Look for an option which says "restore defaults", save and exit. There are two different settings for SATA drives, try both to see if you can get your system to boot.
Dec 26, 2013 | Microsoft Windows 7 Home Premium 64BIT...
Just got a brand new gigabyte motherboard,when i shutdown the pc it wont reboot. when the power switch is pressed nothing happens no fans,led, nothing. the board is a ga-990fxa-ud3,cpu- amd phenomII...
Hi Orville,
Your problem is all about your motherboard you need to updated to BIOS firmware to solve your problem.
Go to the gigabyte website then go to your motherboard page and download and updated to the latest firmware for your bios.
Steps in flashing BIOS
How to Reflash Motherboard BIOS About updating BIOS... The whole BIOS updating procedure should be treated with extreme caution. If you do not encounter any system instability or bugs with the current BIOS version, we suggest that you keep it. If you determine to flash BIOS, you are taking a personal risk of BIOS flash failure. Please contact your supplier or our distributors/resellers for further remedy in case system crashes unfortunately because of BIOS flash failure. Before you begin... 1. Please make sure the BIOS version you want to flash matches your motherboard model. 2. If your BIOS is flash protected, please do not enable BIOS Flash Protection under Advanced CMOS Setup (AMI BIOS) or Advanced BIOS Features (AWARD BIOS) in BIOS menu. 3. Never interrupt when you BIOS is being updated. 4. Because BIOS flashing is potentially risky, if you do not encounter problems using the current version of BIOS, it is recommended that you not flash the BIOS. To flash the BIOS, do it with caution. Inadequate BIOS flashing may result in system malfunction. Three BIOS Flash Utilities... We provide three BIOS flash utilities at our website. Below are the overviews. 1 : flashbios_qflash.gif A BIOS flash utility embedded in Flash ROM. Not all motherboards have the Q-Flash, please use @BIOS or DOS flash utility to update BIOS if your motherboard does not have Q-Flash. Features-- With this utility, you only have to stay in the BIOS menu when you want to update BIOS. No need to enter DOS or O.S. mode. Caution-- Make sure you have a functional floppy disk with the correct BIOS version for your motherboard. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 2 : flashbios_atbios.gif A Windows-based BIOS live update utility. Features-- @BIOS helps you search for, download, and then update the latest BIOS in Windows operating system. Caution-- Make sure your O.S. environment is stable. UEFI - Download PDF User Guide pdf.gif Download PDF User Guide pdf.gif 3 : DOS Flash utility Features-- The flash utility is a combination of AMI and AWARD BIOS flash utility. You can use it with both AMI and AWARD BIOS. Caution-- Make sure you have a functional DOS boot disk with the correct BIOS version for your motherboard.
I hope my solution may help you.
Thanks for using Fixya...;-)
Sep 18, 2013 | Gigabyte Computers & Internet
I'm having problems installing Ubuntu on Windows 8.
you have to change the settings in bios setup. normally press f2 or f10
Dec 21, 2017 | Dell Latitude D531 Laptop Computer PC...
I want upgrade bios ga 8simlh rev 1.0,but can not
Jul 16, 2012 | Gigabyte GA-8SIMLH Motherboard
Computers & Internet Logo
109 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
