Question about Olympus Stylus 850SW Digital Camera
My camera doesn't have color and I constantly see horizontal lines how can I fix this
There is no. Color and constant horizontal lines
    Top Expert:
  • Olympus Master
  • 6,702 Answers
To avoid to much guessing, I think you should try to reset the camera. How to do that is on page 24 and 25 of the manual. With this you exclude things that can go wrong, because of a wrong scene setting or white balance or whatever. After you did the reset in the shooting mode, everything is in automatic again. Then again try to shoot a picture.
It could be the display is giving up. after a few years you can't expect it would work as new. So even if you still see lines on the display, shoot some pictures and put them on the computer. There view the results.
If the pictures are good but the lines are still on the display, try to live with that. Repairs will cost more than a brand new camera of a better quality. If the lines are in the picture, the sensor is defect and I think you should start saving for a new camera. Although new point and shoots can be bought around a 100 dollar. But even some smart phones now can take pictures that should be as goos as the ones that came from your Olympus when it was brand new.
If you can't find the manual, the link here will download it for you:
http://www.olympusamerica.com/files/oima_cckb/Stylus_850_SW_Mju_850_SW_Instruction_Manual_EN.pdf
Posted on Dec 04, 2014
Model LN52A550P3FXZA. Video and audio cycle on and off every 30 seconds or so. When picture switches off, the screen is filled with multi-color horizontal lines.
It is a common problem for this model, the problem is the main board. There are 2 Tantalum capacitors (C102 & C131) 47MF/10V, 1 Passive Voltage regulator KIA7805AF (IC300), 1 Step-Down Power Conveter IC MP2363DN (IC101) need to be replaced. If you do not have soldering skills, just order a new board.
May 16, 2017 | Samsung Televison & Video
2333 sw modeline
Samsung SyncMaster
Part Number: LS23CMZKFV/ZA
Product Line
Samsung SyncMaster
  • Native Resolution Full HD (1080p) 1920 x 1080
  • Contrast Ratio
    1000:1 / 20000:1 (dynamic)
  • Color Support
    16.7 million colors
  • Horizontal Viewing Angle
    170
  • Vertical Viewing Angle
    160
  • Brightness
    300 cd/m²
  • Horizontal Refresh Rate
    75 kHz
  • Vertical Refresh Rate
    61 Hz
  • Max H-Sync Rate
    75 Hz
  • Max V-Sync Rate
    61 Hz
Dec 18, 2017 | Samsung SyncMaster 2333SW 23" LCD Monitor
The screen color is distorted
Check your VGA cable, if they are constantly plugged in and out, a pin may be damaged. Also try wiggling the cable at each end, ie from the laptop and the computer, I have had problems with the VGA output on the laptop. If this doesn't correct the problem it will probably be a polarisor lens, if so it will probably cost more than a new replacement projector. I recently purchased NEC NP115 for just over £200.
Good luck
Aug 09, 2011 | Toshiba TLP 260 Multimedia Projector
I need a wiring color code for a pioneer deh p6400 stereo deck ex i need to know what each color goes to ex. which color is the constant which is right speaker + etc
constant is yellow . switched ignition is red. ground is black. amp remote is blue white. illumination is orange. speakers are gray front right. white is front left. green is rear left. purple is rear right. all speaker wires have a match with a black stripe.black stripe is negitive
Feb 07, 2010 | Pioneer DEH-P6400 CD Player
I need to know the color coded wires for a car stereo, pioneer deh1500. whats speaker colors, power colors and constant power
The power color is red,the negative lead is black,the constant power is yellow.Now for the speakers ,the white lead is the + and the white with the black line on it is the - wire ,grey wire + and grey with black line wire - ,green wire + and green wire with black line wire -,purple wire + and purple with black line -.Hope that clear your mind.
Dec 09, 2009 | Pioneer DEH-1500 CD Player
Sony Cybershot DSC-S500 bad photo resolution problem
Electronic shutter in lens mechanism got bad and you need to replace complete lens assembly of DSC-S500 camera.
Of course new lens assembly would cost more then camera worth so best option is to buy new camera.
Jul 23, 2009 | Sony Cyber-Shot DSC-S500 Digital Camera
What are the colors of the wires for...Battery constant 12v...12v hot only when ignition is switched on.....ground.....and front & rear speakers + and -
ok i cud help u, the color for power wire is yellow or red, front & rear speakers is normally white & gray...the both power wire's , one is constant the other only works when u turn the key, u have too hook ur amp up to find out which is which, constant ur amp will stay on...hope i wasof help
Jul 12, 2009 | Car Audio & Video
Unrecognizable pictures with little color and horizontal lines
This sounds like it might be a defective CCD imager. If so, Canon should fix this for you for free, including free shipping both ways. This is regardless of your camera's warranty status. Please check the following two links for more info:
http://camerarepair.blogspot.com/2007/11/canon-digital-cameras-showing-black.html
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=225&modelid=13390&keycode=2112&id=29819
Applicable cameras include:
A40, A60, A70, A75, A80, A85, A95, A300, A310, S1 IS, S60, S200, S230, S330, S400, S410, S500, SD100, SD110, IXUS V2/300/400/430/500, IXY Digital 200a/300a/400/450/500
Jun 09, 2009 | Canon PowerShot A95 Digital Camera
Picture blinks on and off on my Trinitron Color TV, KV-35S36
My Trinitron Sony Television flashes off and on constantly and has horizontal lines.
Aug 31, 2008 | Televison & Video
Olympus Stylus 850SW Digital Camera Logo
294 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
