Question about Bifinett KH2232 Instruction Manual Recipes PDF
How to choose a light crust for a loaf
I try for the light crust for the loaf but it was very hard
    Master:
  • 918 Answers
It.s not so much the baking it's the length of time it takes. Your recipie may need modifying. Try a different recipe or use the dough setting and make your own bread that way.
Posted on Dec 28, 2014
When I bake a loaf of bread it comes out of the machine with the ceramic mixing paddle baked into the loaf! How do I keep this from happening?
That often happens with bread machines. You can lessen the possibility by using milk in place of water and also choose light crust. This is pretty advanced but if it really bugs you,,, here goes.... After the final punch down and at the very beginning of the final "rise" stage you can remove the dough ball with one hand,( lightly flour your hands first) try to remove the paddle with the other hand from the dough ball and return the dough ball to the center of the pan, and close the lid Just be sure you don't remove your dough ball too early... check your owner manual and be sure you don't remove it BEFORE THE FINAL PUNCH DOWN....!
Feb 15, 2013 | Kitchen Appliances - Others
Bread sticks to the pan and the dough blade what am I doing wrong
It is not uncommon for the paddle to get stuck in the bread loaf especially with thick crust breads (i.e. french) Be sure to choose light crust and sometime using milk instead of water help too.
Feb 08, 2013 | Kitchen Appliances - Others
Kneading paddle gets stuck in loaf after baking and is hard to remove
Hi, it is common for this to happen with bread machines. It often helps if you have a modern machine and you can choose the crust color and you choose Light Crust. The other thing you can do is if you are using recipes that use water in the liquid phase use milk instead. If you paddle still sticks then you just need to turn the loaf on its side and use a popsicle stick, tooth pick etc and trace around the loaf where the paddle is and dig it out.
Aug 09, 2011 | Kitchen Appliances - Others
My panasonic SD 255 breadmaker, after quite a lot of use, is now baking bread with a harder crust than it did in its youth. We can get a softer crust by using the Sandwich loaf setting but then we can...
You never said if you remembered to select the LIGHT Crust setting each time. Did you? Are you? If you ARE using the LIGHT Crust setting and finished loaves are still too dark, I would have to say it's time for a replacement breadmaker. Nothing lasts forever my friend. Besides, it sounds like you got your money's worth anyway, right?
I've owned over 200 breadmaker myself so you can bet that what I'm saying is true. Sorry for the bad news friend.
Hope this helps!
Jun 15, 2011 | Panasonic SD-YD250 Bread Maker
The first time i tried my bread maker i can't get the settting to work at all what did i do wrong
press clear until beeps......unplug..... remove the pan from the machine....put all the ingredients in....yeast goes in last....put the pan back in the machine....plug back in......press the "select" button.....choose the program you want....choose the loaf size....choose the crust color......push "start".....now relax your bread will be ready in about 3 hours.....
Feb 22, 2011 | Sunbeam 5891 Bread Maker
I set the menu for whole wheat bread, however, recipe states whole wheat bread rapid. I've tried to unplug (before it has done anything) and reset, but it will not let me. It just goes back to the prior...
push the stop button until your machine beeps, then unplug it and plug it back in. push select and push it again and again and you will get more confident as you see it go through the choices such as basic, whole wheat, french etc...... you will get more confident about how to choose. Once you feel you have the right program leave it there and then choose things such as the crust color you want and the LOAF SIZE once you feel you have the right settings say....whole wheat, light crust, 1.5 pound loaf.......then....push start and the fun will begin....
Feb 01, 2011 | Breadman TR875 Bread Maker
The bread is too dry
Welcome to FixYa, if you appreciate our solution, please rate our services.
Breadmakers usually don't have as many crust settings as this one does. Darker crust settings usually equate to dryer bread because the bread bakes longer. The longer the bread bakes, the more moisture is removed. Accordingly, if you've tried this many recipes with dry texture, try progressively lighter crust settings until you get the moisture you desire. As for me, I rarely bake my bread in the machine (I don't like the hole in the bottom of the loaf). I do, however, appreciate the dough setting which does all the hard work, and I just bake it in the pan. I think the results are better and I get a better shaped loaf.
If this information has been helpful, don't forget to give me an appropriate rating. Thanks again and good baking!
Jan 30, 2009 | Black & Decker B2300 Bread Machine
Hard crust
Do you take it out right away?  If you let it rest in the machine for about an hour the crust stays soft as the bread sucks back in the moisture it gave off during baking.  Doing this does not make the bread soggy.  It's just physics.  If you take the bread out immediately the heat (+moisture) will be drawn out and diffused into the cooler environment.  Hope this helps.
Oct 17, 2008 | Sunbeam 5891 Bread Maker
1st time w/ Cuisinart bread maker
There's a little arrow in the LCD screen that changes from 1, 1.5, and 2 lbs when you press loaf. There is also one for light, medium, and dark crust. Each time you press either button, the arrow will change which setting it's pointing to.
If you're using it in an area with low lighting, try using a flashlight (I have to do that on mine).
Jan 12, 2008 | Cuisinart CBK-200 Bread Maker
Bifinett KH2232 Instruction Manual Recipes PDF Logo
76 people viewed this question
Top Bifinett Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Bifinett Kitchen Appliances - Other Expert? Answer questions, earn points and help others
