Question about Toshiba Satellite L55-A5234 Laptop, Up to 3.4GHz Intel Core i7-4700MQ Processor
Keyboard Issues with the Satellite/L55-A Notebooks keys are either delayed or input missing completely. I opened, removed and changed the keyboard itself and everything work fine until I turn off t
I opened, removed and changed the keyboard itself and everything work fine until I turn off the laptop. Then things started to get worse while more and keys stop working. sometimes some keys will work back again while other go bad. Did several scan, kasperski, essat, malewarebytes, glarysoft, adwcleaner... nothing works. Using win8.1 works well no problem. I used the prey program and some antilog also. Does anyone have a solution that will fix it for good?
  • il12 Dec 05, 2014
    I removed the keyboard again and cleaned the ribbon and the connector where the ribbon seats,made sure the ribbon is well seated and tight inside the connector. Everything works well.
    I did not have to reinstall windows and neither was a virus or hacker problem.
LRL Computer
  • 64 Answers
SOURCE: Toshiba Laptop Keyboard Malfunction
If you boot a XP cd and select repair will it let you type?
Posted on Sep 21, 2007
SOURCE: Toshiba Satellite Latop - Keyboard problem when entering password
my email add is kant_rai@yahoo.co.in
i need to driver for my laptop model no.is
A60 satellite
can you suggest on my email add.
Posted on Apr 03, 2008
  • 125 Answers
SOURCE: Keyboard not responding or typing random letters
Sounds like the liquid has acted like a glue. You will need to get a cotton bud and dip it into some clean water. Try and clean the hole again and see if it still playing up. Also restart the computer and retry word to see if the same thing is happening.
Posted on Aug 09, 2008
  • 37 Answers
SOURCE: Help me to unlock a laptop keyboard
I had the same problem for my laptop as well. I basically turned it off and removed the battery for ten minutes, then put it back in and turned it on to which it started working. I don't know why it stopped working before or started to work again when I removed the battery but it's happened three times and everytime that has always worked for me. I know it's not very technical but try it.
Posted on Nov 09, 2008
SOURCE: toshiba satellite a215-s5837 keyboard does not work
Yes, replace entire thing. It's really a membrane key anyway. NO contact to clean..
Posted on Feb 10, 2010
The number keys to the right will not work, even after pressing number lock. suggestions?
Please open Device Manager and uninstall what is showing under "Keyboards". If you're unsure on how to perform these steps, follow this link:http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&dlc=en&docname=c03540049&lc=en&product=5450010&tmp...
Once you have uninstalled the keyboard driver, restart your notebook and it should automatically reinstall for you.
Let me know if this resolves the issue.
  • If the keyboard is not working in Windows, continue with these steps to uninstall and reinstall the keyboard software in Device Manager.
  • Click Start , then click Control Panel.
    Control Panel opens.
  • Click Hardware and Sound.
  • Click Device Manager under Devices and Printers.
    Device Manager opens.
  • Click View, and select Show Hidden Devices.
  • Double-click Keyboards, right-click the keyboard name, and then click the Uninstall button to remove the device from Windows.
  • Restart the computer.
  • The keyboard should now work correctly.
  • Your computer comes with several software programs that can test the keyboard for key or hardware failures. For more information, see the HP Support document Testing for Hardware Failures.
  • Notebook key presses are slow to respond
    If there is a short delay from the time a key is pressed to the time the character displays on the screen, the Filter Keys function might be activated. The Filter Keys function provides a greater range of key press options to fine-tune key delays and prevent inadvertent key presses. To disable Filter Keys and return to the default keyboard behavior, use the following steps:
    1. Click Start , and type keyboard in the Search box. Then select Change how your keyboard works under Control Panel.
    2. Remove the selection from Turn on Filter Keys. Then click Set up Filter Keys.
    3. Remove the check next to Turn on Filter Keys when SHIFT is pressed for eight seconds.
    4. Click Apply, click OK, and then close the Ease of Access Center.
      The keys should be more responsive.
    Pressing a notebook key once types several characters
    If two or more characters appear when pressing a key, use the following steps to adjust the key repeat delay:
    1. Click Start , and type keyboard in the Search box. Then click Keyboard under Control Panel.
      The Keyboard Properties page opens.
    2. Set the Repeat delay slider to Long. Click Apply, and then click OK.
    Notebook beeps while typing
    If the computer sometimes beeps while you are typing, Toggle Keys or Sticky Keys is active. Toggle Keys causes the computer to emit a beep when the Lock keys are pressed. Sticky Keys causes the computer to emit a beep when the Ctrl, Alt, Shift, or Lock key is pressed. Use the following steps to disable Sticky Keys and Toggle Keys:
    1. Click Start , and type keyboard in the Search box. Then click Change how your keyboard works under Control Panel.
    2. If selected, remove the check next to Turn on Sticky Keys. Then click Set up Sticky keys.
    3. Remove the check next to Turn on Sticky Keys when SHIFT is pressed five times.
    4. Click Apply, and then click OK to return to the Make the keyboard easier to use page.
    5. Remove the check next to Turn on Toggle Keys.
      If selected, remove the selection from Turn on Toggle Keys by holding down the NUM LOCK key for five seconds.
    6. Click Apply, click OK, and then close the Ease of Access Center.
      The beeps no longer sound.
    Wrong characters appear when typing, changing keyboard language, or Dvorak
    If the wrong characters appear when you are typing, or you are trying to use a different keyboard, use the following steps to synchronize Windows to the type of keyboard you are using:
    1. Click Start , and type region into the Search field. Click Region and Language from the search results.
    2. Click the Keyboards and Languages tab, and then click Change Keyboards.
      The Text Services and Input Languages page opens.
    3. Click Add.
    4. Select the keyboard you want to use, and click OK.
    5. From the Text Services and Input Languages page, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    6. Click OK. You can now use the new keyboard.
      If you find that the new keyboard service works correctly and you do not want to use the other keyboard, repeat these steps and Remove the keyboard service that you do not need.
    HP Notebook PCs Notebook Keyboard Troubleshooting Windows 7
    Aug 23, 2015 | HP Computers & Internet
    How do I replace the keyboard on a toshiba satellite l55-a5384
    Undo the screws underside with the keyboard icon. Lift the cover that sits above the Function keys, carefully! Remove and replace the keyboard.
    Dec 28, 2014 | Toshiba Computers & Internet
    Keyboard mistyping issues
    1. Change to United States-International keyboard layout.
    Manually change to United States-International keyboard layout
    2. Use the Microsoft Fix it 50558
    3. Confirm if the Keyboard is wired or Wireless
    Information:
    Ensure that batteries are new for the wireless keyboards as drained batteries can
    cause delay.
    Slow computer can also cause the issue. Check if computer is slow and perform necessary troubleshooting steps related to performance after following below provided troubleshooting steps
    Steps:
    Clear Turn on Filter Keys, or adjust the settings to a quicker rate for Windows Vista and Windows 7
    Clear the Use Filter keys check box, and then click OK for XP
    adjust your keyboard's repeat delay and rate settings
    Drag the Repeat delay: slider to Short
    Drag the Repeat rate: slider to Fast
    Click OK.
    Close all windows
    Is issue persists, Reinstall the Drivers
    Follow below steps :
    http://www.wikihow.com/Fix-a-Keyboard-That-Has-the-Wrong-Characters
    Mar 22, 2014 | Dell Inspiron 1525 Laptop
    Keyboard input delayed I have to hold keys for down for 5 seconds 4 data entry
    Open control panel and the open KEYBOARD. Now you can set the level of timing which can be presetted to your requement.
    Check on the links and test the keyboard. If not there are errors in the keypad or the drivers/OS.
    Aug 01, 2011 | Sony VAIO VGP-WKB1 Keyboard
    My toshiba satellite m45-s355 seems to be coughing up a weird problem.Whenever i press the shift key these characters - "NB~A" props up and the whole system goes awry.I can figure out that it's a...
    like other prblem on keyboard it seems your fn key was stuck, it can caused the keyboard was dirty, just open the keyboard then remove all the key on your keyboard then clean it using alcohol wait until dry then set the key again
    Jan 14, 2011 | Toshiba Satellite M45-S355 (PSM40U073001)...
    How do I replace the keyboard?
    next to the F1 key and the windows key (2nd upper key and second to last key) are two screws, usually under some covering. unscrew and lift top edge of the keyboard towards the trackpad to lay face down. Undo the wire ribbon by lifting the grey or brown tabs and remove ribbon and keyboard. Then install the new keyboard by inserting the ribbon on the place. Lock down with the tabs and put the plastic prongs (close to the space bar) into the laptop body first, and then close keyboard onto the final position. screw back in and thats all. nboulikas@gmail.com for any additional questions.
    Nov 06, 2009 | Toshiba Satellite A105-S4004 Notebook
    I have a Toshiba satellite notebook.Keyboard problem
    You can use a standard USB desktop keyboard or a mini laptop usb keyboard or just replace the keyboard with one you can buy on Ebay.com
    Oct 09, 2009 | Computers & Internet
    Keyboard removal
    Dear,
    For remove keyboard, u have to open the Complete panel which is above the keyboard. and there u will get the screw and then u can easly able to remove the KB. Okey..
    Thabks
    Cheers
    Jaggu
    Sep 22, 2009 | ASUS G1 Notebook
    Its typing numbers when pressed letters
    If the wrong characters appear when you are typing or you are trying to use a keyboard that is different than the one that came with the computer, use the following steps to synchronize Windows to the type of keyboard you have:
    1. Click Start c01311982.gif , and type region into the Start Search field.
    2. Select the Keyboards and Languages tab.
    3. Click Change Keyboards .
      A Text Services and Input Languages window opens.
      Figure 3: Change Keyboard button
    4. Click Add .
      Figure 4: Add button
    5. Select the keyboard(s) you want to use and click OK .
      Figure 5: Add input language: US Dvorak keyboard selected.
      The new keyboard is added to the list of available keyboards and a keyboard icon appears on the system tray, allowing you to switch between the keyboard that you want to use with the mouse.
      Figure 6: Keyboard tray icon
    6. From the Text Services and Input Languages window, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
      Figure 7: Move up button
    7. Click OK . You can now use the new keyboard. If you find that the new keyboard works well and you do not want to use the other keyboard, repeat these steps and Remove the keyboard that you do not want from the General tab of the Text Services and Input Languages window.
    Jun 10, 2009 | HP 386209-001 Keyboard
    Need to remove the cd/dvd drive in Toshiba Satellite A135 S4527 l
    Most notebooks have a quick release button underneath for the CD-rom. There may also be a screw holding it in place. It's unlikely that you would have to remove your keyboard to take the dvd drive out.
    May 06, 2009 | Toshiba Satellite A135-S4527 Notebook
    Toshiba Satellite L55-A5234 Laptop, Up to 3.4GHz Intel Core i7-4700MQ Processor Logo
    61 people viewed this question
    Top Toshiba Computers & Internet Experts
    pankaj rautela
    pankaj rautela
    Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
