Question about JVC RX-6020V Receiver
How do I connect my jvc model#rx-6020vbk. To my Toshiba smart tv?
I have a JVC RX-7010V AUDIO/VIDEO CONTROL RECEIVER. And I can not get it to hook up to my TV for surround sound I have to hook it up through my headphone jack on my TV.
On the back of the JVC receiver, there should be a TV input, Coax IN and OUT or AUX input (I don't remember if this model had HDMI). On the back of your TV, there should be an AUDIO OUT, connect this to either the TV or AUX inputs and make sure on your TV, to set the Audio Out is On in the TV menu. Turn on JVC and set input to TV and adjust volume. Another way is using the COAX input and outputs. Connect Output of cable box to Input of JVC, then connect Output of TV to Input on TV.
May 15, 2016 | JVC Audio Players & Recorders
WHERE CAN I GET USER MANUAL FOR JVC PD-43N910 SMART 3D PLASMA TV
Did you check with the manufacturer on their web site? If not available it is because the set was a special model for a large store - they change the model numbers on those sets so they cannot be shopped. You need to find the equivalent JVC model which asise from a different model number is identical.
They do NOT make special models for these big retailers - just give them a special number.
Feb 22, 2016 | JVC Televison & Video
Smart TV but reveiver does not have HD plug ins
I would input everything directly to the tv via hdmi, then take the optical audio output from the tv back to the receiver.
Jan 04, 2013 | Yamaha RX-V595 Receiver
Connecting to samsung smart tv
For digital connections on your TV ( unknown model) read on page 7
[PDF] RX-6000VBK / RX-6008VBK INSTRUCTIONS AUDIO/VIDEO - JVC
Sep 30, 2012 | JVC RX-6008V Receiver
How connect to tv
http://resources.jvc.com/Resources/00/00/96/LVT0380-001A.pdf this is a manual for the rx 6000 it's the same connections as my reciever pioneer hope works...............video out to TV, all components video in to receiver
Feb 20, 2011 | JVC RX-884V Receiver
JVC RX-888V hook up to cable box - no video
There is some sort of setting you need to change on the JVC receiver. I had this same problem, and I read the manual and it solved it. You need to press and hold down a button to change the mode. Your unit probably says "TV Sound" right now. Once you press this button (not sure what button) like the manual says, the display should change to "DBS" and then it should work just fne.
Mar 20, 2009 | JVC RX-888V Receiver
I Need help
Here is a link to get your owners/operation manual for the model you indicated. It has two listed, the bottom one is most likely yours.
http://books.jvcservice.com/booklist.asp?Model=RX-6020V
You will get all the instructions you need to connect your unit properly.
A "FixYa!" rating would be apprecieated, since this all the information you really need.
Let me know if you need more help,
Dave
Aug 07, 2008 | JVC RX-6020V Receiver
JVC receiver Auto muting?
I had the same problem. I had bad antennae connection. I re-did the antennae conection and it fixed it. HOpe this will work for you...
Dec 03, 2006 | JVC RX-618V Receiver
JVC RX-6020V Receiver Logo
220 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
