Question about Refrigerators
I just did a search for the amica AK314 refrigerator as I am seeking a hinge/door part that has snapped and broken the company will not help or provide item as is over 12 years old. Seeking a suggesti
I just did a search for the amica AK314 refrigerator as I am seeking a hinge/door part that has snapped and broken the company will not help or provide item as is over 12 years old. Seeking a suggestion of how I can find?
    Top Expert:
  • Refrigerators Master
  • 44,914 Answers
An appliance parts supplier might be able to help.
Posted on Dec 04, 2014
  • 116 Answers
SOURCE: Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Posted on Mar 11, 2007
  • 29 Answers
SOURCE: Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Posted on Jan 28, 2008
mikedurland
  • 481 Answers
SOURCE: Admiral model #rswa278a
Sounds like a defrost problem. Check to see if there is any frost buildup in the back wall of the freezer. If so, it is not defrosting as it should.
  • possible causes:
  1. bad defrost timer
  2. bad defrost heater (in freezer)
  3. bad thermo switch in freezer
If you don’t know what these are then unplug the machine and let the ice melt in the freezer overnight with the door open. Then try it the next day, if is cooling fine then you need to have a service person replace one of the above items.
Posted on Aug 08, 2008
sdmc73
  • 121 Answers
SOURCE: GE Profile refrigerator model PFCS1NJWA is freezing items in back
slow air flow will cause it to freez check air flow from freezer in at the top and back at the bottom
Posted on Nov 30, 2008
Bogie Boy
  • 46 Answers
SOURCE: refrigerator door swings open too far; does not
Yes it is a hinge cam that broke. Can be ordered on the GE website. A no pro job to replace. A little patience and time about 30 minutes.
Posted on Dec 16, 2009
Amica oven door gets so hot that my child has burnt hes hands and needed medical attention
Amica is a European brand, I recommend you contact the company headquarters or a competant local repair shop. Any oven left at a very high temperature for a long period of time gets pretty hot, though, and an eleven month old baby has pretty tender skin.
Jul 19, 2014 | Ovens
The auto-closure spring for the door appears to be broken. What is the best way to go about repairing it?
You need a new top hinge, call true at +1 800 325 6152 for part numbers and ordering info. They are very secretive about their info, they may or may not help. They may refer you to a local tech company. I can get the parts if you can't get anywhere with them.
Feb 11, 2013 | True GDM-26 Refrigerator
My Amica refrigerator -freezer A K 314 Freezer is ok, but refrigerador at setting %6 ia not cold enougth or sometimes is frozen Also Its start expelling a horrible smell! Is this smell dangerous?
I just did a search for the amica AK314 refrigerator as I am seeking a hinge/door part and the company will not help/provide as item is over 12 years old. Might anyone have a suggestion of how I can find?
Jan 24, 2012 | Refrigerators
Amana SXD23V refrigerator leaks water underneath the side where the refrigerator door is evey time I try to get water out of the dispensor. I found a plastic tube on the floor about an inch long then...
I believe your water line or the union nut just behind the kickplate may have come loose. Lets see if we can find a repair kit and get you going again. Depending on where the line is broken or leaking will depend on just how much you will need to do so if leaking at the union nut please disregard removal of door.
WARNING
To avoid risk of electrical shock, severe personal injury or death; disconnect power to unit before servicing, unless
testing requires power. Discharge capacitor through a 10,000 ohm resistor before handling. Wires removed during
disassembly must be placed on the correct terminals to ensure proper grounding and polarization.
sea_breeze_2.png Here are the instructions from the manual below.
1. Open door and remove all storage buckets.
2. Remove toe grille.
NOTE: Shut off water supply before performing Step 3.
Have a bucket ready to catch spillage from tube.
3. Loosen water-tube clamp screw. Loosen plastic
water-tube union nut. Pull water tube away from
union nut and through tube clamp.
4. Remove screw that mounts door closure to top
surface of bottom hinge.
5. Close door.
6. Remove screw holding top hinge cover in place.
Remove top-hinge cover.
7. Unplug wiring harness connectors. Remove ground
screw and ground wire from top hinge.
8. Remove top hinge and hinge bushing. Pull hinge and
bushing off wiring harness.
NOTE: Hinge shim is glued to top of cabinet and must
be left in place.
9. Lift door about 3 inches to bring lower hinge bushing
up, off hinge pin.
10. Set bottom edge of door on protective pad. Remove
hinge pin (with door-closure tab) from bottom hinge
bracket.
11. Reverse procedure to rehang door.
For plastic tubing click HERE
and for a simple snap on coupling I want you to call to insure you get the correct size and snap on union.
  • 1-800-269-2609, 8 am to midnight ET, 7 days Repair Clinic are very helpful and friendly and will be happy to answer your questions. I also will be here to answer any questions you may have, Thanks, Sea Breeze
  • Jul 25, 2011 | Refrigerators
    Oven door on a Amica upright oven not closing completely. Where can I obtain door hinges for a Amica Oven..it is still under warranty, less than 24 months old. I have tried a few spare part places...no one...
    they are Australian company, What country are you in? The wesite for them is www.cimbre.com.au. I would need to know where you are in order to help you. Also need the model number. Usually manufactures warranty expires after 1 year
    May 22, 2011 | Ovens
    Need to temporarily move our Whirlpool Gold refrigerator to replace kitchen floor. How do we remove fridge doors so we can get it through the doorway?
    Usually, there are bolts/screws on the hinges. They may be covered with a plastic cap which will snap off. Start with the freezer door. While supporting the door, remove the screws from the hinge and lift to free the door. Now you should have access to the hinge supporting the refrigerator door. Same procedure for refrigerator door. Keep the screws in a safe place so you can reassemble the refrigerator when the kitchen floor is done.
    Jan 30, 2010 | Refrigerators
    I need to remove doors to get in kitchen, how do i?
    If you are asking that question, sorry you're not qualified for that job. Seek professional help, or you can screw up your refrigerator big time (read - broken tubing,wiring, misaligned gaskets, twisted hinges, not leveled doors, a few hundred $$$ in repairs).
    Nov 26, 2009 | Frigidaire FRS23W3A Side by Side...
    Same problem but part is not on schematics for my model.
    that is what helps your door close..if the cams are broken the door will drop down and may drag..if that is your situation then yes, get that kit.
    Jun 12, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    The piece that connects the vertical hinge to the door is broken.
    Try partsdirect.com they have one of the best parts resources available. you will need your complete model number off of the inside of the unit it is located either on the eiling or right hand wall of the refrig section. thx Peyton
    Mar 16, 2009 | Jenn-Air JFC2089H Bottom Freezer French...
    Hinge assembly makes a snapping sound when door is opened
    This is a self closer assembly. Try getting a new self closer and replacing both parts. The part on the door and hinge. 0The door must be removed to do this.
    Nov 13, 2007 | Frigidaire FRS26KF5C Side by Side...
    Refrigerators Logo
    56 people viewed this question
    Top Refrigerators Experts
    Charles T Nevin
    Charles T Nevin
    John Tripp
    John Tripp
