Question about Garden
<!-- from fixya rte -->Losing prime to carb after warm up - Garden
    New Friend:
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 42 Answers
Make sure you have a vented gas cap installed. The engine will only be able to pull fuel from the tank as long there isn't a vacuum on the tank from it pulling fuel out of the tank. A none vented cap, or a clogged cap will cause this.
Posted on Dec 04, 2014
4 Suggested Answers
  • 14 Answers
SOURCE: Bolens 4.5 Briggs and Stratton: I prime the carb
Be sure the fuel is fresh....meaning, fresh from the gas station. IF that doesn't fix it, replace the carb.
Posted on Oct 08, 2009
  • 6468 Answers
SOURCE: carb. loses prime-have to pour gas in carb to get started(27hp Briggs)
check the needle valve in the carb the fuel we now get melts the tip off also before you blow the engine make sure the fuel that is draining down is not going into the gas
Posted on Apr 01, 2012
  • 6468 Answers
SOURCE: my craftsman 6hp. gas mower will not prime i cleaned carb. good if ispray a little gas in carb well start first pull and there after as long as eng. is warm
the primer bulbs do tear also if the passage is plugged it will not prime
Posted on Apr 28, 2012
Check fuel line to see if it is getting near anything hot. If it is, you will need to get some insulation behind or around it. It sounds like it is vapor locking on you.
Col,. Dana Gillespie
Dec 04, 2014 | Garden
Check the fuel pump pressure. IF this is heat related, it could also be a bad gasket causing a vacuum leak. The other thing could be the fuel line is getting too hot causing the gasoline to create a vapor lock.
Dec 04, 2014 | 1993 Isuzu Pickup
Carb. loses prime-have to pour gas in carb to get started(27hp Briggs)
Mar 30, 2012 | Garden
I ran out of gas, now it won't start. what do i do?
Okay....I think your bike may have a vacuum operated fuel petcock.....which is the fuel valve on the bottom of the tank. It shuts the fuel off automatically when the engine stops and the hose from the intake to the side of the petcock loses vacuum.
So when you restart the bike the petcock is closed till the engine starts...which is okay because there is a small amount of fuel in the carb.........until you run out of gas....then the engine quits and the carb is empty.
To handle this situation, typically there is a prime position on the petcock that allows flow without vacuum to "prime" the empty carb......usually marked as PRI on the petcock,
So rotate the lever on the petcocck to prime....wait a couple minutes....get the bike started and set the petcock back to the normal setting....don't leave it on PRIME as fuel may flow overflowing the carb.
Apr 04, 2011 | 2007 Yamaha XT 125 X
Oct 07, 2009 | Garden
Could this be a cold start problem
defective fuel pump the check valve is allowing it to lose prime replace fuel pump.
May 28, 2009 | 1996 Chevrolet Blazer
1998 chvy 1500 loses power
check the intake gaskets. in the middle front and middle rear. If they are oily, it more than likely sucked part of the gasket in. When it warms up the leak gets bigger. The easy way to check is to get some carb cleaner and spray all around the intake while idling and warm. DO NOT SPRAY ANY EXHAUST PARTS , carb cleaner is combustible. The truck should stumble or even shut off when spraying with the carb cleaner if there is a leak.
May 03, 2009 | 1998 Chevrolet K1500
Engine runs 2-3 seconds then stops
Drain float bowel
check for water .
Mar 19, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
