Question about Robinair Measuring Tools & Sensors
Mod 34800-2k will not refill more than 2 lbs of r134
Will not take a recharge of more than 2 lbs of r-134 filter dryer was replaced robinair part
  • 3,382 Answers
It is probably to warm. Are you filling it with liquid by turning the tank upsidedown.
Posted on Dec 04, 2014
5 Suggested Answers
mhkamran
  • 180 Answers
SOURCE: robinair model 347002k has a problem with leaving
Please change your machine spin-on filter & vacuum pump oil immediately,becaus you already exceed maximum limit of filte.( NOTE:max.cap.of filter is 150 lbs ) if you keep using machine without changing filter then compressor will get damage at any time. Recovery is not compleating also because of that & do not skip clearing before any recovery.hope this will 100% solve problem.
Posted on Aug 07, 2009
mhkamran
  • 180 Answers
SOURCE: how refill my tank of freon 134 in my machine ?
Fix low side coupler to R134a refrigerant sorce (new refrigerant tank with up side down & tank valve open) tank.Open low side manifold valve & close high side manifold valve.press tank re-fill or recover botton & fill as you want.NOTE: Max.cap.50 LBS or 23 KG.
Posted on Jan 23, 2010
mhkamran
  • 180 Answers
SOURCE: I have a Robinair cooltech 700 a/c machine. does
Please check your machine ISV tank liquid hose,it's may lose or too tight
Posted on Jun 11, 2010
mhkamran
  • 180 Answers
SOURCE: Can my Robinair 34700Z be set to recharge in
You can not use any Robinair machine in ounces to recharge refrigerant instead of LBS or KG. the software is not programed for count refrigerant in ounces!
Hope you get your answer
Posted on Dec 21, 2010
Refill A/C
the A/C system will need to be placed under a vaccum of at a min. of -29.5 HG to verify the seal held and removed the water caused by being open to the enviorment (humitiy ) will cause water in the system witch will damage the matter in the receiver dryier. there is a specific amount and proceedure that will need to be followed to the letter to place a precharge, bypass the low pressure cutoff switch. extream cauation should be used as the Hihg pressure gas and fluid is both very hot and extreamly hi . I would really recommend if you dont have experance and licensed take it to the shop and get it done it will be chaeper that a hospital bill and the repairs if you get it sealed up right it should only cost the evac fee normally .5 hrs labor and R134 of about 2 lbs here in Calf, labor at a normal shop on A/C specials are 40.00 and 19.99 per lbs of R 134 BE CAREFUL
Johnie G
35 yrs ASE
univ A/C cert.
Oct 24, 2012 | 2004 Jeep Grand Cherokee
Hi, my robinair ac375 wonot charge gas, gauge up arrow and down arrow wont move, we done filter and vaccum oil and reset. it is possible to get special way to reset gauge?
mhkamran.jpg Please check Charging solenoid (S3) in Solenoid manifold block, it may need to change solenoid coil or Rebuild. If charging solenoid is OK, then problem can be SCALE or MAIN CIRCUIT BOARD. See if the machine display show default charging weight 90 kg/lbs when you active CHARGE mode. If not then calibrate scale. But if default charging weight is shown then replace MAIN CIRCUIT BOARD. See attached picture to find solenoids. I wish this will help you to solve the problem. If so please vote for it for further assistance. Best of luck!
May 13, 2011 | Robinair Cool Tech 34700Z Recovery,...
Can my Robinair 34700Z be set to recharge in ounces instead of pounds or pounds/ounces (EX. 2.4 lbs.)?
Dec 21, 2010 | Robinair Cool Tech 34700Z Recovery,...
34700 unit when in the vacuum mode it sends R134 into the oil recovery bottle tank
Please check oil drain sensor(switch) or oil drain solenoid for any debris. If both are check OK, then check Vacuum,Recycle and charge solenoid for any debris or damage. Replace/rebuild as needed. Hope this will help you
Nov 03, 2010 | Robinair Cool Tech 34700Z Recovery,...
How refill my tank of freon 134 in my machine ?
Jan 21, 2010 | Measuring Tools & Sensors
HOW TO CHANGE FILTER just shows clearing filter please wiat
"Clearing filter please wait" if this message is running more then five minute then it's sound that your machine compressor is not haveing 13'' of suction ( Compressor is damage or weak suction) so you have to replace new compressor.Note:every 68 kg/150 lbs of recovering refrigerant you must change spin-on filter,otherwise you will have again same problem.
Jul 10, 2009 | Robinair Cool Tech 34700Z Recovery,...
I have a robinair cool tech 700 not recovering
You Need to replace your unit compressor.Because may be you did not change spin-on filter after recovering 150 LBS of refrigerant.
May 17, 2009 | Robinair Cool Tech 34700Z Recovery,...
AC - RECHARGE I DONT KNOW HOW TO RECHARGE THE AC...I BOUGHT A CONVERTER KIT (R-134) THAT COMES W/EVERYTHING EXCEPT A DIAGRAM ON HOW TO DO IT...HELP?
Bring it to a qualified a/c technition! you need a licence to recharge or handle 134a. there are very large fines for improper procedures and handling
Aug 04, 2008 | 1991 Toyota Previa
Measuring Tools & Sensors Logo
116 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
