Question about Canon Office Equipment & Supplies
How to fix error code on Canon Pixma MG5220?
Reinstalled printer drivers; tried unplugging and leaving off overnight; then removed cartridges and printer head; cleaned head with hot water and isopropyl alcohol; reinserted them and performed alignment and color assessment- some colors wouldn't print out on test. Was able to print from computer for two pages but printer would not copy or scan although mechanically scanner and print heads would move appropriately like they were working correctly...then B200 error message returned and printer is back to non-functioning.
SOURCE: kodak 5100 no black printing, light on colors
Had the same issue... No black ink. Called the # from "Solution #1" guest, 18004216699. Had to patiently go through all the basic trouble shooting stuff like calibration, print head clean, demo print, etc. Once I went through that, they issued me a new print head for free, no shipping charges or anything. Just did this today, but they say I should have the print head in 3 days.
For once, service worked like it should!
Posted on Jul 19, 2008
mitpatterson
  • 74 Answers
SOURCE: Brother MFC-5440 Print Head
To remove it you pretty much have to take apart the printer, tip up the lid and try and get the scanner cover verticle and then slide to the left it should detach and then undo all the screws you see on the top were the pinter head is, and i would recommend Alcohol Swabs (IsoPropyl Alcohol), Then just reverse the dissassimbay directions
Thanks Mitch
P.S. Don't forget to rate me
P.S.S. If you follow my directions you do so at your own risk, I am not liable for any damages that occur
Posted on Aug 22, 2008
SOURCE: canon pixma ip500 horizontal bands of non-printing areas
Hi it's Gill again. I've been looking around more on the net and I think the problem is our printers need new printheads which I'm told are spare parts easy to change. Hope this helps. Gill
Posted on Apr 03, 2009
SOURCE: my canon pixma ip1000 prints,but no image/letters/colors ...blank
buy new HP printer you will have no problem with nozzels
Posted on Nov 25, 2010
  • 352 Answers
SOURCE: Canon MX300 printer--I replaced the
Try this method to get the ink flowing:
  1. Simply fill a saucer with approx 2mm of just boiled water
  2. Place the print head in the saucer with the head in the water.
  3. Leave the head in the water for approx 2 - 5 Mins
  4. The Heat will assist in dissolving any blockages and help the ink to flow with out using any chemicals.
If it is a compatible cartridge you have used then it is possible to get a failure. Most are re-manufactured and are not 100% Reliable.
Also make sure the contacts on the inside of the printer are clean and all there. sometimes they can be damaged by removing and replacing cartridges. these can be cleaned with alcohol wipes.
I hope this helps Regards GM
Posted on Apr 23, 2011
WHAT TO DO WHEN I HAVE AN ERROR CODE B200. i CANNOT PRINT AS THE MESSAGE IS CONTACT YOUR SERVICE PROVIDER. IS THERE A WAY I CAN FIX IT MYSELF////
Hi Kathleen,
to clear the Canon B200 error code:
Steps for 4+ Cartridge Printers
  1. Remove All Cartridges. Do whatever is necessary to remove the individual ink cartridges from your printer. In most cases this will be opening the lid of your printer and waiting for the cartridge cradle to move into the correct position.
  2. Remove the Printhead. This is easily achieved in most printers by simply lifting the orange/gray locking lever on the side of the cartridge cradle and then gently lifting the printhead from the printer.
  3. Reinstall the Printhead. Gently put the printhead back into your Canon Pixma printer and lock it into position firmly.
  4. Reinstall All Cartridges. Place all of the cartridges back into the printer and close any open doors. This makes sure that your printer is actively examining the reinstalled cartridges and printhead.
  5. Unplug the Printer. Physically remove your printers plug from the wall and leave it unplugged for 5+ minutes. This allows the printhead to cool and all residual electricity to leave the printer.
  6. Plug the Printer Back.
  7. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
Steps for 2 Cartridge Printers
  1. Turn the Printer off. When your printer is in this error state it will not let the cartridge cradle within the printer move. However resetting the printer should clear the error message temporarily allowing us to troubleshoot further.
  2. Turn the Printer Back on Again.
  3. Remove the Problem Cartridge. Whilst the Canon Pixma error messages do not tend to specify which cartridge is causing the problem, you should be able to have a rough idea based upon which cartridge was last replaced.
  4. Install a Replacement Cartridge. As the printhead is part of the cartridge, sadly there is no way to stop the B200 error without replacing the cartridge. I would recommend either installing a new cartridge or a previously used cartridge that you know to be functional.
  5. Do a Nozzle Check or Cleaning Cycle. The B200 error does not tend to occur until your printer actively tries to use the printhead. As such I recommend performing one of these processes in an attempt to confirm the correct cartridge has been replaced.
  6. If Necessary Replace the Other Cartridge. If the error persists with the new cartridge, it may be that the other cartridge has developed a fault and is the cause of the B200 support code. If at this point the error remians I can only recommend replacing the other cartridge.
Aug 11, 2017 | The Office Equipment & Supplies
I have an error message B200
Hi Kathleen,
Aug 11, 2017 | Office Equipment & Supplies
Error B200
press the helpful button and follow me on fixya for more tips
an electronic issue with one of the cartridges
How to Fix Canon Pixma Support Code B200 Error Message
http://www.mytechtime.com/2011/09/canon-error-b200-how-to-fix-it.html
Feb 01, 2016 | Office Equipment & Supplies
Error code B200 with message reading: Unplug power cord and contact service centre
VH monitor error
mainboard or printhead error
only replace can fix problem
Jan 07, 2016 | Canon Pixma MG5220 InkJet Printer
Eror 5100 canon pixma mg 2170
Lepaskan kedua cartridge, bersihkan pin2 carriage sekaligus pin2 konektor pada cartridge. selanjutnya pasang kembali kedua cartridge.perhatikan tampilan pada display, jika tertera angka 1 itu berarti masalah error 5100/ P02 telah teratasi dan insya Allah printer dapat beroperasi kembali. (Wahana Computer Masamba)
May 06, 2013 | Canon Pixma MG5220 InkJet Printer
How do I remover a paper jam under ink cartridges in Prima Canon MG5220
rEMOVE THE INK CARTRIDGES AND REMOVE THE CARTRIDGE BASE SUPPORT.
Mar 20, 2013 | Canon Pixma MG5220 InkJet Printer
Canon 5200error 200
You have an error with the temperature of your cartridge, try another new cartridge
Apr 24, 2012 | Canon Pixma MG5220 InkJet Printer
The ink cartridge that was in my Canon Pixma iP1800 printer suddenly got an error message saying it was not properly installed. It had been in place for months. I ordered a new cartridge. It didn't work...
I will try a printer reset.
Remove both cartridges and close cover.
Unplug printer from electrical outlet and wait at least 10 minutes.
The wait time will let the printer to fully cleared memory and
also to cool down if printer was overheating.
Plug printer back in and turn on printer.
Wait for printer to stop.
Install both cartridges.
Jan 01, 2011 | Canon PIXMA iP1800 InkJet Photo Printer
70 people viewed this question
old marine
old marine
