Question about Building Materials
I have a Chamberlain motorlift ML700. The remote works fine for opening the gate, but doesn't close it. Resetting the remote didn't help. Any ideas?
    Sergeant:
  • 290 Answers
  • 6 Answers
SOURCE: Chamberlain Liftmaster Pro. Garage door Problems closing
The sensor eye - or more likely, the other end, the sensor light - probably got knocked out of alignment. The eye should have an LED on it - possibly one that glows green when it's ready to close or red when it's obstructed or out of alignment. Try adjusting the light until the LED on the receiver glows green.
Posted on Dec 07, 2008
swolfinor
  • 504 Answers
SOURCE: Light flashing for 2 minutes after operation
I WOULD GO TO CHAMBERLAIN.COM THEY HAVE ALL THE MANUALS FOR THESE OPENERS AVAIABLE FOR FREE DOWNLOAD IN PDF FORMAT.
THE MANUAL WILL HAVE A GREAT TROUBLESHOOTING SECTION.
HOPE THIS HELPS
Posted on May 28, 2010
swolfinor
  • 504 Answers
SOURCE: door close with wireless remote entry but will not open
HAVE SOMEONE PUT IN THE CODE AND THEN HOLD DOWN THE ENTER KEY. IF THE LED NEXT TO THE PROGRAM BUTTON FLASHES RAPIDLY THE KEYPAD IS SENDING A CODE. TRY REPROGRAMING THE KEYPAD.
IF THE LED DOES NOT FLASH, NO RADIO SIGNAL IS BEING SENT THE KEYPAD IS BAD.
  • 3197 Answers
SOURCE: Chamberlain 102-1499A Opens w/ remote. Will not
If when you try to close the door the main light flashes 10 times and the door reverses to the open position you have a door sensor problem. Make sure they are pointed at one another and the small light on each one is lit and not flickering. If you cannot get both lights to come on you have a bad sensor.
Posted on Jul 26, 2010
blanchettohd
  • 143 Answers
SOURCE: The belt on my Chamberlain Whisper Drive dipping
Where the belt attaches to the trolley carriage which attaches to the door there is a black adjustment nut with a spring on it. Tighten it up more by turning it clockwise until the belt tightens up. The belt will droop a little when the door is all the way shut normally but should not during operation. If you tighten it up too much the belt will slap on the rail during operation. Make sure the spring is set on the adjustment screw too. This holds the belt tight over time. Thanks BB
Posted on Oct 11, 2010
Motor will not accept remote signal, cannot reprogram. If I manually force a connection across the terminal it all works.Any ideas?
check that the fault did not alter the limiting switch positions for the motor
it is possible that they are out of adjustment
other than that check for a reset button in the control box
Sep 03, 2016 | Building Materials
I have a Chamberlain motorlift ML700. The remote works fine for opening the gate, but doesn't close it. Resetting the remote didn't help. Any ideas? Thank you.
My best guess is the closed limit switch is out of range or defective and telling the controls it is already closed.
Dec 07, 2014 | Building Materials
Miracle one gate opener not working. Was work fine and lately not opening all the time. Now not at all. Looked and all fuses they are ok. System on light is off. only ligts on in control box are the...
Have you checked the fuses? They are small and can be difficult to see because of the thin wires. Check those first, especially the motor fuse on the lower left corner of the board.
Does you system use a wireless remote or keypad, or to open/close.
Jan 06, 2014 | Chamberlain Elite Miracle One Swing Gate...
How to use 2 button remote for two mighty mule gate openers
I understanding that the chamberlin is a two button remote so as long as you have the same kind of recierver (a box hooked up in your operator that has dip switches,it recieves signals when the remote and it are set the same.) you should be able to use the two button remote on both machines. If not their is a reciever that is called multi-code and it is universal to work with all gate openers. the chamberlin remote you have will work with it.
Feb 23, 2010 | Chamberlain Clicker Universal Remote...
Motorlift garage door remote range
Your receiver is going bad and should be replaced. It is part of the logic board.
Jul 19, 2009 | Sears Craftsman LiftMaster Chamberlain...
HOPE THIS HELPS
Jan 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Need to program my chamberlain #953CB from a working gate opener
the chamberlin remote only work with a chamberlin reciever, if you have this it will be a silver box that looks like diamond plate material inside you operator, take of the front cover on this box and you will see a black button that says program push and hold this button down then push your remote button down while holding it close to the box you will see a yellow led flash and then it is set. if you only have a single button remote you will only be able to set it to one operator.
Nov 26, 2008 | Chamberlain 950CB Remote Control
Building Materials Logo
162 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
