Question about SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue
I backed up the files on my old computer to my simple drive 320GB and when I went to put the files on my new computer (both windows 7) My new computer would show the devise. I then tried to connect in
I have tried updating the drivers, using different USB ports using differing power outlets.
  • 56 Answers
Try the drive in a different PC. Perhaps you could have removed the drive from your old PC before it had finished copying? I think the problem may lay there. You should SAFELY REMOVE the usb.
Posted on Dec 09, 2014
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 122 Answers
Does win7 make a plugin noise when you put it in a USB port?
In that case, go to control panel, open disk administrator and see if the disk is recognized by the OS, it may just be a case of assigning the right drive letter.
Posted on Dec 06, 2014
Staunchporra
  • 12 Answers
SOURCE: Simpletech 160 Portable doesn't show up
go into the control panel and click add/remove hardware... and manually add the device and then use the auto update to download the drivers
Posted on Jan 24, 2008
  • 4 Answers
SOURCE: Simpletech 500 GB drive won't work (repost because not solved)
I had a similar problem with a SimpleTech 250g Pininfarina USB drive.
I went through the drivers, the power supply, the USB cables, and the various
computers, USB cards and Operating systems.
Finally I opened the case and found the disk drive was mounted too far
forward, causing the IDE connector to barely touch. I loosened the mount screws,
slid the drive back towards the connector, tightened everything down and it works.
Posted on Apr 22, 2008
  • 8 Answers
SOURCE: SimpleTech 250GB External Hard Drive Installation problem
I bought the Simpletech Signature Mini 250GB last week and had these same issues. I wrote to the company's tech support and the solutions works. It boils down to you having to create a drive letter & partition for this. It took a little time to format, but it's all good now. I agree we shouldn't have such a headache for such a simple piece of hardware, though. I will cut/paste the info below. Once it was done, I was able to go to My Computer and see it listed as Drive H (which was what I selected).
PROBLEM: I have followed directions re: plugging device in, still cannot see device in MY COMPUTER. I have also tried plugging both USB's into computer to no avail. Even tried using it on my laptop, still not showing. My desktop is XP & loaptop is Vista. When I go to remove the dirve, it DOES show as Fujitsu, but I cannot acces the drive or locate it elsewhere. I really want to like this, but will have to return it if this issue is not resolvable.
SOLUTION: You might need to initialize the drive.
Right click on “My Computer” or “Computer” on Vista.
Select “Manage”
On the next screen select “Disk Management”
In the lower middle section you should be able to find your drive.
It will show up as Disk 1 or Disk 2….depending on how many drives you have in your computer.
If you click on the area that says Disk # you should get and option to “initialize drive”.
Also to the right it should show the allocation information for the drive. If it says “unallocated” then the drive needs to be partitioned.
Right click on the white box next to the drive listing.
Select the option “New Partition”
This will bring up the partition wizard and you will need to step through this process.
Select a primary partition.
On the next screen accept the maximum size it will provide.
On the next screen you assign a drive letter.
On the next screen you will do the format and accept the default settings.
The formatting will start and will be busy until it is complete.
You can monitor this from the disk management window.
Regards,
SimpleTech Technical Support
Hope it helps!
Posted on Jun 05, 2008
SOURCE: simpletech 500 GB drive won't work
Open your Simpletech by removing two screws from the back --> you need to remove the label in the back, and pull the I/O card up towards you. The I/O card comes off easily.You need to buy a BYTECC USB 2.0 to IDE/SATA ADAPTER Kit ( you can buy this adapter on line, It ranges from $16 to over $30). Now connect the USB port from the adapter kit to your USB port, and plug in the Adapter kit to a 115 volt power outlet. If the hard drive is not shot, that is, you feel it spinning, you should be able to see the drive, and copy the data from your SimplechTecj drive to your PC.
Aram Dodakain
e-mail to adodakian@bakerbro.com
Posted on Nov 12, 2009
  • 261 Answers
SOURCE: My SimpleTech Signature Mini 250GB portable drive
hi
check for virus or
2 scandisk or
3 copy the files then format the disk again
Posted on Nov 13, 2011
How can I upgrade my eeebox pc b202 to windows 7
Well first you can find tutorials online but here is a simple way that I believe may work. Put on a new hard drive in the place of the old one and buy a windows 7 install disk. Next insert the disk and start up the computer via the disk. It should now ask you to install the program and follow the instructions. Once finished just take out the disk and if you want insert the old hard drive that contains all your files into a second hard drive bay and try to set the contents to a D:\ drive. This may not work but this is how I remember doing it excluding the old hard drive part. I hope this helps;)
Jan 19, 2014 | ASUS Eee Box B202 Desktop - Intel Atom...
"How do I transfer individual files archived on my SimpleDrive from old PC to newer HP Windows 7 laptop?"
Connect your simple drive to the computer with the usb and power lead if applicable.
Click start all programs accessories open windows explorer my computer you should see your drives C: usually your hard drive D: your cd dvd drive and your usb drive E: or F: click to open it from there you select the files right click on the file/s right click copy navigate back to the drive right click select paste or hold the mouse cursor the file/s drag them to your usb drive disc then drop them Hope this helps.
Jan 10, 2013 | SimpleTech SimpleDrive Pininfarina 320GB...
Have hp a1240n media center pc. hard drive failed and was replaced with 320GB hard drive & windows xp pro by local repair shop (no xp disk) shop is gone; computer loads, but now says windows not valid...
You can recover data from hard drive with data recovery software.Then format the drive toget it fixed.
For data recovery program,here are two of the best Iused.
For Windows: http://www.any-data-recovery.com/index.htm
For Mac: http://www.stellarinfo.com/mac-data-recovery.htm
You can download one of them and scan your hard drive for free to previewwhether your files can be recovered. They will show you the file name, type, dateand of your files and thumbnails for your pictures that it found on yourdrive.
Sep 26, 2011 | Computers & Internet
Have new computer - Windows 7.
We cannot simply open .bkp file. Use NT backup software and select restore option and select this file to restore.
This way u can restore the files backed up in this .bkp file.
Please come back and vote for me if this find to be helpful for you. Thnx
Mar 28, 2010 | Computers & Internet
Have simple tech 320bg , backed up files using the onboard software.... files show up and I can actually move them back up to new computer but.... can't read file (ext = NBP/NBZ file) also looks like I...
Sorry, best I can do is advise next time don't use the backup/restore s/w that came with the drive. I own the same one and found Windows Backup works flawlessly. In fact, if files are still on orig computer, re-back-them-up using Windows Backup and restore to new machine same way.
Apr 24, 2009 | SimpleTech SimpleDrive Pininfarina 320GB...
Weird hard drive won't boot
How to set jumpers to run two hard drives
Haven't read anything about setting up either of them as slave and the other as master... if you don't do that... you get this sort of "HUH, what's going on." Not quite that simple, but not that hard either if you're IQ is probably at least 80, you should be able to do it... heck, half the drives have the jumper settings printed on them.
Feb 07, 2009 | Compaq Evo D500 PC Desktop
SimpleTech SimpleDrive Pininfarina 320GB External USB 2.0 Hard Drive - Blue Logo
133 people viewed this question
Top SimpleTech Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Lyle Siemens
Lyle Siemens
Are you a SimpleTech Computer and Internet Expert? Answer questions, earn points and help others
