Question about McCulloch 3200 Bar & Clutch Cover
Oil level in motor of 3200 mcculloch chainsaw
Topping oil up
  • McCulloch Master
  • 1,169 Answers
This a 2 cycle engine where fuel oil is mixed with the gasoline. The mix is 40:1. If you attempt to run straight gas in this engine you will destroy it as would using regular oil.
The oil tank on this saw is for the lubing the chain and needs topping off every so often as you use the saw so that the chain stays oiled.
With the original McCulloch manufacture being out business parts are very hard to come if you can even find them.
Posted on Dec 04, 2014
dontbother10
  • 2220 Answers
SOURCE: McCulloch chain-saw fuel-oil ratio 3200
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 2gal premium/8oz chainsaw 2-cycle engine oil - used for many years) and finally the last 5 (±) years 50:1 (1gal premium/2.6oz Stihl 2-cycle engine oil)
  2. Any fuel containing ethanol is not good with chainsaws. Mix what you expect to use within a few weeks. Anything over 1.5 months old use up in a 4 cycle engine. HTH
Lou
Posted on Nov 07, 2009
dontbother10
  • 2220 Answers
SOURCE: my McCullough chainsaw series 3200 is leaking oil,
Operator Manuals for McCulloch are difficult to find and will not help with this problem unless you want a repair facility. You can try here:
Operators Manuals: are much more difficult. I have dialed this number many times (Contact Us - All McCulloch Products 1 (800) 521-8559) and have yet to get a satisfactory response. Please try this! If enough of us try they will fix it!
You provided no model number; this one was given in a 3200 fuel problem I answered earlier. An IPL for the model you provided follows (this is actually a 3214, I have never found a 3200):
http://www.ordertree.com/modelinfo/MCC/11-600032-32-Mac-3214-06%2F93-IPL-211229/139.11-600032-32-Mac-3214-06%2F93-IPL-211229.1.59.1.html
It is the only 600032-32 here:
McCulloch IPLs (all)
The IPL (exploded parts list) for your saw is the only detail for the oil system is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
http://www.ordertree.com/modelinfo/McCulloch/139.59.html
There is a less detailed print here:
Chainsaws 32cc-35cc
On this block of saws the oil pump is under the flywheel and there are many hoses. Please use the IPL to identify and locate oiler parts. I hope you find a burst hose. There are oil pump repair kits listed. Unless the pump has an obvious crack or hole I would not attempt to change it until I had exhausted all other possibilities.
This works for older MCs but MTD (this one) saws often deviate from the explanation. It will give you a little guidance if you try to locate a different IPL.
http://www.fixya.com/support/r3558917-mcculloch_chain_saw_ipl_illustrated_par
I know it is not plugged but this may also be helpful.
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
These are very difficult to work on, most saw shops will not attempt a repair. I hope the chainsaw Gods smile on your undertaking. Good Luck. If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa HTH
Lou
Posted on Mar 27, 2010
dontbother10
  • 2220 Answers
SOURCE: McCulloch EB428 chainsaw and the auto oiler won't work
Good on you for what attempted already. I looked at the print and it appears there is a worm gear (item 50) and a driven pump (item 61) behind the clutch. I suspect one of the 2 has failed. I know you have done most of this already But does it ooze with the bar off?
Oil System Plugged:
A link to the only IPL for a McCulloch EB428 follows:
http://www.ordertree.com/modelinfo/MCC/EB428-Chainsaw/139.EB428-Chainsaw.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Posted on Apr 30, 2010
SOURCE: McCulloch,Mac 3200 Chainsaw fuel lines...........
retgmdI need the same, did you ever find one?
Posted on May 27, 2010
  • 122 Answers
SOURCE: Need a manual for a McCulloch SE2000 Chainsaw
http://www.mymowerparts.com/pdf/McCulloch_Parts_Service_Repair_Manuals/Gas_Powered_Chain_Saws/McCulloch_Gas_Chain_Saws_Parts_Manuals_11_600032_71_Silver_Eagle_2014_IPL_211229_01.pdf
Posted on Feb 08, 2011
McCulloch chainsaw 3200. What is gas/oil mix ratio? Can use 10% ethannol gas?
The McCulloch website includes information regarding proper fuel/oil mixtures. Click on the following link and follow their instructions:
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
Aug 19, 2017 | McCulloch Garden
How to reassemble McCulloch 3200 Chainsaw Trigger Throttle
I recommend contacting your local authorized service center for assistance.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Aug 28, 2013 | McCulloch Garden
Mcculloch chainsaw mac 3200 manual
Contact us
User manuals
McCulloch Service
Jun 15, 2012 | McCulloch Garden
Where to get a coil for 3200 mac chainsaw
Try the manufacturer or I recommend contacting your local authorized service center for assistance.
Contact us
User manuals
McCulloch Service
Mar 05, 2012 | McCulloch Garden
I need a pdf parts manual for a mcculloch 3200 chainsaw where can i find it
Contact us
User manuals
McCulloch Service
Dec 27, 2011 | McCulloch Garden
I need a diagram for the oil line hook up for a McCulloch MAC 3200 14" gas chainsaw. When i picked it up it was leaking oil and when i took the oil cap off the oil line with the filter on it came...
Refer to your service manual or I recommend contacting your local authorized service center for assistance.
Contact us
User manuals
McCulloch Service
Oct 12, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
I need to know which oil type goes into the oil chamber for the chain on a mac 3200 gas chainsaw, not the mixture...thanks
There really is no exact type of oil that goes into the chain and bar oiler. Each manufacturer usually makes their own, but any chain and bar oil will work. It is a thicker type of oil unlike a motor oil. Just ensure that the bottle says "bar and chain" oil
May 02, 2011 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Fuel/Oil Mixture
Lou
Nov 07, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Aug 23, 2009 | McCulloch Garden
Need a manual for McCulloch mac 3200 chainsaw
MS1432 seems to be a good match for the mac 3200 (at least the Mac 3200 I just aquired from Pawn Xchange is identical to the MS1432 that was swiped from me last year by an *EX* friend) - PDF here:http://lawnandgarden.manualsonline.com/manuals/mfg/mcculloch/ms1432.html?idRes=5629277
(Yeah, I know, this is an old question but, it may help the nest person needing a manual)
Apr 04, 2009 | Garden
McCulloch 3200 Bar & Clutch Cover Logo
127 people viewed this question
Top McCulloch Garden Experts
Jim Parker
Jim Parker
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
