Question about Microsoft Xbox Video Game Consoles & Games
RROD, not heat sink or arctic Siler, problem
Replaced Arctic Silver / Heat sink Removed and tried resetting DVD drive Thoroughly cleaned Replaced clips with bolts
5 Suggested Answers
  • 1019 Answers
SOURCE: the thermal paste?
hey buddy you can do, but the grease removers an un-necessary item. this stuff will wipe off with a soft cloth.
or at worst, a very blunt plastic scraper.
you only need the tinyist amount of thermal paste.
I,d Suggest ( E-Bay )
mike.
Posted on Feb 24, 2008
SOURCE: Still get 3 rings after xclamp fix and applied arctic silver 5
Take your metal case, and drill holes big enough to fit 5m diameter x 16mm tall screws. Put them all up through the holes and add 3 steel washers to each post. then add 1 nylon washer. >>>make sure you do the penny fix or replace the thermal pads before you place your motherboard inside the case<<< Place your motherboard inside of the case ( you can use tape on the back side of the metal case to hold screws in place; may want to do that before you add washers) add 1 nylon washer then 1 steel washer to each. Take off microsoft's bolts from the heat sinks and re-apply a ssmmmallll amount of thermal paste (size of a piece of rice for the big ones). Attach everything and you will be good to go.
Penny Trick- Take 2 pennys, wrap them one way with electrical tape, then turn 90 degrees and wrap them again so no copper is showing. >>You will need 4 sets of 2 pennys<< Flip your motherboard over and peal off the white things with band-aid looking squares on top of them. Peal the band-aid looking squares off and apply your tape-wrapped pennys.
Note: If you do not have these puddy-looking things on your ram chips, Use some hot glue, not a lot though.
You may also need to "bake" your 360. When you are all said and done with applying and bolting things. Take your 360 and put everything in except the fan. Take the fan plug it in its spot, then lay it diagonally from its plug, ontop of the tall cpu heatsink. Turn your xbox on for about 15 minutes. Let it over heat good so it can reset itself flat. Turn if off and let it cool down for about 20 minutes. Put everything back together and enjoy your console as your paid for it! smile.gif
Posted on Aug 21, 2009
  • 1093 Answers
SOURCE: The box boots but after short time no video
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
You will need to stop the scaler chip taking so much heat.
Posted on Feb 19, 2010
  • 4102 Answers
SOURCE: Hi, I was trying to
Hi 4 red rings means the video lead is not put in the back of the console properly so take the leads out and try them again.
if they are fitted correctly switch it on and when you get the flashing red lights do the following
when all lights are flashing hold down the little white round wireless button and keep holding it down whilst you do the following.
whilst holding the button down press the eject button on the console then write down how many red lights are lit up.
then hole the white button down again and press eject and write it down, you need to do this 4 times and it will give you a code that you can give to me and i can then tell you exactly what the fault is ok
so it will be something like this
4 red lights
4 red lights
2 red lights
1 red light
let me know the code then i can tell you exactly whats wrong and what you need to do to solve the problem ok
Posted on Oct 09, 2010
I just replaced the mother board in my Dell 8400. I am now getting the Error "Alert chipset heat side not detected". I know that i have applied the arctic silver 5 corectly.. (this heatsink has no sc
Turn the computer off.
Disconnect the AC power.
Open the case.
Check that the heat-sink is securely and tightly connected where it should be.
Mar 11, 2013 | Computers & Internet
After thermal event, pc will not reboot.
Buy some arctic silver from radio shack ($10). Remove the heat sink from the CPU. Apply a dime sized drop and spread it with a credit card or saving card. Attach heat sink.
Oct 27, 2012 | Dell Dimension 3000 PC Desktop
Should silicone heat sink compound be used between the cpu and fan
For today's cpu's and fans, I suggest that you use polysynthetic silver thermal compound such as Arctic Silver. You can find it at Radio Shack and other computer electronics stores.
Thanks for using Fixya.
Apr 11, 2011 | Computers & Internet
How to fix xbox 360 "red rings of death"??
How to Fix Red Ring of Death - A Step by Step Action Plan
Remember to rate me a 4 out of 4 thumbs up thanks
1) Disassemble Xbox 360 Case
Obtain your case separately. By a fine tip screwdriver, poke the grayed out holes and back of poke the small rectangle holes. Get the Faceplate Off and move the latch up on the DVD drive up as you remove it. Unscrew metal case which is under the plastic case.
Following is the image of video (How to disassemble xbox 360 case) which comes with James Dean's Professional Xbox 360 repair guide. If you are not comfortable with instruction you can use this video to disassemble your Xbox 360 case.
Click On Above Video Image To Watch Video On How To Your Repair Xbox 360
2) How To Remove Motherboard Safely
Unplug all cables connected to motherboard and associated small devices and take DVD drive out. After DVD, get the fan and motherboard out of the xbox 360 case. Make sure you do this gently.
Following is a quality video which can show how you can remove motherboard safely.
3) Crucial Motherboard Disassembles.
Turn the mother another side, using the screwdriver snoop off the X-clamp which you can find under heat sink. Check out following an image of a video which came with Xbox 360 repair guide which will make your process easy of "snoop off the X-clamp".
I will suggest you to do this step very gently if you are not comfortable doing this refer following video which comes with James Dean's 360 repair guide.
4) Heat Sink Unscrewing.
After snoop of X-clamp you have to unscrew heat sink to obtain CPU and GPU.I will advice you don't hurry to finish this work, please follow all steps else it will damage your xbox 360. If you are not confident do use Professional Xbox 360 repair guide.
5) GPU And CPU Cleaning.
Next step is to clean GPU (graphic processing unit) and CPU (central processing unit) If you do this step right it will help to stop xbox 360 freezing. This is very important and critical step so just make sure you do it right.
6) Appling Arctic Silver
Now you have to apply arctic silver thermal compound gently over GPU.
You will get this arctic silver thermal compound in any computer hardware shop for $1-$2.
Set it for 15 to 20 minutes then place 2 nylon washers on each screw on the heat sink then place the screws back in motherboard then add two more nylon washers to screws.
Then,
Place the heat sink on the peak of screws then push them down slight, finally screw them up. Try to make it reasonably tight.
Get everything back together and see everything is fitted properly. Now, Turn your Xbox 360 on.
I always like to educate people so I tried to describe a whole process in my words, Videos can make this whole process lot easier. I will suggest you to check out James Dean's Xbox 360 repair guide(Click Here To Visit) which will surely help you out to fix your XBOX 360. Also I have done a detail review of James Dean guide below, so don't forget to check it out if you need a pro help. please rate me high thanks
Jan 04, 2011 | Microsoft Xbox 360 Console
What kind of thermal grease CPU I can use for replace old grease
Depends what you intend to do with your computer, if its lots of gaming, and pushing your pc to its limits, you will need a good quality thermal compound (arctic silver), if its just normal stuff a cheaper heat sink compound will do, i use Servisol, its cheap and works well
Jul 16, 2010 | Toshiba Satellite 2435-S255 Notebook
Xbox 360 no sound no picture
did you check if your cable was switched from hd to standard or for any frayed or ripped wireing also check the connections it could be the tv is set to another channel just the small stuff like that or hold the power button the the xbox til it turns off
Aug 14, 2009 | Microsoft Xbox 360 Console
Red light keeps blinking
You need a screwdriver, a heat gun, arctic silver compound, lots of patience.
Dismantle your ps3 down to the motherboard. Clean off the compound on the Graphics chips with isopropyl alcohol. Set your heat gun to around 700*F. Apply hot air to each of the Graphics chips, 1" away, in a swirling motion for 15-17 seconds each on one side. Let cool down for 20min. DO NOT MOVE THE BOARD. Repeat for the other side. Let cool down for 20min. DO NOT MOVE THE BOARD. Apply new compound to the graphics chips with Arctic Silver. Put the PS3 back together and it should work. It worked for me!
Aug 12, 2009 | Sony Playstation 3 (PS3) Console
My toshiba cooling fan is not functioning. the computer automatically shutdown because of overheating. what is the best thing to do?buy a cooling pad or maybe change the fan as well as the heat sink?
It is best to change the fan and heatsink. Make sure you clean the processor and apply a very thin coat of thermal compound (arctic silver) to the heat sink if it is not supplied. Newegg.com lists may cooling fans & heatsinks based on your socket configuration
Hank
Jul 30, 2009 | Computers & Internet
3 red lights
Looks like you have the "Red Ring Of Death"
You need to contact Microsoft as theres something wrong with your HDD. Its most likely your going to have to get a replacement or have it repaired.
Jul 29, 2009 | Microsoft Xbox 360 Console
Video Game Consoles & Games Logo
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
