Question about Viking Kitchen Ranges
Hood not getting power. Authorized viking tech said I need to get an installer to remove the hood before he could see what the problem is. Is this typical of techs to not remove to troubleshoot?
Electrician said there is power to unit... Viking Tech said no power to fan nothing he can do until its removed.
    Habit-Forming:
  • 102 Answers
It depends on the installation: larger hoods, intricate installs and liability concerns could all raise this concern by a tech. It should be simple to begin by checking for electric at the wiring connection inside the hood terminal box without removing the hood from the cabinet. If there is no power supplied to the hood then an electrician should correct the fault in the house wiring.
Posted on Dec 06, 2014
3 Suggested Answers
  • 89 Answers
SOURCE: Brand new Viking 3048SS hood - fan switch not working
think i would call viking back and ask for refund of inspection fee and go by the bad switch scenerio the electrician said new fan that would be considered flaws in workmanship in most states dont know where you are located but pretty much same anywhere most inspectors for these companies always try to blame problems off on installers hold your ground and make them fix it and refund that" inspection " fee I've been doing electrical work for several (20+) years it takes longer than 5 minutes to troubleshoot something like that good luck
Posted on Aug 23, 2008
SOURCE: fan switch not work - Viking 3048SS brand new range hood
I did some more troubleshooting and figured out how to get the plate off that houses the switches. I disconnected the fan switch and created a safe electrical by-pass. I re-connected the main power supply and sure enough, the fan worked. Issue = defective switch. Currently looking to order replacement. Problem solved.
Posted on Apr 11, 2009
Will not sew straight stitches
If the needle moves side to side easily with power turned on, the sewing head has been damaged. An experienced Viking Service Tech can probably repair the sewing head. A replacement is about $600. You can find your nearest local Authorized Viking Dealer at the Viking website - http://www.husqvarnaviking.com/us and click on the 'Locate a Dealer' icon.
Mar 12, 2014 | Husqvarna Viking Designer 1 Embroidery Arm...
Viking hood Lights out
There is a short inside, you need to check wirings to locate the short.
Apr 05, 2008 | Viking VWH3048 Kitchen Hood
Viking range hood dimmer switch
Sorry we have no part locating services here at this website.
Apr 17, 2017 | Kitchen Ranges
Need new belt for 1993 Viking Husqvarna sewing machine. Where can I get the belt and how do I install it?
An authorized husqvarna viking dealer can order you a replacement belt and install it for you. To install the belt, the covers have to be removed and there are lots of hidden screws. 3rd party parts are available from various resellers online. Just Goggle Search or try ebay but you still have the problem of installing it. Suggest you take it to a local authorized Husqvarna Viking dealer for them to order the original part (if they don't have one on hand). You can find your nearest authorized dealer by clicking on the "Dealer's" link at their website - http://www.husqvarnaviking.com
Jan 29, 2010 | Husqvarna Viking 1
Need New Fan knob for Viking VWH3048
You could contat any viking dealer and they would be able to help you, or you could go online to viking.com; finally you might find a replacement knob at a hardware store like a Valu where they usually have a large assortment to choose from.
Jan 31, 2009 | Viking VWH3048 Kitchen Hood
Vents in the Viking hood fall out on their own
Remove the filters.
The slot that the filters sit in at the rear edge, can be removed, it is basically hooked into place.
When you remove it you will see that the sides are different, reinstall it with the smaller edge hooked thus leaving the larger edge to hold the filters in place.
I hope this is clear.
Dec 12, 2008 | Viking VWH3048 Kitchen Hood
Fan switch not work - Viking 3048SS brand new range hood
There is the on off switch and the blower control that controls the speed of the fan. It is more than likley the blower control that would need replaced.
There could also be a wire disconnected in the hood.
Aug 19, 2008 | Viking VWH3048 Kitchen Hood
Viking downdraft dipr 160r cable
IF YOUR MACHINE WAS BROKEN DURING INSTALL YOU SHOULD BE UNDER FACTORY WARRANTY IF IT WAS PURCHASED AT AN AUTHORIZED DEALER IT IS THE RESPONIBLITY TO REPLACE THE MACHINE AND TAKE THE OTHER ONE BACK TO THE STORE TO HAVE A AUTHORIZED SERVICER REPLACE OR REPAIR ANY DAMAGED PARTS. HOWEVER IF THIS IS NOT A NEW INSTALL YOU CAN PURCHASE THE PARTS FROM HADCO APPLIANCE PARTS
May 30, 2008 | Viking DIPR160R Stainless Steel Kitchen...
Viking hood damper
Remove the blower and reach up into the duct through the back flow damper and put weather stripping on the 2 edges that are chattering, it will greatly reduce the noise
Dec 20, 2007 | Viking VWH3048 Kitchen Hood
Kitchen Ranges Logo
138 people viewed this question
Top Viking Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Viking Kitchen Range Expert? Answer questions, earn points and help others
