Question about Ovens
On a jenn air W131 does the lower element work with 240v
Should each wire going to the bottom element get 120v wen oven on
  • 9,742 Answers
If the plug that goes into the wall looks like the one for an electric dryer then its 240. If it looks like an ordinary wall socket then it's 120.
Posted on Dec 05, 2014
  • 1214 Answers
SOURCE: How do you get a Jenn air oven out of the wall???
The JennAir website should have the installation manual for download. Go there, type on your model number, and it should come up.
Sometimes these ovens just get "stuck" in place, and take some easy levering to break free, or to help you find other fasteners.
Posted on Jan 16, 2009
  • 134 Answers
SOURCE: MAIN OVEN DOESNT WORK
Hi
Pretty certain nofuse. Suspect switch. Guess would be as element blew it took out contacts on oven switch
Posted on Feb 20, 2009
SOURCE: fridgiaire Gallery series Model GLEB30T8CBA lower elements dont work
I replaced the relay board for the top oven (the one with the transformer) and it works properly now. My issue was only for the top oven so you probably have to replace both relay boards since both ovens have only the top element working.
318022002 is the part number for the relay board with transformer
318022001 is the part number for the relay board without transformer
Yes the one without the transformer is more expensive for some reason.
The boards are on the top of the oven, I was able to pull out the oven about 75% of the way out of the cabinet and easily get to the boards. Just unplugged the connections and plugged them into the new board.
To get the oven out there are two small screws that go into brackets inside the top oven door. Highly recommend taking the doors off the oven to pull it out, much easier to work with.
NOTE: On my old board I noticed one solder joint that was burned out and I since I already had the new board I just replaced but you might want to check that first and see if just a solder fix gets you working again before you spend $$ on a new board.
Posted on May 13, 2009
SOURCE: My jenn-air self-cleaning electronic wall oven
One of the 2 hot wires is out. Flip (hard) the oven circuit breaker to the off position, and then back on. If it did not help - verify 220-240v between the two hot wires on the terminal block behind the electronic control. If there is less - call electrician.
Posted on Oct 14, 2009
jumptrout51
  • 3361 Answers
SOURCE: jenn-air ww30430w dual oven, lower oven, lower
Most likely a bad element. Turn off the power to the oven. Remove the racks.
Use a phillips screwdriver or 1/4 inch nut driver to remove the mounting screws at the back of the oven cavity to remove the element. Carefully pull the element out and remove the wires. Do not let the wires fall back into the holes.
Use a volt meter set for continuity. Touch one meter lead to one terminal on the element. Touch the other meter lead to the other terminal. If you get NO reading the element is bad.
A new element will correct your problem.
If the element reads as good you have a wiring problem or a bad control.
Posted on Jan 03, 2010
Early 1960's Frigidaire 24" Double wall oven not heating
Hello Chris Hammond, thanks for your post!
Based off the information you have provided it sounds like a potential problem with your connector for your element within your Frigidaire wall oven. I would recommend reaching out to a professional technician for proper diagnosis repair to help avoid any unnecessary part purchases. Best of luck! -Matt
Nov 07, 2014 | Ovens
Will not heat up past 200 bottom element is brand new?
Hello- It sounds like it is not getting 220V. I would first check the breaker and reset it a couple of times to make sure that it is sending 220V to the oven. There could be a problem with the relay board not sending enough voltage to the element. I would also check to see if the convection element is ok, it may share a common 120V wire with the bake element. If you are unsure about testing the elements then I would call a Tech out to test the voltage. The oven may have to be pulled to determine if there are any shorted wires. Good luck and best regards.
Sep 28, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jenn Air W30400 wall oven does not heat.
Remove the racks.
Remove the BAKE element screws and carefully pull the element out.
Remove the wires from the element,being careful not to let the wires fall back into the oven cavity.
Use a volt meter set for continuity and touch the meter leads to the element terminals.
No reading is a bad element.
Replace the element.
If you do get a reading,the electronic control is bad.
Jul 16, 2010 | Jenn-Air Ovens
I have a Jenn Air W131 model wall oven and I believe the lower heating element needs to be replaced. I will set the temp at 350 and it doesn't heat up at all. Is my assumption right that that is what...
If this is the problem no it isn't hard at all. Should be able to change right thru the oven without pulling out of wall. Make sure power off while doing this tho. But ist make sure broil does work.
Feb 01, 2010 | Jenn-Air JJW8330D Electric Single Oven
Jenn-air ww30430w dual oven, lower oven, lower element not heating, upper broil element working fine
Jan 03, 2010 | Ovens
My jenn-air self-cleaning electronic wall oven model w131 is heating up very slowly. It took 1.5 hours to get to 175 degrees.
Oct 13, 2009 | Ovens
Ge range model # js968 has power but cooktop & oven don't work
Check for proper power (control panel is 120V, burners and heat element are 240V) You may have lost connection in one of hot wires causing the burners/elements not to work yet the control panel still will
clarkco
Feb 25, 2009 | Ovens
Jan 15, 2009 | Jenn-Air 30 in. Pro-Style Electric Single...
Jenn-Air Wall Oven Model #WW30430P F5 Fault Code
I have the exact same problem with an F5 fault code. I also have a new clock assembly. RepairClinic.com said "Jenn Air fault code F5 = Hardware and watchdog circuits disagree / Replace clock assembly (also called the ERC)
Jenn Air Fault code for newer models F5 = Power to element relays disabled in cook mode
1. Intermittent oven temperature sensor or wire harness or,
2. Intermittent contact on power relay board"
This doesn't help since it is too technical. What should I do next?
Oct 19, 2008 | Jenn-Air WW30430P Stainless Steel Electric...
Jenn Air W131 F1 error code
This means that the Power to element relay energized during time of day display. You have a problem with the wiring harness and it is shorted or you need to change the power relay board (PRB). If it is a double oven, you need to change second oven board.
Jan 07, 2008 | Jenn-Air JJW8230D Electric Double Oven
Ovens Logo
62 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
