Question about Kenmore Refrigerators
What could be wrong with a fridge and freezer side by side it's been setting for about 4 months not .so I hooked it up and it won't get cold hooked up
I hooked it up. it wasn't getting cold so I unhooked it so I didn't know what to do
    Habit-Forming:
  • 193 Answers
A few things can cause this problem make sure the compressor is working ,large black semi round metal device found at the bottom rear of the fridge,it should not make a clicking sound if it does replace it,next grab the smallest pipe it has, is it hot if no you have a gas leak.
Posted on Dec 04, 2014
SOURCE: GE Profile Side by Side is getting too cold on the fridge side.
I have a GE refrigerator with the same problem of my food freezing in the refrigerator. I spoke to an appliance part person and they sold me a temperature sensor for 20 bucks. They said it would be located in the control panel, but I took the control panel off and can't find the sensor. I'm now looking on yahoo answers to find out where the sensor is located.
Posted on Mar 01, 2009
SOURCE: Maytag MZD2766GE side by side, fridge not getting cold.
Your timer for the automatic defrost is defective. Replace it. If you thawed out the back of the freezer, this could be good for 3-7 days and it will freeze up again. I had the same trouble.
Bobby Johnson
Posted on Mar 10, 2009
  • 30 Answers
SOURCE: Fridge won't get cold
Check to make sure that the fan in the freezer is running whenever the compressor turns on to cool the unit down. If the fan's not going, warmer moist air from the fridge will make the air duct frost up. The fan needs to be running to blow the cold air into the fridge section.
Posted on Apr 28, 2009
mgprice
  • 744 Answers
SOURCE: Freezer is too cold, fridge isn't cold enough.
Hi, With the information you supplied i'm going to assume there is an ice build up at the rear of the freezer. Your problem is going to be with your defrost system. I will also assume you have the ability to repair this yourself. This is going to be one of three problems with your refridgerator, 1st thing to do is remove shelfs and panel in the back of the freezer...you should see ice build up on the evaporator...don't worry get a hair dryer and melt the ice. Next locate the wires for the heater...using a multi meter test the heater for condinuity...if the heater is bad replace it, If the heater is good replace the defrost thermostat..the stat normally is a barrel looking part clipped onto the evaporator pipe. The last possible problem could be the evaporator fan, have you heard the fan running in the past few hours?..if you are not sure pull the panel out to where you can see fan and watch it over an hour to see if it turns. I have included links with pictures of what the parts you need to check are: http://romulusappliance.com/manufacturers/maytag/refrigerators/575432.JPG defrost stat http://www.hotekalliance.com/UploadFiles/2008627111553382.jpg heaters http://www.applianceblog.com/archives/EvapMotor1018185.jpg evap fan. Hope this helps. If you have any other questions please feel free to comment again. If you decide to get a repair guy in should not cost you any more then $120 - $200 depending on make/model/problem Good luck & thanks for using fixya! Mike p.s. please don't forget to rate this free solution.
Posted on Sep 11, 2009
sekjr
  • 3 Answers
SOURCE: Freezer cold not frozen, fridge cool but not cold enough.
Is the refrig running constantly? and still can't get to 0deg???
You say it's 30deg in there! I assume you are using a thermometer IN the freezer. Is the fan in there running (you can hear it). If it is, and you say you aren't cold enough, you lost freon...
Posted on Aug 16, 2012
GESS25LGMB WW Side-by-side fridge/freezer won't cool.
call a repair service it probably need freon added to system and that is not a consumer FIX
Aug 27, 2017 | General Electric Refrigerators
Admiral american fridge freezer constantly blowing cold air into fridge compartment.
Changing the freezer settings won't really make a difference because regardless its still going to be freezing. The way the machine works is the freezer cools the fridge, and there should be a control in the fridge that operates the baffles in the airway between the freezer and fridge and reduces the amount of air that enters into the fresh food section.
Jun 17, 2012 | Admiral 26 cu. ft. Side-By-Side...
Ed2vhex side by side won't cool on refrig side. Freezer side is cold. What is the problem. It is under warranty.
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 07, 2011 | Whirlpool ED5VHGXM Side by Side...
Even though i have the frig set at 1 and the freezer at 4, things in my frig are freezing. What could be wrong?
the way that works is if you set the fridge area vent wide open and freezer at 4.
then you have called for most of all the cold air to blow from the freezer in to the cooler area.
this causes the cooler area to be to cold. go the other way with the fresh food setting and give it 48 hrs.
Dec 23, 2010 | GE Adora (DSF25KGTBG) Side by Side...
Fridge in storage for 4 yrs, now not cooling
Good day,
After that much time, be sure the fan motor in the freezer compartment is running, as well as the fan motor on the back bottom behind the cover by the compressor. Either could well have frozen up after 4 years of storage.
As well a refrigerant leak could have developed because of the time frame. However, if it is less then 5 years old, the sealed system would still be under factory warranty.
Apr 03, 2010 | Hotpoint HSS25GFP Side by Side...
Samsung side by side not as cold as it should be all fans sound like they are working what to look for fridge only 4 years old pulled out back cleaned coil pack with compressor please help
We had a similar problem. SAMSUNG said to not set the freezer to the top range and the fridge to top range. If you set the freezer to the top range there is not enough cold air funneled to the fridge. We usually set the freezer to about 3 dots and the fridge to 4 or 5. Try that and see if it helps
Dec 04, 2009 | Samsung RS2630WW Side by Side Refrigerator
I have a Whirlpool Gold Conquest Mod# GS6shexnt00 side-by-side. About 18 months after buying it the refrigerator section stopped getting cold but the freezer section still worked even though it had iced...
Yes, the difusser door is not allowing cold air to enter the fridge section, a fridge freezer is actually just a freezer, some of the cold air is drawn off from the freezer to chill the fridge protion, if the door is stuck, broken no cold air is getting to the fridge section
Aug 22, 2009 | Refrigerators
Refrigerators Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
