Question about Dell Office Equipment & Supplies
A document printed from Word on my Lenovo computer (Windows 7 Ultimate) is jumbled mix of different fonts and gives the printer the appearance that it is running out of ink. The same document printed
A document printed from Word on my Lenovo computer (Windows 7 Ultimate) is jumbled mix of different fonts and gives the printer the appearance that it is running out of ink. The same document printed from my Dell computer prints fine. Both computers use USB connection. Any fixes for this?
  • Dell Master
  • 10,291 Answers
Get a driver update for the problem computer. The printer driver is corrupt. Uninstall the printer before installing the new driver.
Posted on Dec 05, 2014
Testimonial: "Thank you. But I did that twice and still have the same problem."
  • Lawrence Oravetz Dec 08, 2014
    In order for the new driver to operate correctly , you must first uninstall the printer from your computer. Then install the new driver.
joelr2005
  • 464 Answers
SOURCE: Keep getting "Printer Offline" from Dell 1700 printer
go to the start menu
click on run
type services.msc
on the list go to Print Spooler
double click on print spooler and select automatic on startup type
now press on start.
if that doesn't work go to this microsoft website and click on the Fix It icon with the little man holding a wrench. run this and it will fix it.
Posted on Jan 10, 2010
leethedeuce
  • 4472 Answers
SOURCE: Dell Photo Scanner / Printer
Unfortunately on their website it isn't listed as supported by windows 7. Also when a new operating system comes out there is always a lot of issues in the beginning. I have seen quite a few windows 7 problems of this nature. My first question would be did you run the setup in compatibility mode for windows vista? This would be the first thing to try.
Thank you,
Lee
Posted on Jan 30, 2010
  • 8404 Answers
SOURCE: Using windows 7. Have a Zebra LP2844 printer
I dont think this model has a Windows 7 driver. You can check the Microsoft hardware compatability list to see if your printer is listed.
Posted on Apr 23, 2010
  • 53 Answers
SOURCE: Win 7 Ultimate PC won't print to HP C8180 network printer
You can use the Alternative Drivers to Print.
To Use the Alternative drivers, just follow the steps given below.
Go to devices and Printers
Select Add a Printer.
Click on Local Printer. Select Create a new port.
And Select Standard TCP/IP from the port list.
Enter the IP address of the Printer in Printer name or IPaddress. Click on next.
Make sure that you uncheck the automatically detect printer and install driver option.
Click Next. From the list of Manufacturer, select HP and from the list of Printers select Officejet 6500 wireless E709n. Click next.
Do not share this printer
try printing the test page.
if the issue still persists, Post back.
Posted on Apr 28, 2010
nonontech
  • 4737 Answers
SOURCE: I have a Computer running
I hope you do know that there are two windows 7 drivers for the printer, one is GDI and another is PDL. Would you mind letting me know which one you've installed?
If GDI isn't working, then PDL should work.
One more issue, if you've already install the previous windows versions' drivers for the printer, then that will cause problem in the system registry which means, you'll be unable to print using the printer. This is a very common. In this case, you'll need to uninstall all drivers or softwares related to the printer, run a registry cleaner and reinstall the fresh GDI or PDL driver for the printer.
You can download a registry cleaner from here (click here). Open the link, click the purple "Download Now" button, wait for about 20 seconds (watch the countdown timer and wait until it resets) and then click the purple "Download File Now" link, save it and install it (simple installation, just proceed forward in the manner "next", "yes" or "ok" and "finish"). After it's installed, open the program and click "Run cleaner", if you are asked with a confirmation message, click "Yes" or "Ok", wait for few seconds and click "Registry" when the cleaning is done. The "Registry" is on the left pane with blue icon, now on the middle column, click "Scan for issues" wait for another few seconds [or may be minutes] as the scanning progress runs and click "Fix selected issues" then, "No" and again "Fix all selected issues" and "close". ((Run the program after all the other programs are closed, otherwise it'll not be able to scan everything or fix all issues)) After it's done, close the program and restart your computer. Once it's restarted, again open the Ccleaner (the one you're gonna download from the above link) program and run the registry again.
When you are done, install the printer and try printing again. It should work now.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Posted on Sep 03, 2010
Can we print Courier New font with print quality UTL: Utility in OKI3320 printer
the printer normally prints the font set in the computer as it replicates the document
Mar 30, 2015 | OKI MICROLINE 3320 Matrix Printer
A document printed from Word on my Lenovo computer (Windows 7 Ultimate) is jumbled mix of different fonts and gives the printer the appearance that it is running out of ink. The same document printed from...
Check the print settings to be sure you are printing in black and white, not grayscale. Instead of clicking the printer icon to print, use the File, Print menu selections to bring up the print settings window.
Dec 03, 2014 | Dell Office Equipment & Supplies
HP IIP printer prints spaces where ink should be. Letters are incomplete, jumbled. A fixer problem??
HP Print Diagnostic Utility was created to help users troubleshoot and correct many common problems on Windows-based computers that can prevent printing.Follow the on-screen instructions to run the utility. Details and specifications File name: s.gif HPPDU.exe [1/1, 1.54M] System requirements: s.gif No additional prerequisites Released: s.gif 2010-08-13 Version: s.gif 3.0.0.013 Compatibility: s.gif Microsoft Windows Vista, Microsoft Windows Vista Home Premium (32-bit), Microsoft Windows Vista Home Basic (32-bit), Microsoft Windows Vista Business (32-bit), Microsoft Windows Vista Ultimate (32-bit), Microsoft Windows 7 (32-bit), Microsoft Windows 7 Home Basic (32-bit), Microsoft Windows 7 Home Premium (32-bit), Microsoft Windows 7 Professional (32-bit), Microsoft Windows 7 Enterprise (32-bit), Microsoft Windows 7 Ultimate (32-bit), Microsoft Windows 7 Home Basic (64-bit), Microsoft Windows 7 Home Premium (64-bit), Microsoft Windows 7 Professional (64-bit), Microsoft Windows 7 Enterprise (64-bit), Microsoft Windows 7 Ultimate (64-bit), Microsoft Windows 7 (64-bit), Microsoft Windows Vista (64-bit), Microsoft Windows Vista Home Basic (64-bit), Microsoft Windows Vista Home Premium (64-bit), Microsoft Windows Vista Business (64-bit), Microsoft Windows Vista Enterprise (64-bit), Microsoft Windows Vista Enterprise (32-bit), Microsoft Windows XP Fix/Enhancement: s.gif This version of the HP Print Diagnostic Utility provides an improved user interface in multiple languages, improved diagnostic and problem resolution capability, and support for usb and network connected devices.
Oct 27, 2010 | HP LaserJet IIIp Printer
My printer prints email etc. but will not print anything from my computer...example: word documents
I assume you mean that you can print from Outlook or other e-mail program (Outlook Express, LiveMail, Thunderbird). Are you reading your e-mail on the same computer that can't print Word documents?
If yes, one thing to try is to change the font on the Word document. For some reason, certain fonts just do not work. (Most often it is an issue with a document (or template) created on a different computer (or before upgrading the OS) and the font info gets scrambled in the transfer.) Just select all (control-A or Edit, Select All) and choose a new font. If the document has multiple fonts, do not use select all but highlight the sections separately and change the font.
If it is a different computer, check that the network is active and that all the correct drivers are installed. (One thing to check is a Universal Print Driver (UPD) software needs both the 32 and 64 bit drivers if the network has a mix of OS's. This comes up when the printer is attached to one computer and it serves as the print server.)
Apr 26, 2010 | HP PSC 2175 All-In-One InkJet Printer
Running windows 7 printer wont print anything but installed ok
Is this a brand new computer or did you upgrade to Windows 7? If you did an upgrade, you needed to uninstall the old drivers (with the printer disconnected from the computer). Then you could install Windows 7 and finally install the printer.
You can try unplugging the USB cable, uninstalling the printer and then reinstalling it.
What software are you using to create the file that you want to print? With Microsoft Office, I have seen reports that changing the font on a document can cure a failure to print the document with Word.
I hope this helps.
Dec 29, 2009 | Lexmark P4350 All-In-One InkJet Printer
Printing settings
Hi,I have a doubt, whether the perview is good and only the print out is bad or both are bad.
Anyway i am giving solutions for both.
The Statement or Report Looks Fine When Previewed, but Looks Bad When Printed If the appearance of the statement or report when printed differs from its appearance when previewed, this may indicate a problem with the printer driver (such as corruption of the driver files). Make sure you are using the most current version of the correct printer driver for the operating system on your computer. For example, a printer driver for an OkiData MicroLine 390 for Windows 98 may not work well at all when printing from Windows XP.
  1. If you need to check for a different printer driver, begin by checking the installation disk or CD-ROM that was provided with your printer.
  2. If you can't find the driver you need on the installation media provided by your printer's manufacturer, check the CD-ROM from which your operating system was installed (i.e., your Windows CD-ROM).
  3. If you can't find the driver you need on your Windows CD-ROM, or if you need to try an updated version of the driver you are currently using, check your printer manufacturer's Web site.my.okidata.com/pp-ML521.nsf/openingdrivermenu?OpenFrameSet
The Statement or Report Looks Bad Whether Previewed or Printed There are many factors that can contribute to undesirable printed output, such as margins, fonts, and custom paper sizes. Use the following steps to troubleshoot this problem.
  • Try using a different font size. See if there is a separate font size available for the same font family (e.g., 15 cpi vs.10 cpi).
  • Try adjusting the page margins and printer offset adjustments in the Page Setup window.
  • Check the printer driver properties to determine if a custom paper size is specified. If not, you may need to specify one. For example, when printing checks that have only one stub, you may need to set up a custom paper size of 8.5 inches wide by 7 inches tall. Conversely, if a custom paper size is incorrectly selected, printed output of reports and statements may be adversely affected.
  • In the Advanced Printing Features window, select the Optimize for Print to File check box and clear all other options and check boxes.
  • Try temporarily renaming the STI.INI file and restarting the Tabs3 or PracticeMaster program. The STI.INI file holds all of the printer settings. If this helps, you may have to recreate the margins, font selections, and other settings used for printing since that information is stored in the STI.INI file. If this does not help, delete the new STI.INI file and rename the original file back to STI.INI.
  • Is the printer configured to emulate another type of printer? Consult the printer's manual and/or the printer manufacturer's Web site to determine if the printer is able to emulate another type of printer such as an IBM Proprinter. If you have tried all of the internal fonts available in the printer's current configuration, it may be beneficial to configure the printer to emulate a different type of printer and then install the corresponding printer driver. Then you can test each of the internal fonts available in the new driver.
  • Once your printing issue has been resolved, check the printed output to ensure that lines are not wrapping or breaking when they should not. Make sure the margins all appear correct.
  • When you are satisfied that the printed output is completely correct, be sure to look at a preview of the same print job, to ensure that the preview is legible. For some printer drivers and fonts, it may be necessary to make a second installation of the printer that uses TrueType fonts. This second installation would then be selected whenever you need to preview reports or statements, and the original installation would be used for the actual printing.
Hope my info solves your problem,
Thanx for using fixya.
Oct 01, 2008 | OKI MICROLINE 521 Matrix Printer
Epson LX-300+II, the font problem
yes you can change the font tray to print the printer internal setting tray that press and hold any key by tarn the printer off then on after you tarn the printer on release the key
Sep 06, 2008 | Epson LX-300+ II Matrix Printer
X85 lexmark
Under file menu find page setup. Check the margin settings. Compare them to the ones that are in the printer properties. If they are different the jumbled characters are caused by conflicting settings. Try returning to defaults. If this does not solve the problem, check to see what fonts you are using. A page written in a font not supported by your computer will usually display with small boxes or crazy looking characters.
May 19, 2008 | Lexmark X85 All-In-One InkJet Printer
Printing differently than what is on screen
TRY PRINTING THROUGH MS WORD. OPEN MS WORD - CLICK ON FORMAT - FONTS - IN FONTS PAGE : SELECT TIMES NEW ROMAN UNDER FONT , REGULAR UNDER FONT STYLE , FONT SIZE AS DESIRED. UNCHECK EVERY OPTION OK CHECK WITH A PRINTOUT OR ELSE CLICK ON TIMES NEW ROMAN UNDER FONT AND CLICK ON DEFAULT, THE SYSTEM WOULD ASK YOU IF IT HAS TO BE SET AS DEFULT-SAY YES.
Sep 18, 2007 | HP DeskJet 5150 InkJet Printer
67 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
