Question about Denon Audio Players & Recorders
I have an Aiwa twin tape deck which has been up in the loft for a few years. I've connected it to my Denon amp and it plays a cassette fine for approx 20 mins and then it switches off and ther
I have an Aiwa twin tape deck which has been up in the loft for a few years. I've connected it to my Denon amp and it plays a cassette fine for approx 20 mins and then it switches off and there is no power until the next day when I switch it on and the same happens! any ideas anyone?
  • Denon Master
  • 10,291 Answers
Look for an electrolytic capacitor in the power supply that is no longer flat on top. Replace all capacitors that are bulging on top. Also look for a sand filled resistor that may be cracked.
Posted on Dec 05, 2014
robotek
  • 1512 Answers
SOURCE: NAKAMICHI CASSETTE DECK 1 NOT PLAYING?
it has probably thrown the capstan belt and will require a new belt fitted. the transport relies on capstan rotation to engage play. a separate reel motor operates ff/rew and takeup funtions
Posted on Dec 09, 2007
  • 579 Answers
SOURCE: Left Deck Door Stuck Shut on Cassette Deck
The cassette mechanism has a large gear that rotates to different positions for the different modes. On time around is a play - stop cycle. It is stuck in one position and won't come around to the stop spot. Need to take the cover off and help it to turn to get the cassette out. Then figure out if something is wrong preventing it from turning or if the wheel driving it is the problem. They are all a little different so this is where your mechanical apptitude comes in.
By the way, you'll figure out right away they don't intend these things to be fixed.
Hope Ya Fix It.
Posted on Feb 10, 2008
robotek
  • 1512 Answers
SOURCE: My Teac R-H500 tape deck will not play tapes
The belts will have failed. You will need to replace them for the deck to be reliable. If you are mechanically minded I can talk you through it... You giving me a FixYa rating will help my profile and loosen my lips on how to overhaul your deck. :)
Posted on Feb 14, 2008
  • 205 Answers
SOURCE: Need manual for a Denon Dr-M3 cassette deck
http://www.retrevo.com/support/Denon-DRM-555-manual/id/363ci856/t/2/ try this link
Posted on Oct 15, 2009
  • 5 Answers
SOURCE: Repair of Sansui cassette deck D-1000W and Compu Receiver Z-5000X in India.
i have the same deck with same problem..so this is the typical problem for this deck...got it from thrift shop..it was in perfect condition, working excellent but after few days of enjoying it, all of a sudden the same problem arises.... and the motor is abnormally hot..it is way too fast.
when i switch on the power the middle motor will automatically turn on at very high speed...i play around anything i can do hoping something is just stuck up but to no avail..
Posted on May 19, 2010
Denon tape deck ddr m30 will not play cassette, but fast forwards and rewinds fine, it just wont play!
There may be a separate motor for the play function and either it or a drive belt has failed.
Jun 17, 2016 | Denon Audio Players & Recorders
Denon DRM 740 tape does not play
hmmm...sounds like the transport motor/foot are stuck..open it up, and inspect around those items(where the tape actually clamps down) and see if you can see anything in there. Might even be a bug, no fooling..
as to repairs..you are most likely talking some major money, and a long time in the repair depot, which I believe is in Rio..I'll check that for you while you do this part.
Mar 16, 2008 | Denon DRM-740 Single Dual Cassette Deck
How can I use a hand held stereo microphone to record via a Denon F101 tape deck
You really need to include all brand and model number info for this question.
Feb 03, 2015 | Denon Audio Players & Recorders
Sony tape deck won't play tape.
Dual well decks are among the cheapest and poor designs resulting in the problem you are having. Those decks that are well built may still need belts after a long time but the final result of the repair is a machine that will give good performance like when it was new while the dual cassette deck give the poor performance and then less due to wear that was had when they were new- figures like Wow and Flutter, speed accuracy and they rarely put really good heads in these as well. I fix them for clients but they never come up to a Teac C-3RX deck quality wise. Just so you know I have been working on tape deck for 40 years and even at Sony at one time. The ES line was the only good dual cassettes made and they have their problems too.
Jan 29, 2013 | Audio Players & Recorders
I have an Aiwa Surround Sound Theatre system Model #cx-nmt720. Has a 3 disc player, am/fm, and 2 cassette decks (one on right allows recording/dubbing) Everything works great except cassette...
The unit may be damaged or may just need adjustment- only a tape deck technician will be able to answer the question after seeing the unit. To answer it remotely like this, is really an impossible task.
Nov 03, 2012 | Audio Players & Recorders
Denon DRM710 cassette deck. I need to know the actual output impedance of this machine. Or the minimum load it should "see." Have lost my manual which has the specs. Thank you.
Just curious, what load are you having problems with? It's a cassette deck, not an amplifier. Most Line Level outputs work just fine with other devices' Line Level inputs.
Aug 21, 2011 | Denon DRM-555 Dual Cassette Deck
Fixing aiwa stereo
i have an aiwa stereo system model no: cx- za20k ,the twin cassette deck works fine,but there is no playback from the c d player,the stereo takes 3 cd s and the player just says reading and changes to the next cd endlessly any one help please
Dec 25, 2007 | Aiwa Audio Players & Recorders
Tascam 202 Mk111
most all twin well machines will play off one deck and record to the other.
using an outboard mic preamp will allow for less noise using the sm57. balanced mic cable with 3 pin xlr/cannon connections also reduce noise.
Nov 23, 2007 | Tascam 202MKIII Single Dual Cassette Deck
53 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
