Question about Canon Office Equipment & Supplies
Error 602.00003 pl ans me how can farmet hdd ir2800 canon
    Sergeant:
  • Canon Expert
  • 223 Answers
A data read fault of the HDD is detected when the HDD is started up from the BOOT ROM Causes The wiring is faulty (short circuit, open circuit). The HDD is faulty. The main controller PCB is faulty. Remedy 1. Wiring Are the connection and the cable between connector J1025 of the main controller PCB and the connector J2005 of the HDD normal? NO: Correct the connector/cable. 2. System software Try re-installing the system software. Is the problem corrected? YES: End. 3. HDD, Main controller PCB Try replacing the HDD, and download the system software. Is the problem corrected? YES: End. NO: Replace the main controller PCB.
Posted on Dec 04, 2014
spinal
  • 287 Answers
SOURCE: E000003-0000
Hello 1999.We can reset the code together. And for many errors the copier can be reset,and then recover, then move on like normal. However the code you have (E000003-0000) means that an extremely temperature sensitive area of the machine misbehaved.And the copier gets really anal about monitoring this temp so the code may return as soon as the copier runs a diagnostic, but I can assure you we can reset the code so lets give a whirl and hope for the best.Ok, on your operator control panel, next to the nine key pad,is a button that says "additional functions".Locate it and we will perform a 3 step function that will allow you to enter "service mode" which will let you clear the code. Press "additional function", release it and then immediately press the 2 and 8 buttons simultaneously, release them and then press additional functions again. As I said this is a 3 step process that should be done in a smooth but timely fashion. If done properly this will summon a new screen that will show you a few "blocks" and the top block will say COPIER. Press it and a new screen will appearwhich will have several blocks across the top of the screen. One will say FUNCTION and you need to press it. Again a new screen. Look at the menu in the body of the screen and you will see CLEAR. Press clear. New screen again and look for ERR. Press ERR. After you have touched ERR notice the "OK" button in the lower right corner of the screen. Touch "ok". Now unplug the copier and wait a few seconds.Now plug that baby back in. The copier will attempt to return to a ready condition by "warming up". This is where the copier may notice a problem with the temp. Then make a copy. This will force the copier to run a brief diagnostic(which you wont see). If the copy successfully exits the copier then you should be ok. But the fact that the code occurred at all Means that at a minimum the copier had previously seen a problem and so the code may return. Hopefully, we just saved you the expense of a service call and all remains well. I hope I have helped you and I will keep my fingers crossed hoping it was merely a momentary problem. Good luck and take care. SPINAL
Posted on Jan 20, 2008
spinal
  • 287 Answers
SOURCE: Canon IR2800 Error E000002-0000
Hello 1999AirForce,
I am happpy to have helped you before. My concern is that this error code (E002) is also a fuser error code. The E003 you had experienced before Had to do with an error concerning monitoring the temperature of the fusing section. The "fuser " is a high voltage, high temperature and high pressure area that is responsible for taking the toner (which consists of carbon black, polymers(plastic) and other crud that apparently the EPA and OSHA do do not require absolute specifics on and through heat and pressure bonds this powder of "stuff "to the paper. Because the the heat in this area approaches the temperature of combustion it is monitored in many ways. If the temp does not reach the proper degree in a fixed amount of time......error code. If the temperature swings high or low, whether under operation or not....error code. And we are talking milliseconds of differential. It is because of the danger to property (and more like lawsuits) that every little aspect of the fuser is failsafed. And the monitoring of the fuser is so precise that even a fluctuation in line voltage,( which is used to calculate an algorithm) can cause an error. In fact , fluctuations in the line voltage is a primary cause for fuser errors. So, The initial code you had ....E003 which means that the temp reading of the fuser was incorrect could have been erroneous. There are "thermistors" that monitor the temp and actually touch the rollers.They can become dirty from toner crud and give false readings. But it appears you were able to reset the code. The error E002 is very similar. I can help you reset this code as well. But the fuser for your machine is basically good for @ 150K. It also has limited serviceability It can be seviced but I strongly suggest that the entire unit be replace if it is close to 150 k. Now, lets try to reset your code and then you can make the call depending on what options you have. But please remember that if you are in an area that the line power you have is suspect...... then you neen to write this sequence down just in case that its just power fluctuations.Ok , here we go. Press "additional functions"......then press the numbers 2and 8 at the same time, then press additional functions again. This will put you into service mode......typically used by only trained field engineers. The new menu you see will look wierd as it will be blue and have several "boxes" on the menu with "COPIER" at the top of the list.Touch copier and it will highlight, then press "ok" at the lower right corner. This will summon a new menu which will have several tabs at the top. Of those tabs prees "function". Now there will be many items listed in the main field of the screen. One of the items will be "CLEAR". Press it, it will hihglight. One of the options will be "ERR". Press it, it will highlight. Press "ok" located at the lower right corner. The copier will not acknowedge that you have done so so dont expect whistles and bells. :-) Now, press reset until you get back to the main(I'm pissed off screen) which wll again display the error code. Now reach around the right side at the back, slightly below the halfway point and you will see/ feel the rocker switch that is truly the main power and shut it off. Wait 5 secs, and power it back up. The copier will attempt to reset itself and probably will. If it does then cool. Please remember, poor power can cause this problem, and if tha meter count is close to, or exceeds 150,000 copies just buy (request) a fuser. the part number is FG6-6038-000. Let me know if I can help you more. THANX 4 YOUR SERVICE.
Posted on Jul 08, 2008
  • 990 Answers
SOURCE: error code E000019-0000, trying to find out what this error code means.
Hello sir; It's means waste toner bottle full, dump it after you turn off the power, then turn power back on.
Posted on Apr 29, 2009
canontech
  • 1219 Answers
SOURCE: My Ir2800 canon photocopier is not functioning, if
these is temperature related error, fixing fault.
First you need to try cancel it, follow these steps:
turn on the copier
press *
press 2
press 8
press *
select COPIER
select FUNCTION
select CLEAR
select ERR
OK
turn off and on
If these doesnt helps change fixing film assy ( heater )
Hope that helps
Posted on Aug 16, 2010
  • 122 Answers
SOURCE: my canon ir2800 is showing a error e000805-0002
one of exhaust fan is faulty or loose contact.
Posted on Jan 02, 2011
What is E602-000 on my CANON iR2800 machine which has stopped functioning?
Hi . That,error indicates there is a problem with the hard drive . Maybe is damaged
May 16, 2017 | Canon Office Equipment & Supplies
How do I clear error code E000003-0000
ppress additional functions, 2 and 8 then additional functions again
Go through the following to clear the error: CLEAR >
ENGIN > ERRCLR; and then turn OFF and then ON
I think, I dont have an ir2800 manual. This is an error in the fusing section, so it may come back and require some parts replaced.
Oct 21, 2011 | Office Equipment & Supplies
My copier ir2800 was indicating error 602- 0001 which is the fault to the HDD or main board but after replaced another HDD has changed error and indicated E677-578 then the display is not showing anything...
the hdd u have replaced is not with the 2800 software. is ur machine 2870 2830 2800
they all have different softwares
u have to get a HDD with same software as ur machine
Jun 29, 2011 | Canon imageRUNNER 2200
My Ir2800 canon photocopier is not functioning, if I switch the main power button on, I get an error message on the screen wit the code E000003-0000
turn on the copier
press *
press 2
press 8
press *
select COPIER
select FUNCTION
select CLEAR
select ERR
OK
turn off and on
Hope that helps
Aug 16, 2010 | Canon Office Equipment & Supplies
Error code E000019-0000, trying to find out what this error code means.
Apr 29, 2009 | Office Equipment & Supplies
My phone memori card is virus infected so i farmet it .than i farmet show error momori card write protected .so pl. suggest me what i do
Take out your phone memory card if it is detachable say a microsd card. Plug it in a microsd memory card reader a USB type then plug it in. You should have a good and updated antivirus installed in your computer. Run scan it should delete all virus. If now virus free it shouldn't now reported as right protected.
If it doesn' help some of virus signature is still in there, could be read,system,hide mode.
Leave comment so that I write down the next step but it will be in windows DOS mode.
Apr 12, 2009 | Computers & Internet
Canon copier IR2800 error code E 000999-384, any ideas please?
uninstall printer driver and then software install again.
Oct 11, 2008 | Canon Office Equipment & Supplies
old marine
old marine
