Question about Gateway Computers & Internet
WHY IS MAY TOUCHSCREEN NOT A TOUCHSCREEN ANYMORE..IT IS A GATEWAY ZX4800 ALL IN ONE
Did the recovery while it was still on windows 7. did not work. now it has windows 8 and it still does not work(touchscreen)
    Scholar:
  • 154 Answers
You will have to install the drivers for it.
Go to the website of the manufacturer of your pc, Gateway in your case, and search for support- downloads.
Then download the drivers for Windows 8 and install them.
Posted on Dec 04, 2014
Gateway zx4800 MBR is corrupt..error code = 0 x 57...too, need to know correct boot sequence
Windows installation CDs and DVDs have a number of system repair and recovery tools included that can get almost any computer back on its feet after a bad crash or faulty operating system installation. One very common problem that comes up when installing a second operating system is a corrupted Master Boot Record, or MBR. Windows System Recovery has tools that can fix a corrupted MBR, but if you don't have an installation CD or CD drive to put it in, you're going to need to copy the recovery materials to another medium, like a USB drive. If your MBR is corrupted, you probably don't have access to your Windows installation, so you'll have to follow most of these steps on another computer.
b> Insert the USB drive into another computer and run a command prompt window by typing "cmd" into the search box of the "Start" menu and hitting "Enter." Enter "mkdir X:\boot," and "mkdir X:\boot\sources" where X is the drive letter of your USB drive. Type "cd" and press the "Tab" key once, then hit "Enter." Enter "xcopy /H boot.sdi X:\boot," "xcopy /H Winre.wim X:\sources\boot.wim," "xcopy /H c:\windows\boot\dvd\pcat\bcd X:\boot," "xcopy /H c:\windows\boot\dvd\pcat\en-US\bootfix.bin X:\boot," and "xcopy /H c:\windows\boot\pcat\bootmgr X:\" to copy the necessary files to the USB drive. Enter "attrib -r -s -h /s X:\*" Enter "diskpart" to run the DiskPart program, then enter "list disk." The window lists the drives connected to your computer. Find your USB drive in the list and enter "select disk X", where X is the letter of your USB drive. Enter "list partition" to see the partitions on the drive and then "select partition X," where X is the number of the partition listed. Insert the USB drive into your computer and turn the computer on. Allow it to boot from the USB drive. You may have to set your USB drive as a primary boot drive in the computer's BIOS first. Enter your computer's BIOS (by tapping Delete or F2 during bootup, on most computers), then put your USB drive at the top of the "Startup" list. Go to the "Startup Repair" option in the "System Recovery Options" window. The "Startup Repair" process should correct your Master Boot Record and allow Windows to boot normally again. You will probably lose access to any other operating systems installed on your computer, though, since this recovery option is only designed to get Windows working again.
Hope this helps.
Dec 29, 2012 | Gateway ZX4800-06 (PWG8502023) 20 in. PC...
I want to conect gateway zx4800 touchscreen with a vizio tv is it possible ?
i have a vizio hd tv myself, and i can connect my pc's to it if i have the correct cables. my tv is not internet capable but if it was and you have wireless you should be able to do it without cables. if your pc has hdmi port and your tv has hdmi port that would be the easiest way. else look at tv for a pci connection and get a usb/pci cable to connect the two.
Dec 20, 2012 | Gateway ZX4800-02 20in LCD Desktop PDC...
I have a zx4800 touchscreen gateway and i want to conect it with the tv is it possible ?
You may be able to add a second monitor. You need a USB video adapter to get an external video port. There are no external video ports on the ZX4800 all-in-ones. Here is an example USB VGA adapter: http://www.newegg.com/Product/Product.aspx?Item=N82E16812225007 . DVI and HDMI versions also exist. These aren't the greatest solution so don't use them for gaming.
These will work if the TV has a compatible port. If your TV has VGA input, you are fine with this option. If your TV has HDMI inputs, you need to check the specifications. Some TVs have HDMI ports that do not interpret the signal from a computer. If your TV only has composite or component video inputs, you will need a converter from VGA (RGB) to the TVs input. (Component is YPbPr.) One option is http://www.ramelectronics.net/product.aspx?zpid=3294 . VGA to component video cables do not work; those are meant for projectors that understand the RGB encoding.
I hope this helps.
Dec 20, 2012 | Gateway GM5664 Desktop PC
The touch screen on my Gateway ZX4800 is being unresponsive sometimes and refuses to move the cursor, however other times it works just fine. What do I need to do to fix this? I have tried messing with the...
Press the flag key and type "windows update" and press enter. Click "check for updates" and click on "Optional updates". See if there are any with "driver" in the name. If so, make sure they are check. Than go ahead and update. You will need to restart your computer once it is done.
May 04, 2011 | Gateway ZX4800-06 (PWG8502023) 20 in. PC...
I have a HP Pavilion tx2620es with Windows Vista 32bits working perfectly, i buy Windows7 Upgrade Kit from HP, so i installed it and all sort of problems became: -Rotation of screen has stop working -Touch...
TRY TO DO CUSTOM/CLEAN INSTALL OF WINDOWS 7, BUT BEFORE INSTALLING IT DOWNLOAD WINDOWS 7 upgrade advisor , HERE IS THE LINK http://www.microsoft.com/downloads/details.aspx?FamilyID=1b544e90-7659-4bd9-9e51-2497c146af15&displaylang=en RUN IT ON VISTA TO MAKE SURE WINDOWS 7 IS ABLE TO BE INSTALLED ON YOUR PC. BECAUSE WINDOWS 7 IS NEW OS IT MIGHT GIVE YOU MORE TROUBLES ON TABLET PC`s, MICROSOFT STILL UPDATING THEIR DATABASE FOR CORRECT DRIVERS FOR WINDOWS 7, ANYWAYS , I`LL SUGGEST YOU RUNING UPGRADE ADVISOR ON VISTA.
Mar 09, 2010 | HP Pavilion Tablet Notebook
Cannot get my gateway ZX4800-3 desktop to send data to Printer
I wanted to provide some clarification to you. Once your devices (printer in this case) and computers are connected to your router, they have the connection. Now the communication settings between each computer and devices are to be configured on each computer individually. Obviously the first step would be to install the drivers that came with your printer on the new Gateway just like you did on your other computers. *This is undoubtedly where the problem lies.* You have a printer that was produced prior to Windows 7 being released. Check the website of the manufacturer of your printer to see if they have released a new driver for Windows 7. Download it to your new computer and install. That should take care of you.
Jan 04, 2010 | Computers & Internet
Computers & Internet Logo
98 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
