My 1067 Rotel-when I put on a DVD and when I touch the Volumn Control for up or down- the Picture goes black for a few and then comes back in each time. Any Ideas?
Nothing- I have NO idea!Just set it up today!
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 924 Answers
How do you have it connected up? Are you using HDMI? How about the sound? Does that drop out as well? Let me know, as you may have a firmware issue.
Posted on Dec 06, 2014
My LG tv will go on then after a few seconds the screen goes from black back to picture of and on a few times then shuts off. Help!
LG LED TV has no picture (black screen) but still sound ...
www.tomsguide.com/answers/.../led-picture-black-screen-sound-fixed.ht...
7 days ago - My 32' LG LED TV has suddenly lost picture! The sound is all right but theScreen is pitch black. After switching it on the picture flashes for a second and thenthe ... LG LED TV has no picture (black screen) but still sound - can it be fixed? Tags: ... a touch on the screen reveals nothing so it's not the back light.
Monitor going black after 2 seconds [Solved] - CCM.net
ccm.net > Forum > Hardware
Oct 9, 2012 - Brightness goes down, display draws less juice, and you can at least use .... it's the LCD's Inverter ... you have to replace it for it to go back to ... If the screen is turning off every two seconds or so and then it comes ... i turn my tv on it comes right on, but then after a few minutes turns off, .... Digital Trends for LG. No display in monitor
Jan 11, 2013
Ps3 and hdmi cable
Oct 8, 2012
More results from ccm.net
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
Dec 20, 2015 | LG Televison & Video
HALLO I HAVE A ROTEL RA 9858X AND AGTER PLAYING FOR A FEW MINUTES I LOSE THE RIGHT SPEAKER CHANEL
Try interchanging the speakers. If the right channel works, you have a problem with your speaker.
Jun 14, 2014 | Rotel Audio Players & Recorders
RCA Stav-3880 turn stereo on goes to full volumn
Take the batteries out of the remote control, then apply a piece of black tape over the IR sensor, Unplug the power, wait a few minutes, now power the unit back up, does the unit still have the same volume high symptom? If so, remove the tape and see if the unit responds to any other commands(other than volume) from the front panel. If it responds to the panel controls, the processor is most likely good. very seldom is the IR transistor bad, if it is no input command will work.
Feb 15, 2014 | RCA Optimus/Stav-3880 Rcvr Parts - Board -...
Where can we buy the remote of RSX 1067 7IN1
I do not know anything about your brand or market, but I have had good success with replacement remotes at http://www.replacementremotes.com/
They have a very wide selection of mostly refurbished remotes.
Originally supplied with RSX 1058 is this:
http://www.replacementremotes.com/ROTEL/Buy-RR-1061-RR1061-Audio-Remote-Control.html
Jan 18, 2014 | Rotel Audio Players & Recorders
Picture goes black for a few seconds and comes back. This happens at random, not all the time
The main board probably has bad connections that need to be touched up with a soldering iron. Plus a few capacitors in and around the power supply.
Jan 01, 2011 | Sony KV-36XBR400 36" TV
Hi i have a Rotel Rsx 1067, powers up then off, the remote control is using new batteries, the receiver pickups the remote sensor but doesn't do nothing. volume control does not adjust up or down, and when...
Try fixing your remote controller, because sometimes when we neglected to replace our remote batteries for a while, it will leak and it will build up on the contacts of the remote pad.
Take off the battery, open the back of your remote, lift the circuit board, clean the green painted part with cotton balls slightly damp with rubbing alcohol as well as the black thingy behind your remote pad, let it dry put it back together, replace with a new battery and try if it works.
Good luck
Sep 28, 2010 | Rotel RX-965 Receiver
47in Phillips-tv picture goes black still has
Could be the signal board has a bad cap, in this case it sounds like you are getting intermitten power to the inverters....when the tv goes down and of course you have audio....Shine a flashlight on to screen and see if you have a picture...look carefully. If this is the case..you have the above problem!
Nov 23, 2009 | Televison & Video
Large black box keeps covering 80% of the screen
i have the same problem, when i turn the volume knob on hitachi remote it goes away. Anyone heard of thi s???
Aug 30, 2008 | Hitachi 42HDS69 42 in. Plasma Television
46 people viewed this question
 Grubhead
Grubhead
