Question about Maytag Washing Machines
When maytag washer is draining it makes noises . What could be wrong
Undid pump hoses and I didn't see anything in them what could be causing the problem
    Sergeant:
  • 268 Answers
You could have a bad pump bearing. something caught in the pump or broken impeller blades on the pump. Bearing noise or a bad impeller would be noisy for as long as the pump is running. Please be more specific if you can on what types of noise it is making, whether it is noise that was there before and is just getting louder, and whether or not the noise is constant or intermittent.
Posted on Dec 04, 2014
Maytag washer makes noises when draining
WHAT KIND OF NOISES? JUST THE DRAIN OR WHEN SPINNING?
Dec 04, 2014 | Maytag Washing Machines
My washer is making a humming noise and will not run. there are currently clothes and water in the washer
remove 4 screws on the rear panel and then remove the cover, you can see the drain pump remove both hoses on the pump,it is probably plugged up,if it is they wont drain or do anything
Apr 30, 2012 | Maytag MAH6700AWW Neptune Front-Load...
My washer stopped working and is displaying the code nd, what does this mean?
Hello & Welcome to FixYa
ND error in your Maytag Front Load washer indicates no drain issue. To start with check the drain hose for any clogs and try cleaning it, then check restriction in drain pump assembly or loose wire at the pump. Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Maytag NFW7200TW Front Load Washer
My washer is making a rattling noise as if the water is not leaving the machine. I checked the hose...nothing....now my washer has water in it
does your washer spins?. the most common cause would be a sock caught in the pump blocking the water drain and making noise with the pump impeller.
Feb 05, 2011 | Maytag Bravos MTW6600T Top Load Washer
Maytag washer MAV208DAWW does not spin out the water completely from clothes after spin cycle.
do you smell anything burning or a burning oder,your belt could be glazed from over loading the washer and now the belt is slipping,also check the drain hose for kinks making for a slow drain,do you hear any noises when draining like something could be stuck in the pump, maybe to much detergent and it's oversudsing, or you could have a bad trainy,check the belt first belt part number is 21352320 and it's around 25 bucks
Feb 26, 2010 | Maytag Washing Machines
My washer is not draining. I used to be able to reset it and it would work but now it wont start on any setting and is full of water. Is there anything i can try.
If your Maytag washer is not draining, follow these procedures to find out what is the problem.Set the timer in the spin cycle and pull the knob to turn the washer on. If the washer motor doesn't run, check the following parts.
The wall outlet: Make sure that there are about 120 volts present at the wall outlet. Connect a good working hair dryer to see if it works.If the hair dryer works ok, then the problem has to be in the washer. If the hair dryer doesn't work, then look for a blown fuse or tripped circuit breaker.
The lid or door switch : The lid switch is a safety device use to stop the motor from running if the washer door is opened during the agitation or spin cycles. A bad lid switch could be the reason for your washer not draining.
The pump : Check for obstructions inside of the pump and inside of the tub.
Check the pump impeller, the pump belt, check the drain hose for any kinks. Any problems in these parts could be the cause for the Maytag washer not draining.
Lower the drain hose to a bucket to see if the water drains out. If the water won’t drain or just trickles out, most likely there is an obstruction on the pump or inside of the tub and that could cause the washer not draining.
To check the pump, remove the front panel, lean the washer against the wall and bail the water out with a plastic container.
To check the pump, remove the pump belt and turn the pump pulley to make sure that the pulley is turning freely.
Put a couple towels near the pump to catch any water from the pump. Remove the tub to pump hose at and check inside of the pump for any obstruction. If you find an obstruction remove it.
If you don’t find anything, reinstall the hose and remove the hose at the tub, and check for obstructions.
A Maytag washer not draining could be cause simply by a kink drain hose.
You need to make sure that when you replace the pump, you adjust the belts properly.
Jan 29, 2010 | Maytag Washing Machines
My Maytag HAV2557AWW Loud Noise
pull hoses off the pump and see if there is anything stuck in it
Jun 12, 2009 | Maytag HAV2557 Top Load Washer
Grinding Noise when Washer Attempts to Spin
It is probably the same problem because it is trying to drain during the spin cycle. My machine sounded as though a chain wis clanking, the solution was removing a coin caught in the drain pump. Access the pump from the bottom of the machine. 4 screws hold the mounting bracket on undo those, the electrical connection and two hose to the pump. Undo three screws holding impeller to motor and coin can fall out. Examine for damage if it is not too tore up, put back together. Keep in mind that when you unclamp the hoses that water will come out.
Feb 02, 2009 | Maytag MAH2400A Front Load Washer
MAH2400AWW washer won't drain
pump is plugged unplug washer lean back against wall under unit right front 2, 5/16 screws lets pump free take hoses on both sides free check for coins after pump and objects before pump and in pump clear reinstall if clear replace pump just had 2
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Washing Machines Logo
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
