Question about Philips Televison & Video
How to replace clock in Philips DVDR3575H/37 hard drive recorder
The clock in my hard drive recorder does not keep time anymore where is it located and where do I get one and change it ?
    Master:
  • Philips Master
  • 487 Answers
Talk to Philips at: http://www.support.philips.com/support/contact/contact_page.jsp?userCountry=ca&userLanguage=en
Posted on May 07, 2015
2 Suggested Answers
SOURCE: Philips DVDr3575H/37 Clock Resets
I found this on another board from "Dartman"
You probably have the auto clock turned on and it's finding the wrong channel to set itself with.
You can turn that feature of then it will loose or gain time according to how accurate your individual time chip is.
Also that unit only gets the time signal from analog stations and if your in the USA those were shut down the 24th of June, if your on cable they MIGHT still be working as most still carry some networks on a small analog basic section.
Try this place and thread, more then you want to know about that machine.
http://www.avsforum.com/avs-vb/showthread.php?t=940657
Posted on Jul 06, 2009
DVDR3575H doesn't recognize replacement HD
Unable to FORMAT the HDD in the device? Perhaps remove the drive - hook it up to a working PC temporarily, and using a partition software program or you could burn a CD (I use PartitionWizard), delete any or all partitions on the new 160GB WD and make that drive UNALLOCATED and UNFORMATTED. Apply the actions as needed - only to that drive (this will at least allow your unit to recognize it properly). Once done, remove the drive from the PC, and put it back into your recorder - see if it recognizes it this time, then try and format it (in accordance with the type of file system the unit uses - which may differ from that of a PC). Replacement drives should be formatted to suit the unit they are intended for AFTER they are fitted, not before. Otherwise you run into compatibility problems (e.g. the drive won't allow recording/doesn't read etc., but might work in a PC). If this is the case, it may explain greyed out options and not being able to record to it. If you still have the original drive, check the jumper setting to be sure. If both old and new are set to CS - leave them as is - don't change that.
Dec 18, 2017 | Philips DVDR3575H/37
Doesn't recognize replacement hard drive
What is the type of IC regulator voltage on power supply board Onkyo DV-SP502?
Jan 17, 2014 | Philips DVDR3575H/37
DVR will not record to hard drive
I did a (General Settings) RESET. Then I erased all programs on the HDD. Presto - it now records to the HDD a-ok.
Dec 19, 2011 | Philips DVDR3575H/37
The clock on my Philips DVDR3575/37 jumps 20 years into future
yes you could but you need to replace the battery inside the unit to make it keep time it's the same as the batteries for mother boards.
Jun 25, 2009 | Philips DVDR3575H/37
Jun 08, 2009 | Philips DVDR3575H/37
Dvdr 3455H/97 hard disk unable to reboot
from krystle i am an electronic tec:
what i have found the big difference between the philips dvdr3455h and the dvdr3575h is the
dvdr3455h boot from software on the hard drive and the dvdr3575h boot from an eprom.
the dvdr3455 has both booth software and movie edit software, if the hard drive become
bad in the 3455 or the software become corrupted it wil hang at the philips logo screen.
the dvdr3575h will boot with a bad hard drive or no hard drive at all you will you wont be able to
capture your video to the hard drive.
if the movie edit software become corrupt or damage when you press record button
it will just lock up the recorder.you will need a software reload if the software become corrupt.
if you need a reload on your hard drie email me i will tell you what you need to do my email is krystle913@yahoo.com
Nov 15, 2008 | Philips DVDR3455H/37B
Replace/Upgrade Hard Drive in Philips DVDR 3575H DVD Recorder
email this person at krystle913@yahoo.com for a replacement hard drive for the philips DVDR3575H OR DVDR3575H/37
also can replace hard drive in the philips DVDR3455H OR DVDR3455H/37
Oct 13, 2008 | Televison & Video
Philips dvdr3575h/37 Initial setup
Do you have two cable inputs going into your player?
May 01, 2008 | Philips DVDR3575H/37
Unlock Code for Philips DVDR3575H/37
There is a YouTube video that has the secret code. WARNING: it will only work 3 times, and then the code will no longer work.
Mar 27, 2008 | Philips DVDR3575H/37
Televison & Video Logo
114 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
