Question about Lowrance Elite-5 HDI 83/200 455/800 Combo Unit - Transom Mount
How do I insert a navtronics sim into an Elite- 5HDI ?
Just cannot find how to insert it into the sounder
    Problem Solver:
  • 10 Answers
If you have an Elite 5x then it is not a combo unit
If it is a combo them the small door about the power button with the model number on it swings open.
A micro SD card goes in there. If your chart is an SD not a micro you will find the micro is in the end of the big car. Pull it out and pop it into the unit.
hope this helps
Posted on Dec 17, 2014
Lowrance elite -7xhdi manual
Try Googling (Lowrance)(7xhdi)(manual) without parens.
Oct 11, 2017 | Lowrance GPS
Elite-5HDI Screen is frozen and unit will not shut off.
Hi Thomas
I think your best bet here would be to contact Lowrance support directly I've included the link below.
-Steve
Contact Us
Mar 08, 2015 | Lowrance Elite-5 HDI with 83 200 kHz and...
Hi. I"ve got a brand new elite 5hdi and been on for about 1 hour. does not want to lock in. import it from the states to Mozambique. please help
Hi Pieter
The problem here is that the unit has no idea where it is on the planet.
I think your best bet would be to reset the unit to factory defaults (page 11 of the owner's manual) and THEN use the setup wizard (page 6) to reinitialize the device.
Link to owner's manual provided below in case you or anyone else requires it.
Hope this helps and good luck!
-Steve
http://www.lowrance.com/Root/Lowrance-Documents/US/ELITE-5_HDI_OM_EN_988-10518-001_w.pdf
Mar 03, 2015 | Lowrance HDS 5 Fishfinder GPS Chart...
Can i put lowrance 5hdi sounder and a lowrange sounder/gps 7hdi on the same transponder unit?
If you want to use two head units off of 1 transducer the answer is yes. You will require a transducer switch that allows you to select which head unit receives the sonar signal.
If you want to swap head units utilizing the same transducer the answer is also yes you can do that.
Dec 19, 2014 | Lowrance X515cdf 5" Color Lcd Sounder With...
What is nmea
As Anreas said, The new standard for NAMEA is 2000 used to communicate between multiple devicsess wth multiple talkers. 0183 can only have one talker
Jul 17, 2014 | Lowrance Elite 7x Hdi Fishfinder 50/200...
How do iremove beep from LG tech eleite
The beep is mandatory and a safety feature. It is also used for warning of malfunction. This is a medical device and you may render it dangerous by removing the internal sounder. I cannot recommend removal of sounder although i can see no reason why you could not quieten it with a little tape over the holes as long as it can still be heard.
Jul 05, 2014 | LGMedsupply.com TENS Unit and Muscle...
How to open449CSTE - Smoke Detector W/Heat Sensor, Sounder & Status Relay keeps going off from stean
Opening is simple, but I don't know what you expect to accomplish. Just insert a small flatblade in the vertical opening opposite the hinge side and press firmly to release. If the plan is to disable the device by removing the wires you will only create a trouble condition if your smokes have been wired correctly. More info about your intentions might be helpful.
May 22, 2014 | GE 449CSTE - Smoke Detector W/Heat Sensor,...
I can never read the fish on the screen of my sounder whether is in auto or manual mode (yes we are catching fish)
perhaps someone has messed with your sounder settings. You may want to factory reset the sounder from within one of the menus in your navnet. Also you may have a transducer going bad. Did you hit anything with it or run aground once? Maybe someone painted over the face of the transducer with bottom paint. There's alot of things that can cause this to happen. It would be best to have the sounder checked out before you do anything to the ducer. Remove your navnet and sounder and take it to a dealer to test on the bench. If you're in the maryland area, Mid-shore Electronics and handle this for you. Even if you're not, you can send the units to them.
Dec 31, 2009 | Furuno NavNet vx2 GP1720C GPS Receiver
Lowrance Elite-5 HDI 83/200 455/800 Combo Unit - Transom Mount Logo
97 people viewed this question
Top Lowrance GPS Experts
Andrew Taylor
Andrew Taylor
Are you a Lowrance GPS Expert? Answer questions, earn points and help others
