Question about Refrigerators
I have a Danby dar483bls.... It gets cold then in once it gets to the desired temp it shuts off???
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 70 Answers
Thermistor or temp control thermostat problem?
Posted on Dec 05, 2014
3 Suggested Answers
  • 1891 Answers
SOURCE: refrigerator wont shut off
replace the cold control and prob should be over .. mm
Posted on Jul 01, 2010
SOURCE: fridge does not get cold , " E4" displayed on
change digital board in the front
Posted on Aug 18, 2011
Danby silhouette Minifridge model DAR483BLS. Runs but does not get cold. What's the problem?
Does the compressor actually run or is it just the evaporator fan that you hear running inside the unit? If the compressor is running but never gets cold you have a leak in the system and not much freon left.
Nov 10, 2014 | Furniture
Danby silhouette runs but does not get cold. Model number DAR483BLS. What's the problem?
Sounds like a gas leak. Could be caused by rust. If refrigerant has leaked out through a failure in the pipe work it's probably not worth fixing. If compressor still runs ok get a tech to check for pipe damage or failure. If you continue to run compressor longer term without refrigerant it will damage the compressor. Best to get a tech to ascertain the problem soon.
How do u set temp in a Danby wine frig?
Please have a look at page 4 of the product manual where step-by-step directions are provided for setting your desired temperature.
http://www.danby.com/cms/products/en_manual/DWC283BLS_%28web%29.pdf
If you have any further questions, please do not hesitate to contact Danby Customer Service via 1-800-26-DANBY
Hours of Operation Monday -- Thursday 8:30am - 5:00pm EST
Friday 8:30am - 4:00pm EST
May 05, 2012 | Danby DWC283BLS Wine Cooler
Model # DAR483BLS. Temperature settings not working. LG light remains on ( what is that). Fridge is freezing everything.
My Temperature settings are not working, also is not cooling. The factory setting is also not working. Is there something I can do?
Oct 14, 2010 | Danby DAR483BLS Compact Refrigerator
What is the amperage draw on a dar483bls? i need to install on a boat and my amperage available ,is limited
It won't draw more than 7.5 amps when is running and at the sttart momentum it might go up to10 amps , always with a 110 volt line.
Aug 14, 2009 | Danby Silhouette DWC512BL Wine Cooler
FREEZER NOT FREEZING CONTENTS
I have a similar problem with danby and have been unable to get help - I now HATE Danby Chest Freezers
Mar 10, 2009 | Danby 5.5 cu. ft. / 156 liter Chest...
GE GSS25LGMA WW FREEZES FOOD
These refrigerator use the cold air from the freezer the cool the refrigerator. At the rear of the upper refrigerator compartment, there is a shroud. Remove the shroud and you should see a "flapper" that shuts off the cold air when desired. You will most likely see the flap is broken. Once the flap is broken, you lose control of your refrigerator temp. This is a common problem with this refrigerator.
Hope this helps.
Jan 11, 2009 | Refrigerators
Thermostat
It's the Danby "auto-defrost" feature. It cycles off every 24 hrs to defrost, at which time the temp rises (as the unit isn't running!). Not much you can do. By the way, the blue LED temp display isn't accurate. It NEVER gets 36 (liquid temp) inside the Danby unless you do the following: Open the door and look to the back left. There is a small grate covering the temp sensor. Remove the grate and place the sensor into a small cup of water. The sensor will now read the "liquid" temp inside the keg, and not the "air" temp. The Danby will then cool the inside to a more beer friendly temp, and should not only cut back on foam, but taste better.
Sep 03, 2007 | Danby DKC645BLS Compact Beverage Cooler
Refrigerators Logo
64 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
