Question about Pool & Spa
Where will I find a manual for Hurlcon Chlorinator C140
Hurlcon cx240
bad sensor and cell calsified need to super shock poool
Mar 19, 2017 | Pool & Spa
Why does my salt level get low
You can get a false low salt reading if your chlorinator cell is very dirty. Before adding more salt clean the chlorinator cell as per your maintenance manual.
Sep 01, 2012 | Intex Automatic Salt Water System for ...
My low salt light on my Hurlcon vx7t salt chlorinator keeps comming on.How do i adjust it?
A low salt level warning is indicated on your VX Chlorinator if the salt level drops. If Low Salt is indicated, check again in 24 hours and then if it is still indicated, add two 25kg bags of salt to the shallow end of your pool. Run the filtration system for approx. 6 hours to help mix the salt in the pool. It can take up to a day for the salt to fully dissolve.
If the low salt light is still on, then you should get your pool water tested. If the Salinity is above 4000ppm then you may need to have your Chlorinator checked.
Warning: Some people recommend that you put salt directly in the skimmer box. This is a very bad practice as it allows very high concentrations of salt to be passed through your filtration and other pool equipment.
Hope this helps.
Jul 06, 2011 | Grilling
I opened my pool a couple of weeks ago and filled my Hayward CL200 chlorinator with 3'' tablets. I usually set the dial on 2 with good results. After over a week, the chlorine level was nill in the pool....
A CL200 Involves direct injection of chlorine into the pool. Water passes through the chlorinator and goes to the pool with chlorinated. WIth the 200 (Not the 220) I've only seen a handful with problems over the years with chlorine not dissolving. If the chlorinator is not leaking, and the control valve is moving freely here's what I'd recommend.
1. Are you using a new type of tablet?
If so remove the tablets and place into a floating chlorinator.*** WARNING Wear Rubber Gloves, while handling wet tabs****
Dial it all the way open. If the tablets don't break down at this point with in a day or two, They were over compressed at the factory, potentially have to much filler (most slow tablets should be 95-99% cholroine) or the water is too cold ( below 70 deg. This should not be an issue in July) If this is the case switch brands.
If the chlorine is dissolving in the floater but not the chlorinator it could be one of the following.
1. Make sure the direction on the chlorinator is correct inlet (from Filter) to outlet (to pool)
2.. In some of the newer 200 chlorinators there is a built in check valve you can see it in the bottom of the chlorinator You will notice a threaded piece in the bottom that contains a white plastic ball the size of a pea. If this ball does not move freely to the touch, odds are the filler in your chlorine has clogged it from moving, thus preventing the flow of water from dissolving the chlorine.
You can check this by removing the chlorinator from the pool, removing the lid and pouring water directly into the top. If you do not see water passing through to the "Outlet" side of the chlorinator a clog is most likey your problem.
I've seen clogs cleared with wire coat hangers and hot water. Be forewarned that hot water being poured into a chlorinator will cause the any residual chlorine to gas off, make sure you do not have you face over the chlorinator when you add the hot water and you do so in a very well ventilated area. A straightened wire coat hanger can be used to dislodge any obstruction in the check valve and "get the ball rolling again"
Hope it helps.
Jun 10, 2009 | Hayward In Line Chlorinator 9 Lb. Capacity...
NEED MANUAL FOR COMPAQ HPC HANDHELD C140 - CANNOT FIND ON COMPAQ HP SITE
Downloads for this product are not available through this website. Please contact your local HP representative for information on the specific update methods available for this product.
Jan 10, 2008 | Compaq C140 Pocket PC
I need owners manual
You can download the manual from the link below: http://www.sandisk.com/Assets/File/pdf/retail/25991_sandisk_angl.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 20, 2007 | SanDisk Sansa c140 MP3 Player
Pool & Spa Logo
97 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
