Question about Water Filters & Coolers
Norlake Cooler: water dripping out of vent at top of cooler.
SOURCE: Hamilton Beach 87330 water cooler
Hello! About 2 weeks ago, the same problem began on my Hamilton Beach water dispenser.
Last week, I called the HB service support, and they told me to do the following reset procedure:
1. Dispense 3 cups from the HOT water side, and also, 3 cups from the COLD water side.
2. Turn BOTH back switches OFF (the ones on the back of the water dispenser).
3. Unplug the dispenser, and LEAVE it unplugged for 24 hours.
4. After 24 hours, turn the back switches ON and plug it in.
5. Leave it on for 4 hours WITHOUT dispensing any water.
...it's been about 12 hours since I've dispensed water again for the first time, and so far, SO GOOD! I'll update if the problems reappear.
Posted on Nov 05, 2008
SOURCE: sunbeam water cooler model # YLR2-5-25H2
I called a bunch of different numbers and finally found the people who can help with this. It's called Elite Group (877-383-6399) - I guess they're the ones licensing the Sunbeam name and making these water coolers. If you call that number with the model number, they'll replace the "top" part of the cooler, which should also have new taps, the lady said. The cost is $13.35
Posted on May 05, 2009
SOURCE: it is freezing up inside the cooler
My water cooler is freezing up and stops the water from dispensing, If I unplug it it thaws but then refreezes.
I turned the screw on the back of the unit so that the water is not chilled to such an extreme cold and this did not solve the problem
Posted on Oct 10, 2009
SOURCE: Water Cooler - Water has mildew taste
I just put about six cups of white vinegar (not diluted) into the reservoir and let it sit for about an hour. Then I emptied that out and flushed a few pitchers of very hot water through. It seems to have worked quite well.
Posted on Nov 25, 2009
SOURCE: How to clean/repair water cooler
I have a hamilton beach water cooler with storage cabinet # 87330. The cold water is not cold and the cooling light stays on. What is the problem and how can I fix it? Thanks!
Posted on Dec 20, 2009
My Hamilton Beach water cooler is just dripping water on the cold side but running free on the Hot side.Yesterday I flushed the cooler out with vinigar and hot water but today we have a problem
I have same problem keeps running till freeze up so i put a timer on the power cord it shuts off at 11.00 pm till 6am in morning the water keeps pretty cold and a lot cheaper then a new board or scrapping the cooler after starting for about an hour water is cold
Jun 18, 2012 | Hamilton Beach Water Cooler with Storage...
NORLAKE cooler not turning on
I would have tried to get you going as fast as possible, but when you have a business things are different. If you have any commercial equipment it is always good to have a source for answers. Model Numbers and Brand Names listed someplace where you know just what you have and know who to call without having to get into an expensive repair trap. I'm not saying that those that came out overcharged you but it does happen a good bit of the time. If I can help feel free to ask here or through my websites, Thanks, John Tripp/AKA Sea Breeze
Nov 02, 2011 | Nor-Lake Norlake Refrigeration 4' x 6'...
Marvel wine cooler leaks water
All coolers produce water as a result of condensation which occurs when air is cooled. The water appears upon the radiator (technically called the evaporator) inside the cold area of the cooler. When the water drips off of the radiator, it is caught by a pan which may or may not be a removable piece. The pan should lean toward the rear of the cooler and the water should pour into a drain tube. The drain tube should lead down into the compressor area of the cooler and deposit the water into another pain which is outside of the cooler where it should evaporate back into the air. Sometimes "cardboard" fins are used to help the water evaporate. Sometimes a pan with a huge surface area is used to help the water evaporate. Other times the pan is literally on top of the compressor. Make sure the cooler itself is level. Make sure room air is able to move over the pan where the water is supposed to evaporate. Make sure the drain hose is not clogged. Make sure pans are not leaking.
Jun 11, 2011 | Marvel (6SBARBSG) Wine Cooler
How can I adjust the temp. on a norlake walk in cooler?
There are many variations for a Norlake system
I assume the cooling coil hangs from the ceiling of the cooler and the condensing unit sits on the top?
The temperature is controlled by a control that is located in the condensing unit on the top of the cooler. This can be either;
\ a digital thermostat. You will need the progam key to get in
\mechanical thermostat. Adjust the dial setting
\ pressure stat. Adjust the dial setting
Probably best to get a technician in
Apr 22, 2011 | Refrigerators
Nor-Lake walk-in cooler water leak
The evaporator drains into pan with a coil from the discharge line. The design is intented to sub-cool the liquid refrigertant as well as evaporate the condensation from the coil. Unfortunately the engineer started as career a shipping clerk and never received any further training.  There isn't enough heat or running time to evaporate the condensation from the coil.
The solution is fairly simple
A plastic tube  drains water out of the evaporator in the pan. You can extend the tube and add a defrost pan handled by your refrigeration wholesaler. Wire it so it is on whenever there is power to the unit.  This should get rid of the excess water. These pans are also used on some self contained coolers and freezers. They come in either 120 volts or 220 volts. kasgirls@tds.net
Jul 12, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Kenmore refer #70162990 ice maker leaking into storage tray
Please confirm you have given the complete model number.
If the icemaker has a bail wire to control how much ice is in the bin, there is a fill switch inside the front cover of the ice maker which allows you to increase or decrease the amount of fill.
You may also have a cracked or corroded ice mold. Check by filling the icemaker with water manually, and watching to see if it drips once the initial overfill stops dripping. This would also be indicated by the ice cubes being smaller than usual.
Jan 04, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Oasis water cooler taps started dripping
if the cooler is a hot and cold, even if its a cook and cold, the cooler always needs to be cleaned and maintained, not only on the inside but on the outside, as the cooler is used calcium builds up over time. that is why your taps are leaking, there is a build up in the taps, therefor the taps are not sealing properly and letting some water thru. i say take the taps out and clean them with vinegar.
the second thing u can do is the taps do come apart into smaller peices once u disconnect them from the cooler. take the taps apart and find the spring located within it, stretch the spring and than reconnect the peices together than reconnect to the water cooler.
Nov 14, 2008 | Oasis P1AQ
Water Filters & Coolers Logo
Top Water Filters & Coolers Experts
Tom Chichester
Are you a Water Filter and Cooler Expert? Answer questions, earn points and help others
