Question about Building Materials
How do I install a comalco sliding window handle?
How do I install the exterior front door handle?
Take out inner door handle bezel-1 philips screw. Then remove 2 large screws under inner door handle. The lower light lens can then be removed exposing 2 small philips screws. Remove those and take out light assy and unplug. Use a screwdriver to pry gently on window-lock control switch assy. Remove and unplug. Then gently pry inner door panel off. The inner door handle and cables can be moves by sliding plastic assy back and out. Then you can remove the plastic rainliner exposing the door handle assy. 2 10mm bolts hold it in. Theres also to rods to remove by releasing clips and sliding rods out.
Feb 11, 2015 | 2004 Mitsubishi Endeavor
Replace 2006 driver side sonata door lock actuator
REMOVE DOOR PANEL, LOWER WINDOW HALFWAY. BEHIND THE DOOR PANEL IS A METAL PLATE THAT IS THE WINDOW REGULATOR. THERE WILL BE TWO OPEN HOLES. AS U ROLL THE WINDOW DOWN LOOK IN THE HOLES FOR 2 10MM BOLTS. REMOVE THE BOLTS AND SECURE THE WINDOW. REMOVE ALL THE 10MM BOLTS AROUND HE REGULATOR.. LOOK BY THE HANDLE ON INSIDE OF THE DOOR IS A SMALL ROUND BLACK PIECE OF PLASTIC. PULL IT OUT THERE WILL BE A 8MM BOLT REMOVE IT AND SLIDE THE LOCK OUT OF THE DOOR. PULL FORWARD AND HANDLE THEN OUT. REMOVED THE WINDOW REGULATOR. REMOVE THE 3 T30 HEX BOLTS ON THE STRIKER. SLIDE THE ACTUATOR OUT AND INSTALL IN REVERSE ORDER.
Mar 09, 2013 | Hyundai Tiburon Cars & Trucks
Remove a crank car window handle
Get hold of a clean shop towel (one thats not too plush) slide it up in behind the window handle and slide it back and forth (sawing motion) all around the handle until it releases the 'c clip' holding the handle on the door. Caution dont lose the clip!
Jan 24, 2013 | 1994 Oldsmobile Cutlass Ciera
Need to put passenger miror on. i need help to show me how to take the door panel off.
Section 01-05: Trim, Interior 1998 Windstar Workshop Manual REMOVAL AND INSTALLATION Procedure revision date: 01/22/1999 Trim Panel, Door Front
Removal
  1. Remove door latch cover by prying from top edge and pulling trim free of retaining clips and sliding trim away from latch.
  1. Remove portion of armrest containing door lock switch and window regulator control switch (14529) by pulling straight up.
  1. Remove rear view outside mirror mounting hole cover assembly by prying at top and pulling upward to release double-sided clip.
    Trim Panel
    Item Part Number Description 1 23942 Front Door Trim Panel 2 56908-S58 Screw (1 Req'd), Right Door 56906-S58 Screw (1 Req'd), Left Door 3 18B978 Radio Speaker Grille Name Plate 4 56911-S58 Screw (1 Req'd) 5 17D720 Cover Assembly Rear View Outside Mirror Mounting Hole
  1. Remove screw attaching front door trim panel (23942) to front door (20124) under switch plate.
  1. Remove two screws located at bottom of front door trim panel.
  1. Disconnect the door lock switch (14028) and window regulator control switch electrical connectors.
  1. Remove door window regulator handle if equipped by unsnapping and pivoting away the handle cover from base to expose retaining screw. Remove screw from the door window regulator handle.
  1. Pull front door trim panel from the top to release hooks from front door .
  1. Remove front door trim panel.
Installation
  1. Replace any bent or damaged fasteners.
  1. Follow removal procedure in reverse order.
Body Side
Removal
  1. Remove door handle retaining clip by sliding a shop towel between handle and door trim. With tension on the cloth, pull one end of the cloth so it slides between the handle and the door trim. If handle does not come out, reverse direction.
  1. Unfasten 13 christmas tree fasteners using double-acting spring-loaded trim removal tool and pull body side trim panel from body side door.
  1. Remove forward and rearward mating sections from under window trim.
Installation
  1. Replace all christmas tree fasteners.
  1. For installation of handle, install clip to handle, then push handle onto shaft to snap in place.
Back
Removal
  1. Disconnect rear window defroster wires.
  1. Remove the liftgate window garnish moulding as described.
  1. Remove screws attaching liftgate handle to liftgate and liftgate inside trim panel.
  1. Using Rotunda Windshield and Moulding Trim Removal Kit 107-R0401 or equivalent, pry pushpins retaining liftgate trim from the liftgate.
  1. Remove liftgate trim.
Installation
    Liftgate
2010&c18=modelyear&c35=wsm%2ctrim%20panel%2c%20door%2csww%2c01-05%2cremoval%20and%20installation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=405&ct=lan&hp=n&[aqe]
Mar 07, 2011 | 1998 Ford Windstar
Is there any special tools or requirements for removing and installing a new exterior (drivers side) door handle. Please describe the process. Thank you.
nope, just wind the window down, remove screws around the arm rest, pull panel out from door releasing plastic retainers, slide panel up out of window seal, remove plastic door dust shield , wind window up and you will be able to access handle through the inside of door, remove latch rod clip from handle, remove two bolts that screw to handle and thats it. Of course replace in opposite procedure
Jan 22, 2011 | 1999 Chevrolet Silverado 1500
Replace the window regulator on the drivers side
Please don't forget to rate! Thanks!!!
Motor & Regulator
  1. Remove the front or rear carrier assembly.
  2. Slide a hammer handle between the window guide and carrier assembly until the hammer handle end presses on the gears of the carrier assembly.
  3. Unfasten the bolts (1) and remove window regulator.
To install:
NOTE:By removing window regulator motor, gearing shifts, it is not centered
  1. When installing window regulator motor, the gears must be aligned until the window regulator motor is centered again.
  2. Attach and tighten the bolts to 3.5 Nm. The bolts must be tightened to specifications, or damage to plastic sleeve on window regulator motor can result.
  3. Carrier assembly with window regulator, installing:
    • For replacement part carrier assemblies, the gearing is secured in place with a cable tie.
For replacement part carrier assemblies, the gearing is secured in place with a cable tie (1)
  • Slide a hammer handle between window guide and SF so far until hammer handle end presses on gears of SF.
  • Remove the cable tie .
  • By removing window regulator motor, gearing shifts, it is not centered.
  • When installing window regulator motor, gears must be aligned until window regulator motor is centered again.
  • Attach and tighten bolts to 3.5 Nm. The bolts must be tightened to specifications, or damage to plastic sleeve on window regulator motor can result.
  • // // 0) preLoad.src = ctl00_cphLeft_chRepairTreeNav_tvTOC_ImageArray[i]; } ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.lastIndex = 23; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.populateLog = theForm.elements['ctl00_cphLeft_chRepairTreeNav_tvTOC_PopulateLog']; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.treeViewID = 'ctl00$cphLeft$chRepairTreeNav$tvTOC'; ctl00_cphLeft_chRepairTreeNav_tvTOC_Data.name = 'ctl00_cphLeft_chRepairTreeNav_tvTOC_Data'; //]]> var _strTreeScrollHidName = 'ctl00_hidTreeScrollPos';
    Dec 09, 2010 | 2001 Volkswagen Cabrio
    1997 mercury villager passenger side mirror replacement guide. how do i do it? is there an easy access panel or does the whole door panel need to be removed
    door panel must come off.
    go here for villager help
    http://groups.yahoo.com/group/villagerquest/
    Section 01-05: Trim, Interior 1997 Villager Workshop Manual
    REMOVAL AND INSTALLATION Trim Panel(s), Door
    Front
    Removal
    1. Disconnect the battery ground cable (14301) if equipped with power locks or power windows.
    1. svv~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Use care when removing the front door inside handle escutcheon (22620). Failure to do so can result in damage to the component.
      Carefully pry off the front door inside handle escutcheon by inserting a standard 1/4 inch screwdriver between the top rear portion of the front door inside handle escutcheon and the front door trim panel (23942).
    1. If equipped with manual windows, slip a clean shop rag between the window regulator handle (23342) and the front door trim panel.
    1. Pull the shop rag back and forth to release the window regulator handle clip.
    1. Remove the three cover caps and front door trim panel screws.
    1. Remove the one front door trim panel capped screw from the door pull handle.
    1. If equipped with power windows, remove the door pull handle. Disconnect the electrical connectors.
    1. Slide a flat-bladed tool behind each of the retainers and twist the tool to disengage the front door trim panel from the front door (20124).
    1. Remove the front door trim panel.
    Installation
    To install, reverse the removal procedure. Body Side
    Removal
    1. Gently pry loose the body side door latch handle bezel and remove it.
    1. Slide a suitable tool behind each of the retainers and twist the tool to disengage the body side door trim panel from the body side door (24622).
    Installation
    To install, reverse the removal procedure. Door Electrical Connections
    Removal and Installation
    Refer to Section 01-11 for Power Window, Section 01-09 for Power Mirror, or Section 01-14B for Power Locks. Watershield
    Removal
    1. Remove the Front Door Trim Panel . Refer to the removal procedure in this section.
    1. Remove the front door watershield by carefully detaching it from the adhesive.
    Installation
    1. Install the front door watershield in the proper position and press firmly at the adhesive areas. If necessary, use additional adhesive to ensure an adequate seal.
    1. Install the Front Door Trim Panel . Refer to the installation procedure in this section.
    May 22, 2010 | 1998 Mercury Villager
    Inner door panel door removal
    Coupe
    1. Disconnect the negative battery cable.
    2. Remove the screw covers, screws and pushpin, then remove the door pull handle applique.
    3. If equipped, unplug the regulator switch plate electrical connector.
    4. Mark the position of the window regulator handle, then remove the handle using a suitable tool to disengage the regulator handle snapring.
    5. Remove the pushpins from the trim panel.
    6. Slide a flat-bladed tool behind each of the retaining clips and twist to disengage the clips from the door shell.
    7. Remove the trim panel by lifting it up and sliding it rearward to clear the sheet metal.
    Remove the door pull handle applique
    Remove the two-piece pushpins from the trim panel
    To install:
    1. Replace all damaged trim panel retainers.
    2. If removed, install the water shield.
    3. Place the trim panel into position on the door and insert the door handle through the opening.
    4. Attach the door panel fasteners.
    5. Install the pushpins on the trim panel.
    6. Install the regulator handle.
    7. If equipped, attach the regulator switch plate electrical connector.
    8. Install the door pull handle applique cover, the screws, screw covers and the pushpin.
    9. Connect the negative battery cable.
    Oct 11, 2009 | 1998 Ford Escort
    I want to replace the driver's side mirror and need to remove the inside door panel thanks
    here is step by step instruction to remove your door panel. i am not sure if the picture are coming through so please forgive me on the images. please do not forget to rate and comment about your experience today wih fixya Front Door
    1. On vehicles without power windows, place a soft cloth under the window regulator handle and pull upwards on the cloth to release the snapring. Remove the regulator handle and plate.
    89550p12.gif Using a taped prytool, carefully remove the bezel portion of the handle
    89550p14.gif Remove the bezel by pulling towards the tip of the handle
    89550p15.gif Remove any screw covers ...
    89550p16.gif ... and extract any retaining screws from the door panel
    1. Remove the screw from the inside handle and slide the handle forward. Disconnect and remove the handle from the control link.
    2. On manual mirrors, remove the setting screw and knob. Tape the end of a thin flat-bladed tool and pry the retainer loose to remove the cover.
    3. If equipped with power windows, remove the power window switch from the and armrest.
    4. Remove the mounting screws and remove the armrest from the door panel. Remove the inside door handle bezel by pushing rearward.
    89550p18.gif Carefully pry the edge of the door panel around the outer edges, then remove the door panel
    89550p13.gif Once the door panel is removed, make sure to disconnect all wiring
    1. Remove the door courtesy light by pulling outward. Disconnect the electrical wiring.
    2. Remove the two screw caps and speaker cover(s). Remove six screws from the trim panel.
    3. Remove the door pocket from the panel.
    4. Tape the end of a thin bladed tool, then insert the tool between the door panel and door and pry the panel outward. Disconnect the electrical wiring after the panel is free and remove the panel from the vehicle.
    To install:
    1. Connect the electrical wiring, if equipped, and install the trim panel onto the door.
    2. Secure the trim panel with the mounting screws, then install screw caps and speaker cover(s).
    3. Install the door pocket.
    4. Install the armrest and secure with the mounting screws. Install the power window switch as required.
    5. Install the door courtesy lamp. Install the inside handle bezel.
    6. Install the outside rear view mirror cover and retainer.
    7. Connect the inside handle to the control link. Install the handle, slide it rearward and install the screw.
    8. With the door window fully closed, install the window regulator and handle.
    Apr 17, 2009 | 1993 Toyota Camry V6
    How do you repair a gmc sierra 1998 inside door handle
    You have to remove the door panel, if you have roll down windows the handle will have to be removed. After panel is removed you have to drill the one rivet that hols the interior handle. slide the handle down and unfasten the rod retaining clip. Please make sure you do not break the clip. Install the new interior door handle, clip and provided fasteners. Try the door before you install the interior door panel, Note the is a good time to lube the window roller and the door mechanism. Make sure to install the water shield to provide the protecting from the elements. Line all the plastic retaining clips and or replace if they are broken. Good Luck.
    Jul 22, 2008 | GMC Sierra Cars & Trucks
    Building Materials Logo
    479 people viewed this question
    Top Building Materials Experts
    hpgwva
    Tom Chichester
    ray gallant
    Are you a Building Material Expert? Answer questions, earn points and help others
