Where to add oil into tone arm and what type oil to use
    Problem Solver:
  • 10 Answers
You should NOT add any oil if the arm is stiff it may need to be adjusted if anything the bearings maybe dry and that's a grease that is used,I would need more info on the arm.
Posted on Dec 08, 2014
Rock-ola 448 jukebox skipping how to repair
The stylus might be worn or of the wrong type. A simple tone arm needs a round stylus and if an elliptical type (intended for a long S-shaped tone arm) has been fitted by mistake it could skip.
If nothing is wrong there, the remaining conclusion is either the mechanism is maladjusted or the tonearm bearing has a tight spot. In that case the tone arm should be removed and the shaft examined under strong magnification and any irregularities carefully removed, eased, blended in using a very fine abrasive (12,000 - 20,000 grit) and then ensuring the shaft and bearing is thoroughly clean apply a little very light machine oil and reassemble and readjust the playing weight...
Apr 07, 2017 | The Audio Players & Recorders
Adding oil to tone arm - sherwood st903
There is no oil to ever be added to any tonearm. If you're talking about the fluid used to raise or lower the tonearm, that is known as damping fluid, which takes experience to apply correctly, even if you can find the fluid at all. It's obviously not used often anymore, and it's a very specific type and weight. If you need further assistance, or would like to inquire about repairing your unit, please visit my website at audioserviceclinic.com. Thank you.
Dec 04, 2014 | Audio Players & Recorders
Technics turntable manuals
Looking at both the turntable and the "Shure" Premier cartridge it looks like they both have the screw type of fixing that fits to the underside of the Headshell. So I would say yes. But have a look at both of them on the internet before you buy.
PS you have to add "Shure" or "record cartridge" when searching for Premier cartridges otherwise it comes up with printer cartridges.
Jan 24, 2014 | Audio Players & Recorders
How do i add message tones to my samsung galaxy 551
you have to go on the internet and buy some or go on your phone and download them
Nov 30, 2011 | Samsung Galaxy 551 Cell Phone
1210 tone arm won't stay down. When I unscrew the
Check the point where the arm piviots, maybe a screw has come loose. Depending on the type of cartridge it should track at 3 to 4 grams.
Jun 08, 2011 | Technics Audio Players & Recorders
ION iTTUSB turntable has buzzing sound when I record
It sounds like you have a bad ground on the tone arm. It's probably time to replace the tone arm wiring, or the external connecting cables.
Nov 28, 2009 | ION Audio iTTUSB Turntable
Tone arm comes out and touches record, then goes back to cradle
See what kind of arm position sensing elements are used in your turntable (micro switches, optics or possibly other) and check if they work correctly - sometimes a microswitch can be damaged or have oxydized internal contacts or a badly soldered / broken wire and it will not function properly, causing the unit to stop automatically, the same might happen if the sensor is of optical type and there is some dust or broken wires or if the emmiter or sensor is damaged. Also, it could be a problem with the part that activates the switch / optics, it might be displaced or damaged.
If all sensors / switches seem to work well, then check the section which has wires going to those sensors / switches, it's the next probable location of the fault (it might be an electronic controller so there could be damage to some components, broken wires, dirty connectors or bad solder contacts).
It could as well be something else in the mechanisms, wiring or electronics, i just suggested a few things that might cause the malfunction you described.
Hope you can get it fixed.
regards
3rq8 (Triarcuate)
Sep 15, 2009 | Audio Technica AT-PL50 Turntable
SL-1200 MK2 Tone Arm Oxidized and Height Adjust
X1N may I suggest a few drops of mineral oil, the bottlels you find in the local grocer store. Once applied let soak for mabe 2 to 3 hours. Wipe or sponge away oxidation. The soaking may take longer. View the working one very closely to compare to the troubled one. The controls may accepte repositioning to the correct position now. If you got the guts study the assembley and make notes of you disassembley procedure, the problem may just need some realignment internally. I hope this helped.
Sep 16, 2008 | Technics SL-1200 Turntable
Cueing Problems on Technics SL-1300MK2
Usually the damping fluid is to let the tone arm lower slowly, lifting is usually a mechanical link. Read THIS.
Hope that helps...
Geno
Apr 01, 2008 | Audio Players & Recorders
Aiwa LX770 Turntable won't start
It's a bit after Jim's post, however I had what appears to have been the same problem with my LX770 after it had been stored in the loft for quite a few years. I found the problem to be caused by the tone arm mechanisms stalling - The band that was associated with lifting the arm had turned to a black gunge and was not allowing the motor to rotate, also the motor associated with moving the arm backwards and forwards was struggling to turn. I cleaned the tone lifting pulleys and replaced with a small elastic band (for a temporary fix). This was a little fiddly as you have to take off a spring and a couple of gears to get the new band in place. I cleaned the runners and cleaned off the grease on the worm gears associated with the arm tracking (as I suspected it may be more viscus than originally installed), lightly oiled the tone arm tracking gears. It still seamed to take an amount of helping the tracking arm gears until they were able to move freely. With the tone arm mechanisms working properly the whole unit now seams to be working.
Top tips if you attempt this: WARNING - If the unit is plugged in, the transformer and high voltage wires are live regardless of whether the on button is on or off on the front of the record deck. PLEASE do not take any of my comments as recommendation you should ever do anything with the unit plugged in! Remove the little stylus carrier before you start taking the player to pieces - saves damaging it! Remove the record mat and aluminium platter before turning the unit upside down. Manually push the tone arm to about 0.5cm from its furthest travel - so you can remove the tone arm mechanism plate. May be a little stiff as the wires have to slide of the pulleys for the tone arm to be pushed. To access the tone arm mechanisms, remove the main bottom plate (and greasy spring), then undo the screws which hold on the rear undertray. With the decks buttons toward you, you should then be able to lift the rear tray slightly and tilt the tray towards you to expose the tone arm mechanisms. You shouldn't need to remove the circuit board with the control buttons on the front of the unit.
After getting it going, I found that I needed a Phono preamp to get the signal strength necessary to use the deck for transferring vinyl to my PC.
Good luck
Oct 20, 2007 | Audio Players & Recorders
61 people viewed this question
 Grubhead
Grubhead
