Question about Locks & Locksmithing
How do I change the code on a lockwood digital door lock 530
  • 5,346 Answers
First determine the code you want to use; find the tweezers and spare red and blue tumblers if you are going to change the length of your code. The factory-set code is 5 digits. You can only use each key once and the C key cannot be included in your 4-6 digit long code. Next you need to disassemble the lock with the lock kept horizontal during the recoding process. If the lock has been installed, you need to uninstall it from the door. Remove the two mounting screws from the interior face plate. Then separate the exterior section from the spindle connecting it to the interior face plate. If the lock has not been installed or the previous step is done, remove the adapter plate from the back of the digital lock (exterior plate) if it is fitted on the unit. Next remove the four red screws that hold the back plate onto the lock and remove the backplate. Press and hold the C button at the lower left (as viewed from the back where the tumblers are) below the most of the other keys on the faceplate. With the tweezers, remove tumblers and put a red tumbler in the spots corresponding to your new code. Put a blue tumbler in the all of the other spots. Make sure that the color side is up and that the square cutout is facing the side of the lock. (Thus on the right side keys, the square cut faces right and on the left keys, it faces to the left.) When all of the tumblers are in place, release the C button. Test your code and check that it works after replacing the backplate and adapter plate but before putting the lock on the door. Save the tweezers and additional tumblers for future code changes.
The directions for resetting the code on any Lockwood Digital Lock are provided in the service manual here: http://www.lockweb.com.au/Local/AU/Technical%20Downloads/Lockwood/Mechanical%20Digital%20Locks/530%20Digital%20DX/Lockwood%20DX%20Digital%20Service%20Manual.pdf . Other details for the lock installation are available here: http://www.lockweb.com.au/en/site/lockweb/Lockwood-Products/?productId=948353 .
I hope this helps.
Posted on Dec 04, 2014
I have lock our triple security sliding door without looking to the catch. And we can’t open the lock. Not sure of the type . It is a Lockwood triple security lock. Maurice
I know a website that has every info
on all vehicles and vehicle problems (common/basic and technical both), with their solution In detail.. it's www.reliable-store.com
Mar 04, 2018 | Cars & Trucks
I need to remove this lockwood lock from my front door as it has stopped working but can't work out how to remove it
if its still locked and not working , then your in for a real chore !! as these are designed to not be able to just unscrew if there locked up , if its not locked , open door and unscrew frame part from frame (screws held it on frame) then look at bottom of key lock section , see small set screw (use allen key on this ) remove this screw , then using a small pipe wrench (you didn't want to keep it right ?) unscrew the lock section lefty loosey and then with a slight pry with small screwdriver entire front cover will pop off , this exposes the screws into the door , remove them an lock will come off door (leaves big holes in door thought)
May 13, 2016 | Cars & Trucks
After selecting allow speech over locked screen, my nokia lumia 530 is locked please how do I reverse that?
Hard Reset NOKIA Lumia 530 - HardReset.info
www.hardreset.info/devices/nokia/nokia-lumia-530/
Hard Reset NOKIA Lumia 530; In the next step go to Windows Phone Settings. Master Reset NOKIA Lumia 530; Afterwards select About. Wipe data NOKIA ...
nokia lumia - Phone is locked and says I need to wait for ...
windowsphone.stackexchange.com/.../phone-is-locked-and-says-i-need-t...
Sep 9, 2013 - I locked myself out of my phone by entering the wrong password too many times. However, instead of the usual "Try again in 1 minute" ...
How to unlock Nokia Lumia 530 - sim-unlock.net
sim-unlock.net > Unlock Nokia
Your Nokia Lumia 530 is locked to only one network ? You can unlock ... Check how fast You can unlock Nokia Lumia 530 by using our site. We give You full ...
Nokia Lumia 530 - How to unlock security code by hard ...
? 13:44
https://www.youtube.com/watch?v=q8OjYvinAxo
Nov 11, 2014 - Uploaded by phone reset
look i forget my password of my nokia account so i reset mylumia 635 it works? or how i can erase mi nokia ...
Jan 05, 2016 | Nokia Cell Phones
The round metal piece outside the door where the key is inserted to open the door of my Lockwood deadlock is loose, how to tighten it please
go to the inside of the door and tightened the 2 screws from the back that holds the lock in the door.
Jan 12, 2015 | Cars & Trucks
How to open a locked door
Post more information with make, model, year of car etc.
Sep 21, 2014 | Cars & Trucks
Does lockwood and kwikset use the same keys
The popular Kwikset keyway is used by many companies, and will fit into one of Lockwood's keyways. The spacing is a little different, so if you are trying to make locks of both brands work with the same key, double check the width of the cuts while you have the locks apart to make sure the pins you are using will sit on the bottoms of the cuts and not on the slopes of the sides of the cuts.
If you just want to copy a key, then there won't be a problem. Lockwood does have 6 and even 7 pin locks, so make sure your key is the right length.
Oct 28, 2013 | Kwikset Locks & Locksmithing
Change the combination on a DHo74E
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777).
You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Activate user codes
Change code
How can I program my electronic keypad lock when the instructions with the programming code have been lost?The back plate of the keypad side of the lock on the exterior of the door has a sticker which includes the serial number, six digit programming code and two pre-programmed four digit user codes. The lock must be disassembled to a point the exterior of the lock can be pulled away from the door and the information on the sticker made note of.
This link will give you instructions for various models of Schlage locks:
http://consumer.schlage.com/Service-Support/Pages/InstructionandManuals.aspx
There is a video for changing codes on this page!
Nov 29, 2010 | Schlage Camelot Deadbolt Keypad, Satin...
I have a kwikset lever door lock, is there a diagram or manual available for it which shows the inner mechanisim parts?
No. Throw it out and buy something else. Carbine, Lockwood, Brava, even Gainsborough is better than kwikset.
Oct 04, 2009 | Kwikset Locks & Locksmithing
Locks & Locksmithing Logo
307 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Andrew Taylor
Andrew Taylor
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
