Question about Metra 40-cr10 2006 Chevy Monte Carlo Ltz Antenna Cable Audio Radio Stereo
My heater will not heat when its on idol. will get some heat when driving.
I have to keep it on defrost or windshield will fog up
  • 9,771 Answers
Check the coolant level in the radiator. Then check for a stuck open thermostat.
Posted on Dec 05, 2014
When my car turn on start switch...eng running. I don't turn on a/c switch but compressor pully and clutch are running together Is it ok or problems? Car is BMW e90. 323i 2010 year Thank you
Is the heater control in the defrost position? Most cars will automatically turn the air conditioning compressor on when defrost is selected to dehumidify the air being directed on the windshield. This keeps the windshield from fogging up, and helps defog the windshield more quickly if it is already fogged up.
Dec 10, 2016 | BMW 323i Cars & Trucks
Tip
Tips for operating Air conditioning system on Toyota Hilux and someother...
To cool off your Toyota after it has been parked in the hot sun, drive with the windows open for a few minutes. This vents the hot air, allowing the air conditioning to cool the interior more quickly.
Make sure the air intake grilles in front of the windshield are not blocked (by leaves or snow, for example).
On humid, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
Keep the area under the front seats clear to allow air to circulate throughout the vehicle.
On cold days, set the fan speed to high for a minute to help clear the intake ducts of snow or moisture. This can reduce the amount of fogging on the windows.
When driving on dusty roads, close all windows. If dust thrown up b the vehicle is still drawn into the vehicle after closing the windows, it is recommended that the in intake be set to FRESH and the fan speed to any setting except "OFF".
If following another vehicle on a dusty road, or driving in windy and dusty conditions, it is recommended that the air intake be temporarily set to RECIRCULATE, which will close off the outside passage and prevent outside air and dust from entering the vehicle interior.
HEATING
For best results, set controls to;
Fan speed ---- Any setting except "OFF"
Temperature----Towards WARM (red zone)
Air intake ---- FRESH (outside air)
Air flow ---- FLOOR
Air conditioning ---- OFF
For quick heating, select recirculated air for a few minutes. To keep the windows from fogging, select fresh after the vehicle has been warmed.
Press the "A/C" button on for dehumidified heating.
Choose floor/windshield air flow to heat the voltage interior while defrosting or defogging the windshield.
AIR CONDITIONING
Fan speed --- Any setting except 'OFF"
Temperature --- Towards COLD (blue zone)
Air intake --- (outside air)
Air flow --- PANEL
Air conditioning --- ON
For quick cooling, move the air intake selector to recirculate for a few minutes.
VENTILATION
Air flow --- PANEL
DEFOGGING
The inside of the windshield
For best results, set controls to:
Temperature --- Towards WARM (red zone) to heat; COLD (blue zone) to cool
Air intake --- FRESH (outside air)
Air flow --- WINDSHIELD
The outside of the windshield
Air conditioning --- OFF
On humid days, do not blow cold air on the windshield. The windshield could fog up because of the difference in air temperature on the inside and outside of the windshield.
DEFROSTING
To heat the vehicle interior while defrosting the windshield, choose floor/windshield air flow.
on Feb 14, 2011 | Toyota Pickup Cars & Trucks
1998 Nissan sentra ac bypass
Assuming that it is working in frigid conditions, sometimes The
Ac works with the defroster to remove moisture and the fog on the inside windshield. So, turn the defroster of unless you need it when the windshield fogs. You may be able to keep the window clear by opening the outside air vent and increasing the heater temperature.
Feb 13, 2015 | 1998 Nissan Sentra
Heater & defroster works fine but inside car windows keep fogging
So you have the vent settings to blow out of the windshield vents and still have fogging?
You can dry out the air more quickly if you use the air conditioner setting. It sounds backwards, but this is exactly what the manual in my older car said to do. (Some cars are electronic control and won't let you do this however - or they do it automatically with the defrost vent settings).
For the older car, I would set the heat to the hottest setting and press in the a/c button. The a/c dries out the air, but it does not have to be set to run cold.
Another thing that could help is to make sure that you do not have the vents set for "recycling" the air. The picture should look like a u shapped arrow. Make sure it is not pressed in.
Dec 20, 2011 | 1999 Oldsmobile Alero
How do i clean the windshield it is kind of fog
Check your coolant level, if its low it may indicate a heater core leak into the vehicle interior. It will severely fog up the windshield and seem like an oily deposit on the glass. If good just keep the heater on defrost to the windshield or blend to defrost and heater.
Feb 02, 2011 | 1995 Honda Civic
Why my window is fogging whe i turn the heater ?? i recently bought my toyota carina 3 model 1994 but the window is fogging , what should i do?
Make sure the vent system is set to draw air from outside. If it is set to recirculate the same air that's inside the vehicle without drawing fresh air from outside, the resulting humidity that builds up inside the vehicle can fog the windows even when you run the defrost. You can also try opening the windows a bit to get some more air moving inside.
If it still fogs when the vents are set properly, you may have a leaky heater core. The heater core is a small radiator that is located under the dash that the heater system blows air through to heat the inside of your car and provide heat to defrost the windshield. The fog may be coming from the heater core leaking hot coolant steam that's being circulated through the defrost system. If this is so, you will need to replace the heater core.
Jan 07, 2011 | 1997 Toyota Corolla
Window fogs up after driving for awile. Just
The mildew smell you refer to could be anti-freeze. When a heater core starts leaking it may allow anti-freeze (which circulates through it for heat) to be blown through the ducts onto the windshield in defrost mode. The repair is to have the heater core replaced. It may wait for the thermostat to open and allow the coolant to circulate before you notice it. Occasionally the carpet on the passenger side may be wet from leakage.
Dec 12, 2009 | 2001 Chrysler 300M
When we turn on the heat, the windshield fogs terribly, and "for good" making it nearly impossible to clear it up again. ONLY the AC keeps the windshield from fogging - even in the Winter! can't tell you...
Thats normal, when the defrost button it pushed, the a/c compressor is on, and you can adjust the temp of the air. With the a/c is on, it takes the moisture out of the air. So, after the engine is warm, you can get warm dry air to defog the windows.
Nov 05, 2009 | 1997 Honda Civic
Heater works but defrost fills inside with fog.
your heater core has probably sprung a leak.does the fog smell kinda sweet?....check the floor in the front where the floor mats are for moisture or even puddles of antifreeze.(the replacement of a heater core can be very expensive as the entire dash usually needs to be removed to access the heater core)also look under the engine near the firewall for antifreeze drips.
Dec 13, 2008 | 1998 Dodge Caravan
When i run the heat or air cond. i smell water and windshield fogs up in the middle.
Sounds like your heater core is bad. Have someone check out the heating system and possibly replace heater core.. that should take care of the fog problem also by enabling you to use the defrost... Good Luck!
Oct 26, 2008 | 1999 Jeep Grand Cherokee
Metra 40-cr10 2006 Chevy Monte Carlo Ltz Antenna Cable Audio Radio Stereo Logo
54 people viewed this question
Top Metra Car Audio & Video Experts
xxxxxx xxx
Are you a Metra Car Audio and Video Expert? Answer questions, earn points and help others
