One or two relationship between latitude and angle
    Novelist:
  • 167 Answers
Both are fixed to travel in a set direction and will continue in that direction throughout infinity.
Col. Dana Gillespie
Posted on Dec 04, 2014
Are my Mickey Thompson Baja ATZ P3 tyres likely to cause poor fuel economy (14L/100km)in my 2015 BT50 Freestyle cab ute or is there a more fundamental problem?
I am not familiar with either the tyres or your vehicle.
Some tyres do have a greater rolling resistance and cause the vehicle to use a little more fuel. Suspension and steering misalignment wastes a great deal more fuel as does a binding brake or incorrect tyre pressures - some tyres need a great deal more pressure than those recommended for standard fitments.
A small amount of additional toe-in or toe-out can waste a deal of fuel due to the fact the vehicle is effectively pushing the tyre sideways several feet each mile and the more grippy a tyre is the more effort is needed to push it sideways.
It is worth knowing the stock toe-in or toe-out figure applies only when the camber angles are correct. The toe figure has a direct relationship to the camber angle and when the camber angles are unequal no toe figure will be correct.
Oct 10, 2017 | Cars & Trucks
Dwell angle to point gap relationship
The tighter the gap, the longer the dwell. Specific relationship depends on number of cylinders/spark plugs and manufacturer.
Mar 26, 2017 | Cars & Trucks
The meaning ofthe prefix in the word relationship
Word Origin and History for Relationship
1640s, "sense or state of being related," from relation + -ship. Specifically of romantic relationships by 1944.
Relationship in Medicine
relationship re·la·tion·ship (r?-l?'sh?n-sh?p')
  • The condition or fact of being related; connection or association.
  • Connection by blood or marriage; kinship.
Mar 15, 2017 | Homework
What is the dwell angle on a 3f engine if point gap is 18 thou
dwell angle is the no of degrees rotation between points closed and points open and for example on a 4 cylinder engine ( 4 lobes =90 degrees the dwell would be around 45 degrees available
there is an adverse relationship between point gap and dwell angle
the closer the points the bigger the dwell and conversely the bigger the gap the smaller the dwell angle
in a distributor the point gap of 18 would have a large dwell angle and that affects ignition timing
in your workshop manual there will be a dwell angle specification and if you set the points at .020 " that will put you close to the dwell angle specification
from there you adjust the gap to obtain the dwell setting
after yo have the dwell set , adjust the ignition timing
there is plenty of information on dwell angle, /point gap if you type in ---dwell angle to point gap relationship--
Aug 16, 2016 | Cars & Trucks
Relationship
A relationship is the way people/ countries act/interact together and how they communicate no matter what relationship they are in
We cant exist without them as if nothing else there is a relationship with one self that might be love or hate relationship-
Rleationships and communications are part of my life
Aug 22, 2011 | Computers & Internet
Can u plz mail me tha easiest way to use Ms Access, like Creating relationship, with the table, creating form, query etc.
In general you initiate this process by pressing the "Relationships" button on the MS Access toolbar. It is the button with three small boxes arranged in a triangle shape.
When it first comes up it will give you the option to add tables. You can add any set of tables including the possibility of adding one table more than once (you would do this if you wanted to create a relationship between fields in the same table).
Once you see the tables you're interested in, you simply drag the field from one table over a field in another table. The fields should be those that will define the relationship. Once done, you should see an Edit Relationships window. You can get back to the Edit Relationships window later by double clicking the line in the relationships window.
MS Access does a good job of figuring out the relationship type. For example, if you match a field in one table, that is not a key, with a primary key in another table, Access will make this a Many-to-One relationship.
This can become a very deep subject. Hope this at least gets you in the right direction.
Dec 18, 2010 | Microsoft Computers & Internet
I WANT TO CONVERT DEGREES INTO FT/LB TORQUE AS MY ELECTRONIC ANGLE TORQUE TOOL CANT GET INTO SOME TIGHT SPOTS SO WAS GOING TO USE TORQUE WRENCH.
I don't think that can be done because a torque wrench measures torque, or tightness. A torque angle gauge only measures the amount of degrees that the bolt is turned in relationship to 360 degrees. Auto Zone has a small torque angle gauge that may work in a tight spot.
Apr 27, 2010 | 2006 Chevrolet Silverado 2500HD 2WD
Where is secant button on TI84?
There isn't one; it requires two keys. Use the relationship sec(x) = 1/cos(x).
After calculating the cosine of the angle, press the x^(-1) key (leftmost column, just below MATH).
Feb 21, 2010 | Texas Instruments TI-84 Plus Calculator
Why is my Dell Latitude D620 laptop screen turning white?
You'll have to live with it. It's taken damage, it's not repairable, it's only replaceable. My Latitude screen was replaced after only 2 1/2 years.
Nov 02, 2009 | Dell Latitude D620 Notebook
HP35s extracting P to R anwsers and place in memory
Given a complex number, ARG (yellow-shift i) will give you the angle in the current angular mode, while ABS (blue-shift +/-) will give you the magnitude.
To extract the real and imaginary components, you'll have to use the relationships
x = r cos(a) and y = r sin(a).
Feb 14, 2009 | HP 35s Scientific Calculator
Computers & Internet Logo
50 people viewed this question
David Payne
David Payne
