Question about Primera Technology LX900 InkJet Label Printer
Primera lx900 does not detect label stock and feed button doesn't feed at all either.
I've tried turning it off and on, but maybe the label stock is too thin? It is 1.625" wide..
  • ivonne g
    ivonne g Dec 04, 2014
    Although printer DOES detect and feed larger width labels, the width of 1.625" shouldn't be the problem, since minimum width size for the LX900 is 1.5"
    Scholar:
  • 51 Answers
There is an sensor position adjustment, from where you can adjust the position of the sensor that detects the gaps between labels. If the labels are thin, you will need to adjust the sensor, so that to be under the label. The minimum label width that you can use is 0.75" (19mm). Check the picture below:
Primera lx900 does not detect label stock and feed - 25306316-nzz1tlas2cpqmreraogzlv2p-4-0.png
Posted on Jan 30, 2015
Refill lx 900 ink
there are reset chips for the lx900 now... just google "reset chip lx900" or this site has them lx900 reset chip ... we use them with success.
Aug 02, 2012 | Primera Technology LX900 InkJet Label...
Does anyone know how to reset ink levels on the Primera LX900 Inject printer?
Yes!!! Finally we have a reset chip for the LX900... just google LX900 Reset Chip and you'll be on your way...
Mar 29, 2012 | Primera Technology LX900 InkJet Label...
Reset Primera LX900 ink level
there are now reset chips for the Lx900... just google LX900 Reset Chip and you'll be on your way...
Mar 29, 2012 | Primera Technology Primera BravoPro...
Out of stock
Morrisettepa: This error occur when the labels are not detected, 1. the label is out of sensor, 2. the label sensor is dirty or blocked. Clean it, adjust in correct position and perform a sensor calibration. Press and hold FEED button by 5-6 seconds and release it. In display you can see CALIBRATION SUCCESS, if not, then repeat the quick calibration.
Sep 15, 2011 | Datamax DMX-I-4208 Label Printer
On the Zebra it was printing 4x13 labels without a problem. However when I tried to print a 4x6 label it still thought there was 4x13 stock in the printer. I played around with the label format size, even...
I think this is more related to the calibration of the label each time you change the new label size. I use ZM400 and your printer should also have the same setting. Under setting, put the When Head Close setting to Calibration. This will let the calibration perform automatically when ever you load a new label size and close the print head. Well 2 label will be lost every time.
Aug 31, 2011 | Zebra 105SL Thermal Label Printer
I'm using my LP-2844 in conjunction with Label Matrix software and I've run into a snag with my printer. When switching between jobs, I went from one label size to another (something i've done...
The problem with this type of printer is that you need to callibrate the size of the label in fact the Length. If you change the length then the printer may stop printing correctly ans stalls.
From your driver try to do a calibration of sensors with your labels and this sould work with this model.
Other manufacturers handle the varying length dynamically.
Jul 13, 2011 | Zebra LP 2844 Thermal Printer
Dear Sir, Madam, We recently installed our Zebra S600 labelprinter together with the Zebra Designer software. But the labelprinter doesn't print out our labels. We've searched the internet and...
It sounds as though it is printing test labels. Switch of and on again to reset.
If no change then try factory reset.
If it is ever necessary to return the printer configuration to factory default values, press the FEED
key and PAUSE Key at the same time while turning the power on. The default values will remain
active until the printer power is turned off. To save the default values in memory, press the MODE
key four times. The Darken, Position, and Calibrate LEDs will cycle on and then off indicating the
values have been saved.
If this does not work then you have a fualty logic board which write off the printer
Jul 06, 2011 | Zebra Stripe S600 Thermal Label Printer
My Dymo Labelwriter 450 turbo feeds out 4 labels each time I print one. The print setting is on one label. The first one prints and the next three are blank. If I try to use the reverse button the printer...
Multiple label feeding usually occurs because the sides of the spool holding the roll are not squeezed tightly together. Make sure there's no gap between the labels and the sides of the spool. If this doesn't help. take out the labels and blow a blast of air into the feed slot. There is a sensor inside the slot on the left that detects the hole in the labels, and maybe it is blocked.
Jan 26, 2011 | Dymo LabelWriter 400 Thermal Printer
Primera Technology LX900 InkJet Label Printer Logo
121 people viewed this question
Top Primera Technology Office Equipment & Supplies Experts
Josh Whitehead
Josh Whitehead
Don  Farrell
Don Farrell
Guy Loeffler
Guy Loeffler
Level 1 Expert
Are you a Primera Technology Office Equipment and Supply Expert? Answer questions, earn points and help others
