Question about Samsung PN42A450 Plasma TV
Issue with volume control on both remote and TV. Also I have to hit the power button many times to cut it off. Any ideas?
    Top Expert:
  • Samsung Master
  • 74,185 Answers
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Posted on Dec 04, 2014
I need to program my telus remote to turn my 46"
Press and hold TV, then OK at the same time. Let go of TV and OK, top buttons should quickly blink red then stop press the code 1019 then hit the bottom right button marked ENTER or OPTIONS
Remote should now work with tv.
To control volume and power at the same time... Press and hold STB and OK at the same time, let go, red blinking up top enter the code 977 STB should blink red a few times.
Hit STB, see if TV volume adjusts Hit POWER. see if both STB (Set Top Box) turns off and TV turns off.
All should be good.
If both TV and STB do not turn on/off, repeat the process for the code where you enter 977
Jan 29, 2011 | Samsung LN-T4661F 46 in. LCD HDTV
As I program my control of dish to a tv sanyo
Hi maria_pal371, I would need to get a better idea of what model remote you have. I would recommend viewing our remote codes found here:
http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/Remote_Codes_Web_Page.pdf
The model # is on the back of the remote at the top, once you have the code(s) you can follow these steps to program the remote:
1. Hold the gray TV button until all lights on top turn on.
2. Let go and while TV is blinking enter the 3-digit code you found and press #.
3. TV should blink a few times and stop. Try volume/power/mute.
4. If everything works hit SAT and you're good to go! If not repeat steps 1-3 with a different code.
Tommy Faust
DISH Network
Sep 17, 2010 | DISH Network IR Remote Control
Can not control the volume on an rca
Ok to reprogram the remote and this only works if you just use the remote for the tv and the receiver. Like i was saying to reprogram the remote hold the tv button till all the top lights flash, then push the red power button, then hit the up arrow button slowly til the tv cuts off, once it cuts off hit the pound (#) button. The top lights should blink three times, that should reprogram the remote, If it is a tv/vcr combo or a tv/dvd combo then there isnt a code for it. Also there is a series of years that the rca tv's wont take a full code and u can just control the power and the tv channel
Sep 05, 2010 | DISH Network IR Remote Control
Volume control not working
Most of the time one of the switches under the control buttons are bad on the control panel of the TV.
Jul 05, 2009 | Sony BRAVIA KDL-46XBR2 46 in. LCD HDTV
My Dish Network Remote will not allow me to...
go to page 19 of your manual (for the E-Z remote) or here "http://www.dishnetwork.com/downloads/pdf/user_guides_and_manuals/remotes/EZ_Remote_Manual.pdf"
(if you don't have the manual)
or to here "http://www.dishnetwork.com/support/documents/receivers/default.aspx" if you have a different remote.
basically, turn your TV on, then you press the antenna button for about 5 seconds until the TV button lights, then use the channel up/down buttons to find the code (the TV will turn off when you find it) hit the TV button again to turn it back on, then hit mute to set the code! good luck!
Feb 17, 2009 | DISH Network IR Remote Control
URC 3220 REMOTE
just try to program the remote by hitting code search on the remote and then continuously hit the power button until the tv turns off and then cut it back on and the tv should be programmed, good luck! make sure that you press and hold the code search button until the light comes on and then the power button.
Feb 01, 2009 | One For All URC4110 Remote Control
Sanyo DS32224 tv remote
It sounds as if you have inadvertently selected the 'Aux' function. Pressing the 'TV' button (should be close to the Aux and others) should restore full control.
Since the volume generally means 'TV Volume,' this function often stays effective but the other controls will not respond, including 'Power.'
This happens to us all the time with our Dish remote which also has 4 basic functions.
Apr 26, 2008 | Sanyo DS32224 TV
Mitsubishi remote and control panel issue
Did you ever resolve this problem and if you did, what was the fix? My same tv just got out of warranty and I have the same problem. Thanks.
Nov 22, 2007 | Mitsubishi WS-55813 55" Rear Projection...
Volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Dec 01, 2006 | iLO 2600 Television
Samsung PN42A450 Plasma TV Logo
41 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
