Question about Miscellaneous
How do i convert 7 inches to a decimal - Miscellaneous
    Problem Solver:
  • 11 Answers
7 equals 0.583 decimal of a foot
Posted on Dec 04, 2014
How do I convert 35mm into standard inches?
I only know standard inches - are there some other kind ?
35mm is the metric equivalent of 1.3779527 inches, to seven decimal places.
Dec 29, 2016 | Photography
Converting 84mmby 90mm = what and 60mm by 65mm = what
If you want the conversion in inches (to two decimal places) it would be:
84 x 90mm = 3.30 x 3.54 inches.
60 x 65mm = 2.36 x 2.55 inches.
If you need to convert to different unit of measurement the following website provides virtually every type of measure you could probably ever need.
Online Conversion Common Length Conversions
Feb 28, 2015 | Cars & Trucks
How to convert fractions to decimals using ti-84 silver plus?
Divide. For example, to convert 2/7 to decimals, press 2 / 7 ENTER .
Dec 06, 2012 | Texas Instruments TI84PLUS Slvr Viewscreen...
Convert .714285 to the fraction 5/7?
Say you have a repeating decimal number 0.714285 714285 714285 etc. You identify the period (the repeating part) and in this case it is 714285.
Y
ou count the number of decimal places in the period: here it is 6. Your equivalent fraction is
Fraction= period/(99...9) where the number of 9's in the denominator is equal to the number of decimal places in the period. For this case, that is 6.
Thus
0.714285 714285 714285 etc.= 714285 / 999999
Reduce the fraction and you will find 5/7
This technique works for a repeating decimal number where the period starts just after the decimal mark.
If the periodic part does not start right after the decimal mark there are modifications to be made.
Jan 16, 2011 | Office Equipment & Supplies
Can this convert decimal measurements to fractions of an inch
Enters a proper or improper fraction,
b?c (b { 6 digits, c { 3 digits). When
possible, improper fractions are
displayed as mixed numbers.
3 F 4 3?4
8 3 J 21?4
Single-variable functions display
decimal results.
1 F 2 0 0.25
a F b F c Enters the mixed fraction a b?c.
(a, b, c { 3 digits each, with the total
digits { 8).
6 F 4 F 6 64?6
J 62?3
"s Toggles display between a mixed
number and an improper fraction.
30 F 4 30?4
"s 71?2
"s 15?2
"s 71?2
"y Toggles display between fraction and
decimal.
55 F 24 55?24
"y 2.291666667
"y 27?24
If a result would overflow or if fixed decimal is 0, no
fraction to decimal conversion occurs. It is not an error.
Denominator must be a whole number {999.
Nov 28, 2010 | Texas Instruments TI-30XA Calculator
How do I get the calculator to show a DECIMAL answer? you know when I divide 100/7 I should get 14.28- NOT 11/7
To convert a single result to decimal, press S--D. to have all results come out in decimal, press SHIFT MODE 2 to switch to the LineIO mode.
Nov 23, 2010 | Casio FX-115ES Scientific Calculator
Where is the fraction button on the ti 83 plus cac. look like
There is no fraction button. Any division of two integers you do is represented as a decimal number. If you want your fraction to remain a fraction you enter it as follows
7[ / ] 19 [ MATH][1:ToFrac] [=] displays 7/19
If you want to convert a decimal number into a proper fraction press [MATH][1:ToFrac] .
Exemple 7/19 [ENTER] gives .36842105. If without doing anything else, you press [MATH][1:ToFrac] you recover 7/19.
There are limitations related to the number of decimal digits in the floating point number.
.3684 [MATH][1:ToFrac][=] gives 921/2500 but
.36842 [MATH][1:ToFrac][=] gives .36842 : it is not converted to fraction.
Hope it helps
Sep 16, 2009 | Texas Instruments TI-83 Plus Calculator
How to do binary,hex BCD and decimal on casio classpad 330
to convert between bases, go to keyboard, then cat(alog) and press B to scroll down to baseConvert(
syntax: baseConvert(value to change, original base, new base)
e.g. to convert 1100 from binary to decimal
baseConvert(1100,2,10)
Sep 14, 2009 | Casio ClassPad 300 Calculator
Converting decimals to degrees on a casio fx-83es calcualtor
if you mean degrees like the degree/minute/second thing: lets say you have 24.12 there is a button that has a dot, and 3 commas (it's located next to the negative button) that will convert that number to degrees. input your decimal, press the equal sign, and then press that degree button and it will convert 24.12 to degrees, minutes, and seconds. the solution is 24 degrees, 7 minutes, and 12 seconds.
Jan 11, 2009 | Casio FX-115ES Scientific Calculator
Miscellaneous Logo
65 people viewed this question
Top Miscellaneous Experts
steve cannon
Level 1 Expert
bill tarkulich
Level 1 Expert
William Miller
William Miller
Are you a Miscellaneous Expert? Answer questions, earn points and help others
