Question about Craftsman Sears Edger Manual Model 316.772370
The new belt keep coming off the track. Before that new belt it ran wonderful.
Tried reinstalling the belt several times. What else can I do?
  • Brad Brown Dec 04, 2014
    Hi myra dufrene, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? What device is this on?
    Problem Solver:
  • 19 Answers
It's possible you have a belt retainer (Cub Cadet Part # 787-01502) either missing, damaged or misaligned. See: http://www.partstree.com/parts/?lc=mtd&mn=25A-515-799+%28316.772370%29&dn=769035510002
Otherwise you may have an incorrect belt - Again, see the link above and double check you belt number.
Best of Luck
Posted on Dec 10, 2014
Belt keeps coming off
Check th eidler pulley for the belt and make sure the belt is runnin in across all the pulleys in a straight line.
Jun 12, 2013 | 2000 Chrysler 300M
Replacing the drive belt Nordictrack 2900
basically you will be just about to take your treadmill, almost totally apart. But the are not many nuts and bolts to solving your problem, first Lay treadmill on its side and locate the rear roller bolts, on mine their are 2, most tread mills are all the same, remove them 2 bolts, Now locate the front roller bolt, 1 bolt,remove bolt, your belt is going to be very loose now, on the side that you would be walking on, Is a board, 6 phillips head screws, Hold the board to the metal frame, remove them, remove the board, then go back to the rear roller, And remove the plastic end caps that hold the rear roller too the metal frame, by gently tapping them off, remove old belt from rear roller, Now go to front roller, and remove belt from front roller, and its time to Install new Belt, AND AJUST NEW BELT, Put belt on front roller and reinstall roller, put plastic end caps back on frame, and then reinstall rear roller threw the belt and reconnect to the plastic end caps on the rear of the frame, Now reinstall the board with 6 phillip screws, to the metal frame, Now turn treadmill upright again, Its time to AJUST YOUR NEW BELT 1st Center your New Belt, Then tighten rear roller bolts, ( Pay Attention ) Count even amount of turns for both Rear roller bolts, Then Ajust front roller Alignment, Their is only 1 bolt on most treadmills, So if your belt is pulling to one side when you turn the treadmill on,it means you still have to ajust the front roller ajustment screw, What I Do Is , I USE A small leveling tool, For the front roller ajustment, It KEEPS the pitch EVEN on both sides of the front roller, and this is HOW YOU REPLACE YOUR BELT AND AJUST THE NEW BELT, and save your self some money, enjoy, in you need to contact me, kjosr@cox.net
Oct 24, 2010 | Nordic Track /proform Treadmill...
WB-37 tracking
Has the "crowning " on the drive roller been worn away . That is the slight barrel shape of the roller . It is that which keeps the belt tracking so I would look at that first.
als try the tension as any trace of belt slip will cause the belt to de track.
Jun 01, 2010 | Powermatic WB-37 37" Wide Belt Sander...
Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Apr 05, 2010 | Nordic Track NordicTrack Treadmill, A2550
New feed belt will not track evenly. Belt is loose on left side & tight on right, but if I tighten the left side to pull it flat, it tracks off to the right immediately. I tried reversing the belt in...
Could be the belt, sometimes they get glued together wrong and they don't track, or its the tension wheel/ track wheel.
It looks like one of the stationary rollers might have a small adjustment
that you can do, hard to tell looking at the diagram,
but if you can adjust this tighter on the right side it should track the belt back to the left, so check and see if any of the rollers or holder of the rollers can be loosened and moved a hair to get the track to the left so the adjust track can make it track straight.
If you still have the old belt, put it on, if it works then there is a problem with the new one and it is not the machine.
Feb 12, 2010 | Delta 31 - 255X X5 18'' x 36'' Drum Sander
Windtunnel belt
I've successfully used a compatible belt - Royal 104425001 .It's still new, but for the time being at least - it works.
Jul 29, 2009 | Hoover S3765-040 WindTunnel Bagless...
Tool Shop Belt sander - can't align belt tracks to thee inside
The problem is that you have not set the adjustment properly. Back off the adjustment screws,slide on the belt and center it over both rollers, addust a little at a time both screws, after belt begins to tighten up stop adjusting. Turn the power switch on for about 1 second. Is the belt tracking? Adjust as necessary. Try the power again for longer and longer periods untill belt tracks in the center of the rollers. Tighten nuts to keep adjustment screws from backing out.
Jun 12, 2009 | Tools & Hardware - Others
New timing belt keeps getting loose when it cools down
yes you can get defective auto tenioners.Chage ASAP.
May 30, 2009 | 1992 Mitsubishi 3000GT
Belt Keeps slipping off shaft
If this is a new belt that keeps coming off, then if not catching something in the roller like a scatter rug, etc then the belt isn't tracking true. The pulley may have come loose for one thing, something has to be off to have the belt come off. Does it come off almost right away, or after some uasge?
Sep 27, 2008 | Hoover U6434-900 Bagged Upright Vacuum
Craftsman Sears Edger Manual Model 316.772370 Logo
122 people viewed this question
Top Craftsman Garden Experts
Dean Gruber
Roland W VanLue
Roland W VanLue
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
