I need a power supply or a schematic for a signalreach cr100 cell phone amplifier.
Need a power supply or pin out voltages or schematic for a signalreach cr 100.
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Posted on Dec 04, 2014
Carlsbro Bass Reactor 400 bass amp - power section dead
• Could be drive transistor , output transistor or both on the main amp.
But check for power supply and in the preamps also.
• A signal tracer will come in handy when troubleshooting these kind
of symptoms.
• Measure supply voltages,
• Check offset voltage
• Check idling current
Isolate , and trace afterwards.
• Schematic is really needed when there are burnt and unrecognizable
component. But one can use similar schematics to analyze circuit
problem.
Aug 01, 2012 | Audio Players & Recorders
Power supply output for Yamaha p4500 secondary output for the power supply so that i could check the voltage
Hi Joel, although we've sourced detailed schematic for this P4500 amplifier, there are no many voltage details on it for manufactures sake. Anyway, mine findings are. Secondary winding on main transformer should supply no less than 2 x 75 volts which makes after rectifying and filtration no less than 2 x 90 volts on capacitors with amplifier without input signal. Also transformer has to be very "hard" , otherwise amp will start clipping before reaching stated wattage on output.
Oct 17, 2011 | Yamaha P4500 Power Amplifier 2-Channel
When then amplified is turned on, it generates a humming static noise. it plays music, along with that humming noise. would it be possible for us to receive the schematics of this model at...
What amplifier is this? Humming noise is normally caused by video cables in audio ports, high voltage wires too close to audio wires, or ground loops.
Feb 25, 2011 | Audio Players & Recorders
Carver power amplifier Pm1.5, 110 acv accidentally plug in to 220
magnetic field supplies are different than conventional types, check that the thyristor is working properly
Feb 23, 2010 | Audio Players & Recorders
Hello, I have a pyramid power supply(PS-52KX), that recently started with a overvoltage problem. I run a Galaxy DX94 HP 10 meter transceiver, and just recently, when I key up the radio, the...
I'm not sure what you mean by 'wide open voltage'. If it's over 17v, the supply may have multiple problems. I don't have the 52kx schematic but other Pyramid supplies have over-voltage protection. There is an SCR that is triggered when the voltage gets to ~17v. This should clamp the output and trigger a shutdown. You should check the 16v Zener diode and the SCR. If the SCR or the Zener is defective, that would prevent the over-voltage from clamping the voltage. Also confirm that the SCR has a solid connection to the ground terminal of the supply. If it's open, that could prevent the clamp from shutting down the supply.
If the voltage is going high, measure the DC voltage from pin 4 to pin 5 of the LM723. It should remain the same at all times. Also measure the voltage from pin 5 to the ground terminal of the supply. That should also remain constant at all times.
Aug 20, 2008 | Pyramid - PS21KX 20 Amp Power Supply Car...
Pryamid ps36k power supply
Have you done any troubleshooting at this point?
Are you going to try to repair this yourself?
Have you tried to locate a schematic for the supply?
Mar 11, 2008 | Pyramid - PS21KX 20 Amp Power Supply Car...
Need information
Try http://www.servicemanuals.net/
They are not free, but the amplifier service manuals I have purchased through the site have been very good.
Jan 02, 2008 | Audio Players & Recorders
PS36K power supply overload problem
Most of Pyramid's supplies are based on the LM723 voltage regulator. The DATASHEET should tell you most of what you'll need to know to repair it. THIS is the schematic diagram.
If the output voltage drives the voltmeter to the end of the scale, it likely has one or more shorted power transistors.
Dec 21, 2007 | Pyramid - PS21KX 20 Amp Power Supply Car...
Soundstream ribcom500
You can get the schematic from SoundStream. If you get the schematic and need help, email it to me at:
babin_perry@yahoo.com
If the amplifier does nothing, post the DC voltage on each of the pins of the SG3525 (or whatever IC they're using in the supply). Use this as a template:
Pin 1:
Pin 2:
Pin 3:
Pin 4:
Pin 5:
Pin 6:
Pin 7:
Pin 8:
Pin 9:
Pin 10:
Pin 11:
Pin 12:
Pin 13:
Pin 14:
Pin 15:
Pin 16:
Nov 07, 2007 | Soundstream Davinici Car Audio Amplifier
Amp randomly comes on and off
You may have an intermittent power problem. You will need a schematic and a multimeter to the the power supply voltages in the amplifier.
Sep 07, 2007 | MA Audio M1889I Car Audio Amplifier
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
