Question about Whirlpool Washing Machines
What size is my Whirlpool washer Mod.LSQ9010KQ0 Ser. CM2553866?
  • 409 Answers
SOURCE: My washer will stop after
hi there,
are there any error codes that come up on the display?
Posted on Sep 26, 2008
  • 409 Answers
SOURCE: grinding noise when washer starts
hi there,
the grinding noise may be coming from either the pump or you have something caught between the drums.
the f-33 error is the pump drive system error. it indicates that you have lost communication between the CCU board and the pump. the CCU board is the main control board that you see in the front of your washer.
i would recommend that you call a technician to check it out, as you will have to do some checks that require technical knowledge.
Posted on Oct 11, 2008
  • 136 Answers
SOURCE: does not spin or empty
it might be jammed or there might be dirt or some sort of a clog. I would suggest you clean it out.
Posted on May 29, 2009
SOURCE: we have a kenmore elite washer mod. 970-c40062-00
Your Stainless Steel drum is supported inside of the washer tub by a spider assembly. The assemply, which is made of cast aluminum, has corroded (steel and aluminum and detegent don't mix) and the spider assembly has broken. The drum has likely wobbled enough to wear a hole through the tub. You need to replace the drum and spider assembly, and tub.
Posted on Mar 24, 2010
jsrock516
  • 5911 Answers
SOURCE: Will not drain and proceed through rinse cycle
The most common cause of the problem you are experiencing is a lid switch malfunction. Symptoms may include, filling and stopping on the intial fill cycle, a wash tub that will not drain, and stopping right after the wash cycle and not advancing to rinse or spin cycles.
The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r3557193-replacing_a_lid_switch
On some models, the lid switch is located under the top casing by one of the lid hinges. You will know if you if you have this type of switch, because It does not have a lid strike and the small hole on the right hand side of the wash tub will not be present. This switch is actuated (toggled) by a rod on the lid hinge. With this type of switch, if you locate it and it can be toggled by hand, you may only need to adjust the actuator by bending it slightly.
NOTE: You do not have to drain or bail the water from the washer tub to perform this repair. Once a defective lid switch is replaced, the washer should drain normally.
A replacement lid switch (if required) can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The average price is about $20 - $30 if you perform the repair yourself. Prices differ between sites so shop and compare. If the model number you posted this question under is correct, the part number for a replacement switch is 3949247.
If you have questions, or need additional assistance, please post back and let me know. The lid switch is a very simple repair that you can easily perform without the assistance of a repairman.
If you would like to purchase a Repair Manual to assist you with all your repairs, repairclinic.com has one that you can order on line for about $20. The part number is 1170635. Searspartsdirect.com also has a repair manual for about the same price. Part number 4314044L. I hope this information is helpful.
Posted on Apr 25, 2010
Can you guide me where can I find the right part number for Relay overload starter for my Whirlpool Gold Side-by-side fridge.Mod: GD5YHEXLS01 Ser: SP2325250 MFR DATE:06-03 I am not 100% sure if I rea
Go to sears parts direct web site and put in the model number. Found the page with unit parts our the page that list the compressor. It will have the newest part number
Feb 03, 2013 | Refrigerators
How old is my whirlpool washer mod-lsq8243hq0, ser-cj2671399
10-12 years old.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Apr 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Does not spin or empty
May 29, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Grinding noise when washer starts some spin cycles, washer stoped and game my wife a f-33 reading. whirlpool told me to unplug(reset) the washer for 30 mins. i did this and the washer still has the...
hi there,
Oct 11, 2008 | Whirlpool Washing Machines
Washing Machines Logo
29 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
