Question about Crl Automotive Vehicle Parts & Accessories
I have a 2000 gmc sierra with a 5.3 l engine ,it idles and starts fine , but will not go past 1500 rpm when driving ,and it surges if you try to floor it . low speeds are ok
  • sonny stanton
    sonny stanton Jan 15, 2015
    my truck is the same year , and did the same thing . after doing many things , it ended up being fuel pump . with a pressure guage hooked up , it showed 55 p.s.i. at idle which it is supposed to have , but as i slowly increased throttle , i could see the pressure drop to almost nothing at 60%throttle ,then back to normal at idle
  • 50 Answers
1. Go to an auto parts store, see if the engine has any OBD II trouble codes. Fix as required.
2. My first thought is restricted air or fuel flow. Hopefully the OBD II computer can read those items, if not, find one which can; or just replace air and fuel filters. This will only help if one is massively plugged, which if they have never been changed is a fair chance.
3. Loosen but do not remove fuel tank cap. go for a short drive. If it drives fine, fuel tank venting is not working. DO NOT drive for any length of time with the cap loose, this is a great way to die a fiery de@th.
4. Take it to a car repair shop for a full diagnostic. There are many other things that could cause this, bad sensor, plugged cat con or muffler, slipped camshaft drive, security system, transmission problems, contaminated fuel, intake vacuum leak....
Posted on Dec 04, 2014
    Problem Solver:
  • 9 Answers
Sounds Like you have a faulty catalytic converter, and or a clogged EGR valve. you will also notice a loss of power and sometimes a odder catalytic converter will need to be replaced. The EGR valve is easy to remove and clean out the carbon with intake cleaner.
Testimonial: "already have emptied cats. , and replaced fuel filter . was able to command egr on and off with my scan tool and increase and decrease it with no problems found"
Truck runs fine then dies while driving then will start back up and run ok.
About 56,700 results (0.76 seconds) Search Results
    GMC Sierra 1500 Questions - Truck suddenly stops running ...
    www.cargurus.com > Questions > GMC > Sierra 1500
    CarGurusJul 11, 2013 - Truck suddenly stops running, acting like it's out of fuel. ... start it and let it run until it dies then check the pressure and shut the key off. ... Was running fine and then turned off as if the ignition was turned of. .... Well mine was a loose battery connection that just shut down the vehicle completely while driving.
    1998 1500 5.2 Shuts Off Randomly - CarGurus
    www.cargurus.com > Questions > Dodge > Ram 1500
    CarGurusAug 29, 2011 - I let it sit for a second then tried to start it back up and it wouldn't start.... 2006 ram 1500 randomly dies while driving 13 answers ... truck started outrunning fine but would randomly die. wait a few ... Used GMC Sierra 1500".
    GMC Sierra 1500 Questions - started stalling and dying ...
    CarGurusJul 28, 2008 - The truck starts and dies. Have to give a little gas to keep running.While driving have to 2 foot it so it won't die. Wants to die when I come to a ...
    Engine Dies and Then Starts Right Back Up
    www.justautorepair.com/chevrolet/blazer/stalls-starts-up
Feb 04, 2016 | 1997 GMC Sierra
2000 gmc 1500 seirra idles then dies
Have you checked your running fuel pressure AND VOLUME under load and at idle ?
Jul 29, 2014 | 2000 GMC Sierra
I have a 95 1500 with the 350, sometimes it starts and runs great, other times right after it starts it will shoot up to 2000 rpm, the service engin soon light comes on and if you drive it, everytime you...
Try removing and cleaning the idle control solenoid on the throttle body. They get contaminated with carbon build-up and gives you an erratic idle. It's the round solenoid that screws into the side of the throttle body. When you remove it you'll see a spring loaded plunger that needs cleaning with throttle body cleaner and you'll need to clean the seat inside the throttle body as well.12_24_2012_2_14_19_pm.png
Dec 24, 2012 | 1995 GMC Sierra
My 2000 gmc sierra z-71 has started idleling at about 1300 rpm after driving for a while. when i turn it off and restarted it would idle fine for a while then start idleing high again. it is getting to...
I assume the check engine/ service soon light is on. Commonly the MAP sensor is the culprit, but can be TPS, CSS, even a buggy O2 sensor. Only way to be sure? (light or not) is to scan it.
Jul 02, 2017 | 2000 GMC Sierra
99 GMC Sierra 5.3L sputtering and hesitating
Check TPS for smooth and linear electrical response over the entire range of motion. If the response is jumpy or erratic at all, replace TPS.
Thank you for using fixya and good luck.
May 11, 2010 | 2000 GMC New Sierra 1500
Where is the starter on my gmc sierra 1500
4.3, 5.0, 5.7 under the passenger's side floor board. Crawl under and look up where the engine meets the transmission. Two 13mm bolts usually, and two wires on top. One 13mm. The other 8mm. Unhook the negative terminal first before starting.
Mar 01, 2010 | 2000 GMC New Sierra 1500
2000 gmc starts but then idles rough then dies
I had to replace the mass air flow sensor. $ 150. the engine would shut off when driving too.changed fuel filter only worked for a day. The sensor is just after air filter.
Nov 27, 2009 | 2000 GMC New Sierra 1500
Engine surges at rpm over 1500
Look for a vacuum leak (lines and intake), Is the engine light on, were any codes present? A faulty EGR or IAC could cause the problem too. Check the throttle cable for any restrictions.
May 27, 2009 | 1996 Chevrolet Cavalier
2004 GMC Sierra Heater does not heat on low RPM
check your coolant level on the radiator
Feb 03, 2009 | 2000 GMC New Sierra 1500
Vehicle Parts & Accessories Logo
83 people viewed this question
Top Crl Automotive Vehicle Parts & Accessories Experts
Slo Mover
Karl H
Rigger
Are you a Crl Automotive Vehicle Part and Accessory Expert? Answer questions, earn points and help others
