Question about Refrigerators
Hello I have a Frigidaire refrigerator model X FUT 1826MW1 there is no power to the light inside or compressor and fan not working need help to pin point the problem
  • Refrigerators Master
  • 744 Answers
Hello;
My name is Peter. I am a retired field service refrigeration technician.
You unit is locked in defrost. You have a defrost timer problem. This is a easy fix.
In your fresh food section, not freezer, are your unit controls. If you look up, about have way back, you will see a small hole.
Look at the following picture:
Hello I have a Frigidaire refrigerator model X FUT - 25306244-b3edjqs4ufvbcqfi2v1m52kl-1-0.jpg
At the upper left is a nob for a screw driver. This component is face down, about half way or middle of the control plastic cover.
So, with the screw driver turn the nob clockwise. You will hear a click. Keep turning one click at a time until you refrigerator turns on.
Now, the refrigerator has turned on. You have a bad defrost timer. It will not come out of defrost. So, until you replace the defrost timer which is easy you must force the timer through defrost.
Every 8-10 hours your unit goes into a defrost mode. Where it shuts down for about 20-30 minutes. So, once again, you must shut the unit down manually at least once a day.
Having received the new defrost timer:
1.) Unplug your refrigerator.
2.) Remove the hex head screws from the control panel cover. There are 3 screws. Be careful not to remove the two screws holding the defrost timer until you are ready.
3.) Having removed these screws, pull the control housing toward you. In the rear of the control panel are tabs and slots.
4.) Unscrew the two retaining screws holding the timer, and replace.
Posted on Dec 04, 2014
  • ramirezff Dec 04, 2014
    Hi Peter I have a Circuit board there it's not like the pic you posted I've read that could be power cord or wires that go around back area I put a new light bulb and no luck no fan or compressor
    I've tried resetting by pushing the light switch 5 times to see if it's in defrost mode and no luck
guly
  • 67 Answers
SOURCE: U-Line 75R refrigerator compressor does not turn on
chick the defros timer, replace the defros timer
Posted on Sep 16, 2007
SOURCE: Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
Ended up having a freon leak in tubing around door. Luckly the warranty was 5 years in sealed system. New one was FREE.
Posted on Feb 23, 2008
  • 1073 Answers
SOURCE: Frigidaire refrigerator
check the overload, take it loose and inspect it for a burnt spot shake it if it rattles replace the relay
you either have a relay bad or a stuck compressor
the compressor has a 5 year warranty on the part, the relay 1
so if you relpace the relay and it still doesnt run the compressor, call for serviece under warranty
Posted on Apr 28, 2008
SOURCE: Maytag stopped getting cold, buzzing noise every now and then after pwr outage
Frig requires either compressor relay or the compressor itself...should have some warranty still, so call an authorized servicer. Ray
Posted on May 30, 2008
docjohn174
  • 943 Answers
SOURCE: not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
Posted on Sep 27, 2008
Frigidaire frs23w3a side by side fan and light inside working but not compressor. Compressor not hot at all. Any suggestions?
Hello Eric, thank you for your inquiry!
I see that the compressor on your Frigidaire refrigerator is not operating and all the components inside are still in operation. This could be a potential miscommunication within your refrigerator and a reset may help correct that problem. You can reset your refrigerator by disconnecting the power from it for at least ten minutes. If the reset does not help correct your issue within the refrigerator you may need to have a professional technician out to perform a proper diagnosis and repair. This will help you from purchasing unnecessary parts. I hope this information is helpful. -Matt
Jan 13, 2016 | Frigidaire Refrigerators
Hello, my frigidaire fridge fan wouldn't shut off and started freezing everything in fridge, unplugged it a cpl times and now its not working at all, just the lights? Any suggestions would help...
I appreciate your inquiry, Rick Baran!
From the information you have provided the fan inside of your Frigidaire refrigerator continued to run and would not shut off thus freezing everything inside of your refrigerator. Now, the refrigerator is not cooling and only the lights are working. Sounds like you may have a possible problem with the control panel or wiring harness within your refrigerator. I would suggest having a professional technician come out to perform a diagnosis on your refrigerator. This will help you avoid any unnecessary part purchases. Hope this helps. -Matt
Jan 29, 2015 | Frigidaire Refrigerators
Not cooling at all,compressor & fan next to compressor not working
Hello friend, thank you for your post!
It sounds like there could be an issue within the sealed system or control panel of your Frigidaire refrigerator. Are the lights still showing on the front and inside your appliance? If they are, I would recommend a reset to the refrigerator, which you can do by unplugging the appliance or flipping the household circuit breaker for ten minutes. Once you have performed the reset if the compressor or fan does not start up I would contact a professional to accurately diagnose your refrigerator to determine the root cause. -Matt
Aug 06, 2014 | Frigidaire Gallery GLHS66EJSB Stainless...
What stop the compressor, water spilled on the freezer fan though the vent by the ice maker. help
Most likely the=> 5303918476 Defrost Control Board will need to be replaced. This board can be found inside the control panel inside the fresh food compartment. Unplug power and lets examine the board. Here is another source for the board 5303918476 Defrost Control Board Here is a photo of the inside of the control panel HERE and item location 23 is that board. I am here should you have questions, Sea Breeze
Soemtimes the defrost control board will show signs of failure with burn marks and heat damage but not always. It is likely this board is the problem and in some cases the start relay and run capacitor can cause these same symptons.
Jul 03, 2013 | Frigidaire FRS3R5EMB Side by Side...
I have a Frigidaire upright freezer. Power coming into freezer. Light inside works, and the temp setting on the door works. Not getting any power through the system to the compressor.
Contact a professional. The power supply source needs to be testing to the compressor and see if the power is fine, or if the compressor is faulty and not drawing needed power.
Aug 15, 2012 | Frigidaire Freezers
My freezer is no longer freezing food- why?
I looked up your model. This is a self defrosting model which features a fan motor for the compressor and the evaporator. If either of them 2 fans is out then the freezer won't work well. That is the first thing I would check. If only one of the fans is gone out then replace that fan and rock on. If Both fans and compressor are not working then hunt down the timer. It may be stuck in defrost mode. The timer is nestled up behind the cold control and light bulb inside the nice little console in the fresh food compartment. Look under the console for a hole about the size of a dime. Inside that hole a timer advance. Use a flat blade screwdriver to advance the timer till you hear the compressor and fans come on. If the timer is fine the next thing to look for is ice buildup inside the evaporation compartment. If you see that then the defrost heater and termination thermostat needs to be replaced.
If both fans operate ok but the compressor is not working then I would remove and inspect the compressor relay for wear. The cold control would be the next thing to take a look at. If it is open the compressor and fans will not run but the inside light will work.
May 18, 2011 | Frigidaire FRT17B3A Top Freezer...
Frigidaire refrigerator not working colling
Can you tell me a little more like sounds of fans or compressor sounds. Lights on inside. When you open freezer is fan running? I will give you a try on fixing this. Let me know also if the model number above your post is the model of your refrigerator. Let me know if I can help you, Thanks, Sea Breeze
Jun 18, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer not working nor is the other side
Unplug the Ref for 15-20 min, plug it back in and listen for the compressor to start. You will have to be behind the ref also, check the fan that keeps the compressor cool. If you hear a clicking then the compressor relay is bad. If nothing happens then the defrost timer could be stuck in the defrost mode.
Nov 21, 2008 | Frigidaire FRS26R4A Side by Side...
Frigidaire side by side
booster on compressor not condesor, if you needed a "boost" to run compressor sounds like you got bad compressor.
Feb 09, 2008 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
42 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
