My Prima TV model:PH-4237P 42inch for some reason for the tv to go full screen I have to put zoom it if I put it on panorama or full screen there is black space on the bottom and the top how do I fix it thank you
    Top Expert:
  • Televison & ... Master
  • 74,383 Answers
Do a reset to this TV, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Dec 04, 2014
I have a Prima TV model PH-4237P When I put my tv on the panorama mode it doesnt take the full screen What should I do???
Do a reset to this TV. It will make it right. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 03, 2014 | Televison & Video
Hi I have a Prima TV model:PH-4237P 42inch the problem I been having a ********* square comes in a middle of the screen every 10 to 15 minutes I always have to use the remote control press anything b
Do a factory reset to this set. It will clear all wrong settings, and the TV will come ON with its factory set mode. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Dec 03, 2014 | Prima Televison & Video
Hi I have a Prima TV Model:PH-4237P 42inch my problem is the tv has alot of little white snow not sure how to remove it
Check all cable connections. Take them off and put them back on the same place that you took them off of, to insure good connections.
What is the code for a srp4004/27 phillips remote for a prima modelph-4237p tv
0195 0601. Check these codes. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" or "Magazine" view. It will make surf easier. Do a search by type in the brand name of your device at its search box.
http://electrohelponline.blogspot.com/ Check this link too. http://remotesearch.blogspot.com/
May 25, 2014 | Televison & Video
Prima Cineplus 50" Plasma PH-50R18C will not turn on
The ambient temperature might be high. Check whether the foolinf fans are working or not. If not, check out the reason for it. The TV must be placed at least 6cm away from wall, and should have sufficant ventilaation.
Nov 15, 2013 | Televison & Video
I have a 42" Prima
Hi Howard,
It sounds to me the Power Supply Board is bad. You will need to get the numbers off the original board by taking the back off the set ( After unplugging the set of course) and the you can contact a board company ( Encompass Parts Distribution ) or any other company that you might find on the internet with your google search engine and order the board. Good luck with this problem.
Ed " Original Radio Man"
Nov 20, 2010 | Televison & Video
Sony 42inch tv picture has reduced itself to size of regulaur tv instead of wide screen. How can this be adjusted ?
There should a selection for the size picture your viewing. There is most likely a zoom selection as well.
Dec 28, 2009 | Televison & Video
The code to program my remote control for my tv Prima PH 42R6C''
I need to know the code to program a new universal remote tv for my PRIMA PH-42R6C. I don't find the code and i don't know what kinf remote i need for this tv.
The problem is i lose the remote
Thank's for your help
yvon.rathe@sympatico.ca
Mar 03, 2009 | Televison & Video
Overscanning
On your remote control there should be a button that lets you change the screen mode, IE. Auto, Panorama, Cinema, Full, Normal, Zoom, etc...
Jan 23, 2008 | JVC AV-27D305 27" TV
Televison & Video Logo
62 people viewed this question
Top Televison & Video Experts
Electro Med Services...
