Question about Bowflex Treadclimber TC1000 USED
Bowflex TC1000 has power to control panel put will not start
Turning unit on an off press reset button numurious times
Hello. Have you figured out the problem.. I had bought a used one and had magnetic switch issues . So I bypassed the switch and things work great
Posted on Feb 23, 2015
  • Lionel Velez
    Lionel Velez Jun 26, 2015
    How did you bypass the switch?
  • Lionel Velez
    I have the same problem and I've replaced the console board, wires, and speed sensors. Nothing appears to help
3 Suggested Answers
  • 6 Answers
SOURCE: I have a bowflex tredclimer tc1000 won't turn on.
I have a TC3000 and when it wouldn't turn on I recalibrated it using the directions from the owners manual. It's now working. Give it a try.
Posted on Jul 29, 2009
SOURCE: bowflex tc 1000 treadclimber
TC1000 from Bowflex, works okay for 15 mins then the speed surges ahead and stops dead with error E1
Posted on Jan 12, 2010
My treadclimber is in sleep mode how do I fix this ?
Make sure machine is plugged into a known working outlet, and make sure the power switch is turned on. Then make sure the yellow safety key is in place. At this point you should only have to press start to use the machine.
Feb 16, 2013 | Bowflex TC1000 Treadclimber
Do i need a safety key to start the tc1000
Yes, it will not operate without the yellow safety key inserted into the console.
Dec 15, 2012 | Bowflex TC1000 Treadclimber
Control panel on bowflex treadclimber isn't working.
adjust the reed switch, see the diagram clean it, tight the plug very well.
God bless you
Sep 22, 2012 | Bowflex TC1000 Treadclimber
Pushing my Reset Button messed up my digital screens
Disconnect all power to the machine (unplug from wall) for 5 minutes, then reconnect and that should resolve it.
Aug 13, 2012 | Bowflex TC1000 Treadclimber
Treadclimber tc5000 will switch on but start button won't work
Make sure the power cable is connected to a known good outlet (test outlet with a lamp or some other electronic device) and connected securely to the machine. Make sure the safety key is securely seated or belts will not move.
Jan 16, 2012 | Bowflex TC1000 Treadclimber
TC1000 when turned on runs at high speed only has no display and no control
Your motor control board sound defective, there is likely some debris or liquid that has shorted out the contacts. Contact Bowflex for replacement.
Aug 09, 2011 | Bowflex TC1000 Treadclimber
I have a Bowflex TC1000 that will not start. The console powers up, the red light on the power switch lights up and the green led and red led on the controler board are lit. A/C voltage to board is 120...
Check to make sure the yellow safety key is securely inserted into the console. If not, the control board will not send power to the motor. If this does not resolve the issue, check connections and continuity of wiring from console to control board.
Apr 20, 2011 | Bowflex TC1000 Treadclimber
Bowflex TC 1000 treadclimber causing power surges that freeze the cable and internet and change the time on 1 alarm clock for 1-2 minutes every time I turn it on. What's causing this?
You are not on a dedicated circuit the amp draw must be significant thus pulling down the voltage causing your grief. Find a and outlet that is not on the same circuit your electronic units maybe in another part of the house. Or put in a new circuit if you have a vacant in the breaker box, but that need a qualified electricians to do the job$$$$$
Jul 10, 2010 | Bowflex TC1000 Treadclimber
Jul 08, 2009 | Bowflex Treadclimber
Bowflex tc 1000 treadclimber
Jun 28, 2009 | Bowflex TC1000 Treadclimber
Bowflex Treadclimber TC1000 USED Logo
226 people viewed this question
Top Bowflex Exercise & Fitness Experts
Electro Med Services...
Shehu Pro
Shehu Pro
Are you a Bowflex Exercise and Fitnes Expert? Answer questions, earn points and help others
