Question about Classic Flame Nantucket Corner or Flat Wall Electric Fireplace Insert & Mantel - Golden Cherry
Flames wont move - Classic Flame Nantucket Corner or Flat Wall Electric Fireplace Insert & Mantel - Golden Cherry
  • 2,042 Answers
There should be a small electric motor that turns the wheel that looks like flames. That little motor may not be working making it look like the flames don't work. May have to replace the motor.
Posted on Dec 04, 2014
  • Kellie Marks
    Kellie Marks Dec 04, 2014
    Can I still use it with the flames not moving it is still pretty I just don't want to hurt anything worse. But I want to look at it the way it is frozen like that till I can fix the little motor
How do you adjust the pilot light flow on an old magic chef heating unit/ceiling mounted furnace?
How long is the pilot flame? It could be you can move the thermocouple into the flame by making adjustments of the metal holder. If the flame is small, there is an adjustment for the piolet flow in the control module where you turn gas on and off and light the pilot. It should be labeled and usually has a cover that must be unscrewed to reveal the adjusting screw. Need a bright flash light to see what you're doing.
Feb 28, 2015 | Heating & Cooling
Superser gas heater lights but wont stay alight new thermocouple fitted
The tip of the thermocouple needs to be moved closer to the pilot flame.
Feb 02, 2015 | Heating & Cooling
Burning smell when running car ? Oil or electrical ?
open the hood and observe the smoke(if any) electrical smell will show a yellowish color with a blue/green/red yellow flame and it moves fast..oil smoke and antifreeze smoke(vapor really) will sort of "steam" off from near the area its leaking from when hot.. brake smell and clutch smell are almost the same since both use like materials for friction..keep an eye on this for potential problems and may need to move the vehicle outside so if it goes up in flame the house wont/grarage whatever//
Dec 30, 2012 | Cars & Trucks
Whirlpool Cabrio Gas Dryer. Will heat for a short time then stops. usually gets stuck around the seven minute mark and wont move from there. Cothes are soaked. I checked all internal parts with multimeter...
If what happens is the flame comes on when it first starts,after the flame goes off you see the igniter glows then goes off but no flame,the coils that open the gas valve are working while thier cool but once thedryer gets running,when warm to hot the gas valve coils wont open the gas valve so when the igniter comes on and no flame the coils have failed to open gas valve and need to be replaced, all manufactures use the same coil supplied by one parts supplier, and them not opening the valve when warm is a very common occurence regardless of what brand gas dryer it is.
The part number for the coils is 279834 they could be picked up from your local appliance parts store for under $20 or online at;
repairclinic.com
searspartsdirect.com
assuredparts.com
apdepot.com
appliancepartspros.com
Gene
Aug 11, 2011 | Whirlpool WGD6200S Gas Dryer
HEF33 flame not turning over, power OK and heater working, all lights on. Flame speed at stop and will not move.
i have pyromaster hef33. flames on my stop moveing also. i took off front glass and logs. then i got a long metal tool and.then i tap the moter that moves the rod that makes the flames move.and also i move the rod back and forth alittle bit. i did put just bit 3in one oil on both ends of the rod. so far its doing better now . this may help some one or it not. i thank the moter or rod was sticking
Jan 02, 2010 | Leisure HOMEPRIDE Electric Fireplace...
My pilot wont stay lit i cganged the thermocouple it worked for a couple of day now the pilot wont stay lit again
Make sure ALL covers are in place. Watch the pilot flame. It should not move around. If it does, there's a draft blowing it out.
Oct 23, 2009 | Water Heaters
WONT FIRE UP Hayward h150 Pool heater
Is the thermocouple in the pilot flame? It has to sense the flame and provide a signal to light. or, is it a flame sensor? Same thing, must be sensing the pilot flame. This is the first step for it to light...
Jul 15, 2009 | Electronics - Others
Dryer flame on magtag wont stay lit. Pilot flares up but no flame
Thermocouple is probably bad. The pilot burns and heats a sensor which tells the CPU that the Flame can start, and the thermocouple heating up changes voltage with increase temperature and tells the CPU that the Flame is burning OK. If it is defective, there is no voltage change and the CPU assumes that the Flame didn't start for some reason, (Gas only!) and turns if off for safety. Over and over xx times.
My .02
Good Luck!
Mar 26, 2009 | Dryers
Infra red heaters wont stay lit flame in the tubes
have you tried to heat up thermal couple for a couple of minutes. It takes a few minutes for the flames to actually starts heating thermal couple you might have to move thermal couple a little closer to heater flames
Jan 16, 2009 | Reddy HD30 Heater
Blue flame heater pilot wont stay lit
There is a therma-couple that the flame burns against. When it is working correctly it allows gas to travel to the flame. When it goes out you get no gas, as a safety feature. Replace the therma couple and it should work again.
Oct 06, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Classic Flame Nantucket Corner or Flat Wall Electric Fireplace Insert & Mantel - Golden Cherry Logo
73 people viewed this question
Top Classic Flame Televison & Video Experts
Electro Med Services...
Are you a Classic Flame Televison and Video Expert? Answer questions, earn points and help others
