I have a flat screen Phillips TV and recently the power light flickers (I hear a click) but the screen does not come on. If I keep trying after a couple days it will finally power on, however once I power it off the issue above repeats itself and I have to wait for a couple days again.
    Scholar:
  • 82 Answers
Most likely your power supply or main computer board has bad electrolytic caps that require some "charging" time before they warm up enough to turn on the set. This happened to me on a 42" LCD flat screen and I was able to determine which one - it was only one on the main board that was the bad cap - by using a hair dryer to heat it up enough by holding it in one area until I could determine which one it was. This helped a lot of people who were going to trash their sets because this $.50 cap didn't have a bulging top or leaks like they do most of the time...you should look for that problem too of course. Once you find where it is, you can normally go on eBay and buy replacement caps and diodes to solder in as replacements...get a friend who has experience if you are not comfortable doing this yourself because you can wreck a good board with poor soldering techniques and then it will cost more than it might be worth to replace those boards. I'm in the process of repairing my son's 37" set right now where we think it is the power supply board and there is a slight clicking/chirping sound as it tries to turn on...had many bad caps but now we're down to replacing some zener diodes. Good luck! Dave
Posted on Dec 04, 2014
Testimonial: "Hey Dave, Do you think it makes more sense to just replace the main computer board first, and if there is still a problem go ahead and replace the power supply? I don't think I would do a great job at the soldering. Thanks again for any help."
  • David E. Colglazier Dec 04, 2014
    I don't know your set and it's problems personally but the power supply is more likely to be a problem than the main board normally. If you google your set's P/N, you can find out how often this is happening to others and determine from the responses which board is the best to replace or repair. I can't get repaired boards for my son's set so I have to go the route of repair.
  • 4090 Answers
SOURCE: Hisense tv turns on and off
STOP!
The unit has a fault on its power board and sustain board.
It turns off because the sensor is preventing some component from bacoming overheated and catching fire or damaging further components. Seel professional repair.
Please rate my help++++Thanks for using FIXYA
Posted on May 13, 2010
SOURCE: 2 year old Phillips 42" Plasma TV won't turn on
Hi I had exactly the same problem, bought the above parts off ebay. The above solution worked and tv back to normal. the soldering is a bit tricky and there is a lot of screws holding the back on!
Posted on Oct 23, 2008
yammy_alf
  • 666 Answers
SOURCE: RCA 37" FLAT SCREEN NON STOP FLICKERING/FLASHING SCREEN
you need to remove main ckt, (m.board) some part need to re solder specially in hot area. (lost contact i one of the flickering problem you encountered.
Posted on Mar 26, 2010
SOURCE: my Samsung flat screen tv won't turn on and it
There's a couple transistors on the Power Supply board that are probably bad. On mine, the solder joint was bad on the bottom side of the board that pointed me at those transistors in particular. Part number is FQPF9N50C. Also, you could get a refurb or new power supply board of ebay or send your board in for service (also on ebay).Or there's a "repair kit" you can get that contains 4 transistors and a couple caps I think. If you are an electronics junky and like soldering stuff, that would be the way to go... I just ordered the two transistors off ebay for like $6.
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=320632712822
http://cgi.ebay.com/Samsung-HP-T4254-Internal-Replacement-Circuit-Board-/230575679230?pt=LH_DefaultDomain_0&hash=item35af61a6fe
http://cgi.ebay.com/REBUILD-YOUR-SAMSUNG-BN44-00161A-Power-Supply-/200513469692?pt=LH_DefaultDomain_0&hash=item2eaf88bcfc
Posted on Feb 05, 2011
  • 8457 Answers
SOURCE: I have an aquios LC-42D64U which suddenly has the
This problems is very common on Sharp tv after a year or two.I have one too 46" Aquos.The tv Tuner signal board have problems,but this tv still usable.My tv does Power and OPC LEDS lights flashes alots many times as the tv getting older.This how i solved it.If POWER and OPC LEDS lights flashes,just press the remote power again wait awhile.Sometimes POWER and OPC LEDS lights will flashes again,just press the remote power button again and wait awhile.Sometimes POWER and OPC LEDS lights will repeat like 3 or 4 everytimes,just must press the remote power switch wait awhile eventually the backlight,will light up the Tuner signal board kick in and work.Have to press the remote power button and wait for the POWER and OPC LEDS to stop blinking and the Tuner signal board to kick in.But like POWER and OPC LEDS blinks 10 or 12 times and remote power button press 10 or 12 times,it time to replaced the tv Tuner signal board.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Phillips flat screen tv left half of screen is black right side is dim and flickering
Is your tv less than a year old? You need to call Phillips and see if it is covered under warranty. If that is not the case you need to get a few estimates. You want to know if it will be cheaper to repair or replace your tv set.
1 888-744-5477 Phillips customer service number
Aug 14, 2016 | Televison & Video
Phillips TV Model: 52PFL7422D/37 Purshased this TV Dec 16, 2007. No I have blank screen with the TV blinking a read light at the left - the red light flickers - blink, blink,blink,blink,blink then 3...
First place to check is the power supply board. I have not repaired this particular model. I'm very certain you have two bad capacitors in the power supply. This is a classic problem for Philips flat TVs. The capacitors will be bulged or skinned. Be sure to replace them with same values. I would certainly gamble my time removing the power supply for inspection. Spending a few bucks on two capacitors may prove good. A working TV is near. Thanks for asking and show all hands of support!
Jun 30, 2011 | Philips 50PFP5332D 50 in. Plasma...
My phillips model #32PFL5332D/37 flat screen will not come on
You have been the victim of a power surge. It will need to be repaired in order to work.
Sep 29, 2017 | Philips Televison & Video
Phillips 19 TV screen will not work I can hear
there is a invertor problem ....first check the psu uni (power supply)
Aug 30, 2009 | Televison & Video
LG 42LC2DB LCD TV Flickers when Ps3 is connected via HDMI port
Make sure you have the PS3 set to the correct frequency for the TV. Many cannot accept 1080p / 24fps etc.
Try different settings.
I hope this helps.
Mar 28, 2009 | Televison & Video
The tv will not turn on.
hi right now samsung is the best tv maker out right these problem dont happen with samsung what would be good to do is call them and let them know your problem cause you have a year protection on it thats if it less than a year
Jan 10, 2009 | Samsung 40 in. Flat-Panel LCD HDTV
Blinking light on 37" Dynex LCD
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 22, 2008 | Dynex DX-LCD37 TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
