Question about Cell Phones
My password from my Netgear09 box will not work as Cox lost power and now it will no allow me to join.
Cox told me to telephone you and I waited on the phone for 2 hours today, 21/03/14. Merry christmas to you. Lowell Schwalbe dearoled@ecenet.com I am at anowth computer.
  • 201 Answers
SOURCE: base phone handset #1 holding charge
The base unit should not need a charge. It should be powered by the plug in adapter. It may have a battery to keep operation for a short time in a power outage. The adapter may be loose, the adapter could be broken or the plug in the phone may be broken.
Posted on Jul 07, 2007
otacon
  • 1944 Answers
SOURCE: changing passwords on a used D 307.
Try this:
1. Reset to original factory setting by typing *2767*3855#, youre phone will reboot
2. Then insert a sim card that is from another network that your phone is not locked to.
3. An Wrong sim message will come up on the screen
4. When message appears type in* #9998*3323#
5. At this time a white screen will appear which says “exit”
6. Tap the rigth soft key, (occasionally it will not go to the next screen, if so press the down key)
7. From the menu that appears scroll down to the malloc Fail option, this will reboot, and normal service screen will appear.
8. Then type *0141# and press the green call key, Personalized will appear on the screen, and the name of the current sim card provider will appear on the screen.
9. Turn phone off, and then turn on
10. Go to menu by tapping left soft key, then settings in bottom right hand corner, then choose option number 7 security, then choose option number 6 Sim Lock, select option 1 disable
11. Then enter 00000000 (eight zeros), the message will come up sim lock disabled with a check mark, your phone is now unlocked to use with other carriers.
Posted on Dec 24, 2007
SOURCE: My Book makes clicking noise and does not show up anymore
THIS WORKS....Here try this...unplug everything including the power cable...press and hold the button on the unit for 10 seconds. after that hook the unit back in the power cord first..and it should work...files and everythin are there...I got this from tech support and it worked for me
Posted on Jan 10, 2008
oldnovii
  • 667 Answers
SOURCE: Manual for GE Pro Series 4-line telephone Model 2-9451A
This should be what your looking for. If it's not exactly what you need just add a comment and let me know. If it is, you're good to go! Don't forget to rate ( but wait til I get the right one if it's wrong. Rate now if it's right)
Posted on Mar 19, 2008
  • 990 Answers
SOURCE: I lost power today for about 2 hours. When it was
first ck the nine volt battery out at the equiptment box and make sure it is good then ck to be sure all other batterys are good. Reset all defaults to factory settings and start from scratch on resetting scedules and temps. Always be sure to have fresh batteries in unit ck every year when you change the clocks for example so you don't forget. If this does not help you could have a deeper problem due to surge but ck your antenna out at the equiptment and be sure to ck all your breakers to the pumps also. I hope some of this helps and good luck
Posted on Nov 22, 2009
Uniden PowerMax 5.8 message light won't stop blinking with Cox Digital Telephone
You have unheard messages on the voicemail system provided by your telephone company. This system records messages when someone calls while you're already on the phone. Please contact your telephone company for instructions on accessing their voicemail system.
Mar 24, 2012 | Uniden Cordless Phone
How to remove bios password in lenovo 3000 y510
This information is intended for experienced users. It is not intended for basic users, hackers, or computer thieves. Please do not try any of following procedures if you are not familiar with computer hardware. I'll not be responsible for the use or misuse of this information, including personal injury, loss of data or hardware damage. So use it at your own risk.
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
Jun 10, 2010 | Lenovo IdeaPad Y510 Notebook
I cannot reboot, the thinkpad is locked. how do i
Oct 11, 2009 | IBM ThinkPad T43 Notebook
Belkin N Wireless Modem-Router F5D8633 drivers
Just hook it all up, and push and hold the reset button in the back of the router for 10 sec..
Then unplug your internet box, [cable/DSL box] and plug back in,
The internet box will send a IP to your router automaticly.
[If it dont work unplug power from both boxes, then back in but plug the internet box in first..]
done..
if your useing wireless this will not be setup with a password to join, and will be open to neighbors,,
If you want to go to the next step and setup a password to join, you can do this with out the cd also, but get it working first and hit me back
Sep 12, 2009 | Belkin N Wireless Modem-Router F5D8633au4A
How to remove cmos/bios password ?
Aug 23, 2009 | HP (350030-001) for Compaq dc7100...
How can i remove bios password
disconnect your laptop battery and, bios battery on the mother board wait 10 minutes plug the bios battery back in then; reboot without installing the laptop battery: your passwords will be removed
May 20, 2009 | Computers & Internet
Urgent please (KX-TSC30BXW)
I HAVE THE SAME SYSTEM BUT I DONT THINK U CAN UNLOCK WITHOUT PASSWORD
May 01, 2008 | Panasonic KX-T7636BK Digital Telephone...
Mar 19, 2008 | Lands Phones
Administrator Password for BIOS lost
HP laptop 9000 need help installing webcam
Feb 22, 2008 | HP Compaq nx6110 PC Laptop
Cell Phones Logo
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
