Question about Hardware & Accessories
I just bought a WorkChoice Indoor Mechanical Timer model #TM-082. It is a Pin timer and says to push the pins down to set start & sto time. I can't press them down. What am I doing wrong ?
  • 5,245 Answers
Maybe lift them up?
Following link has pictures showing how to set analog timer and identify type of pin or segment
http://waterheatertimer.org/How-to-set-timers.html
Gene
Water Heater Timers Save Money
Posted on Dec 05, 2014
SOURCE: GE 24 hour programmable basic timer - how do i
So, this timer came with no instructions. What do you want for $3.99. Made cheap in China and instructions cost more than the timer.
The timer has a dial with tabs all around the 24 hour clock. They are in the down position which is on. You must pull all the tabs up in the times you want the timer off. This is different from all the other timers I have that used that have two removable tabs that are placed at the start and end times.
Put the switch on the side of the timer in the timer position.
Posted on Dec 14, 2009
SOURCE: Woods Model 59200V Indoor Mechanical Timer. Not working
book says peg should be down for on and peg should be up for stop. How the hell does one pull the peg up...it is blocked and can only be pushed down...now what I am missing?
Posted on Dec 19, 2009
SOURCE: intermatic Time All ,model TB111. lost plastic pin
I have the pieces for an Intermatic Time All, model TB111 because mine stopped working. I don't know how to get in touch with you.
Posted on Feb 06, 2010
SOURCE: I have set
Woods 7-day timer:
Timer dial is supposed to rotate at all times no matter if override switch is set set to ON or Timer.
Sounds like the timer is broken.
http://waterheatertimer.org/Woods-timers-and-manuals.html
Posted on Nov 25, 2010
SOURCE: I cannot set the timers for off and on. The
They're ALL Down when you get the timer.. It would be helpful for them to state that in the instruction. Instead they tell you to push the pins down to set. Bur they're already all down!
Posted on Mar 03, 2012
Manual for a defiant indoor mechanical pin timer
Don\'t buy a Defiant timer they are bad bought one messed with it for an hour or 2 before I realized it was broke to start with
Dec 18, 2013 | Heavy Duty Hardware & Accessories
Hi how do i set the the 59200 timer for indoor use. does it matter if you use the nos on the white side of the dark side of the timer? im not following the instructions. how do u know how many pins to...
Each pin/segment represents 30 minutes.
To set timer for 2 hours, move 4 consecutive pins/segments up or down.
For 8 hours, move 16 consecutive pins/segments
http://waterheatertimer.org/images/Raise-segments-240.jpg
Dark background for numbers are usually 'night' or 6pm to 6am.
Timers usually have am and pm printed on timer dial.
Open following link for analog timer instructions:
http://waterheatertimer.org/Woods-timers-and-manuals.html#59200
Jul 18, 2011 | Woods 2C 24 Hour Indoor Mechanical Timer...
Where are the pins on the outdoor mechanical timer "woods #59382
The "pins" are the 48 little tabs that are around the clock dial. That would be 2 in every hour of the 24 hour day.
Push down a pin to start the device that you want to control and pull up the pin at the time you want the device to stop.
Dec 21, 2010 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
I have the intermatic TN 300 model lamp timer and I forget how to set the timer...??
This answer is a little misleading. ALL the pins between the time you want the lamp on to the time you want it off must be pushed down. In other words, the lamp will light only when the timer reaches a pin that has been pushed down. You could have the timer turn a lamp on and off and on and off and on and off, etcetera, if you had one pin down, the next up, the next down, etcetera. It's a good visual indication of what the lamp will do: pin(s) DOWN = lamp ON; pin(s) UP = lamp OFF.
Dec 12, 2010 | Intermatic 10 Amp Mechanical Indoor Timer
I need the instructions to do the set up
You posted under Intermatic TN300 24-hour plug-in indoor timer with 2-prong outlet
If this is not your timer, add a comment
http://www.amazon.com/Intermatic-TN300CL-Indoor-Mechanical-Timer/dp/B001KBZUK8
Intermatic TN300
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/tn300.ashx
TN300 is same as Woods 59200
http://waterheatertimer.org/pdf/Woods-59200.pdf
Rotate dial until current time lines up with arrowhead located on inner dial.
The segments located around edge of dial are pushed down or raised to set on-off times.
Push segments down for times you want timer ON
Override switch on top of timer.
For programs to operate, move switch to Timer ON
Plug lamp into timer.
Turn lamp ON
Plug timer into wall
Dec 09, 2010 | Intermatic 10 Amp Mechanical Indoor Timer
How do i program the 24 hour timer by woods?
You posted under Woods indoor plug-in 24-hour mechanical timer.
This particular timer:
Rotate dial until current time lines up with words: 'time now' located on inner dial
To set on-off times, look carefully at dial that rotates.
There are tiny pins that stick up on the dial.
Each pin represents 1/2 hour.
Use fingernail and click pin outward for each half hour you want timer ON
Leave pins inward for each half hour you want timer OFF
Next, plug table lamp into side of timer.
Last step, plug timer into wall outlet.
If this is not your timer, see all Woods timers and manuals:
Or add a comment and I will help.
Nov 17, 2010 | Woods 2C 24 Hour Indoor Mechanical Timer...
Dec 18, 2009 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
Setting GE Plug in mechanical timer 24 Hr Model 15119 instructions
pull the pins up for off, down for all, so pull all the pins up then push down the pins for the time you wan the time on
Dec 13, 2009 | General Electric GE 24-Hour Timer, 2-Pin...
Hardware & Accessories Logo
3,274 people viewed this question
Top Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
