Question about Bosch MMB2000 Work Top Blender
The plastic base of the glass jug is broken, need repacement.
Does anyone know where I can purchase a replacement for this part?
  • 4 more comments
  • KatieS Nov 22, 2007
    I have that problem also. The book says it is called a blender support but it has no part number and I can't locate one.
  • geekwench May 21, 2008
    Can't locate parts for this blender!
  • Anonymous Jun 14, 2008
    The "blender support" as the book calls it is broken. Cannot find parts for this blender.
    Does anyone know where?
  • Anonymous Jul 14, 2008
    The plastic ring broke on mine too. You'd think as much money as they charge for these this could be replaced, or better yet, wouldn't break in the first place.
  • toddar277 Oct 25, 2008
    Need plastic base or new jar, Where do I purchase?
  • kim leighton Jul 26, 2013
    I have this problem too. I tried to glue it together, but the blender is starting to leak... I found what i think is the replacement part 056561 at the following website. I have not ordered it yet, in case anyone had any ideas...
    New Friend:
I have the same problem. tried to glue it back together, but now is leaking again. i found what i think is the part 056561 at the following website.
any thoughts?
Posted on Jul 26, 2013
I used a 4" stainless steel hose clamp as ours was cracked but not in pieces. So far it has worked.
Posted on Jun 16, 2008
Breville tea maker glass jug broken, how to replace it?
I suggest you go to the company's website and look up your tea maker. You might have to call the company as well to find a replacement for your glass jug.
Best I can do.
Semper Fi,
Feb 13, 2018 | Breville Blenders
I bought a new interlocking collar for my Kitchenaid blender, and now it doesn't seem to be fitting on the base properly. It's resting on the base rather than going all the way down, if that makes sense....
Remove the collar from the jug and have a good look inside, there is a circular ring inside the collar that needs to engage correctly with a glass finger on the jug. The glass finger goes between 2 plastic fingers. I think there are two of them. It was a silly idea that's been given the flick on later models.
Mar 02, 2015 | KitchenAid KSB560 5 Speed Blender
Broken plastic base for CBL25
FIXYA does not know who might have a broken JUG .
Dec 03, 2017 | Breville CBL25 Moda Bar Work Top Blender
Gold powder or particles on base
It's probably brass, run it a few time and clean it, if it continue, their a good chance that your bearing is dying (grinding it self),check if you can replace that section.
Jan 06, 2014 | Breville Blenders
Can't remove glass jug from plastic base...........Used once.....not impressed....probably won't buy again
The bottom of the plastic base has some grooves on it to grip it. Make sure you are turning the glass counterclockwise with respect to the base being below it.
Jan 28, 2011 | Cuisinart SPB-7 SmartPower Work Top...
Broken glass jug on kitchenaid blender model 5ksb2aer4
Look at the underside of the blade shaft. The metal wing nut on the end of the shaft secures the blade assembly to cream coloured plastic blade base. The wing nut also transmits the drive from the rubber coupling on your blender to the blade shaft. The wing nut has a LEFT HAND thread.
The left hand thread ensures the blade assembly does not unscrew during normal blender use.
Firstly disassemble the blender blade assembly. Place a folded tea towel over the blades and hold the blades firmly. If you do not use a tea towel you may cut yourself.
Grip the wing nut with your other hand and unscrew it CLOCKWISE.
Remove the wing nut. You can now remove the blade from the plastic base.
Put the blade assembly in the new jug and offer up the plastic base from under the jug so that the blade shaft protudes enough for you to install the wing nut.
Screw the wing nut ANTI-CLOCKWISE to secure the blades to the plastic base.
Do not over tighten the wing nut; you may have to replace your jug again at some point.
Jun 06, 2009 | KitchenAid KHB300 Handheld Blender
I want to replace plastic jug of my blender, It leaks
Dec 09, 2007 | Bosch MMB2000 Work Top Blender
Replacement glass jug?
I will buy the blade set from you? I will return....
Nov 14, 2007 | Bosch MMB2000 Work Top Blender
Bosch MMB2000 Work Top Blender Logo
382 people viewed this question
Top Bosch Blenders Experts
Are you a Bosch Blender Expert? Answer questions, earn points and help others
