Palsonic tftv6043fhd wont turn on.? - Televison & Video
    Top Expert:
  • Televison & ... Master
  • 42,979 Answers
This could be due to a defective switch, an open fuse, or a failed power supply.
Posted on Dec 03, 2014
Code for a pdp4225hd
http://tv.manualsonline.com/manuals/mfg/palsonic/pdp4225hd.html
Free manual - see if contact information is available for the manufacturer of the
Palsonic PDP4225HD Flat Panel Television
Apr 22, 2018 | Televison & Video
Red light on but wont turn on palsonic tftv4932led
sorry about your issue but the Tv you have is generic low grade and not even worth 100 to replace all over the internet
I suggest you go buy a new TV because the one u have is not worth paying anybody to fix
Feb 12, 2018 | Televison & Video
My Palsonic TV wont tune in some free to air channels, I receive a message saying not supported ?
Hi sounds like you're TV doesn't cover the frequency's (channels) U r looking for :::::: if U want to get them U will have to get a set top box .most new set top boxes will cover all the frequency's....good luck
Oct 12, 2016 | Televison & Video
Palsonic stand by light is on wont turn on
The main power supply regulator section fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jun 27, 2016 | Televison & Video
I have a palsonic model no: TFTV492LED and I can't change it off AV1. I want to put it on HDMI I have no remote either.
Try the front panel button labeled Source; it's the second button from the left. (The first button is the Power button.) All of the buttons are on the right hand side of the bottom frame of the TV. Use the Channel Up/Down arrows to navigate through the list of inputs. Try waiting for the selection to take effect. (The documentation says press OK or the Volume Up button. Sometimes, the Source button on the TV functions as an OK button. This isn't clearly identified for the Palsonic.)
If the HDMI input is greyed out, the TV may not be seeing a compatible signal from the source. Try turning on the device when the TV is off, then turn on the TV. I'm not sure if this TV will correctly see the signal from a computer. However, on some laptops, you'll need to enable the external video first. This is disabled to save power. Then turn off the computer. Finally, turn on the TV before turning the computer back on.
Palsonic has the manual available for the TFTV492LED on the product (discontinued) site under the Downloads tab. See http://palsonic.com.au/archive/led-tv/tftv492led.htm . The direct link to the manual is http://palsonic.com.au/customer_service/led-instruct/Palsonic_TFTV492LED_Manual.pdf .
I hope this helps.
Feb 29, 2016 | Televison & Video
When I try to retune TV to pick up new TV stations I get sound OK but a black screen with message invalid format.
Check stations MPEG format . Check if it is MPEG4 and check if TV can decode MPEG4 . A firmware update may be available on tv and may fix it but it has the risk of turning the tv into a brick if something goes wrong during a firmware update.
suggest contacting palsonic to see if firmware possible and which one to use.
http://www.palsonic.com.au/customer_service/upgrade/default.htm
Feb 23, 2016 | Televison & Video
Why wont my palsonic TFTV3915FL won't turn on. Any ideas
If there is no LED lit on the front, it may be a blown line fuse.
If you have an LED still showing (power light) then the main supply is likely dead.
Jun 25, 2015 | Televison & Video
I have a Palsonic tv and it keeps turning off ,what could be the problems
There might be some loose solder terminals at its main power regulator board.
Dec 01, 2012 | Televison & Video
A Universal remote which will work on a PALSONIC television?
It will be very difficult to get a sutable universal remote for this set. You can try. That's all.
May 10, 2012 | Televison & Video
My srp2008b/86 remote control wont connect on a palsonic t.v/dvd combo?
use the code '9999' and keep searching. it took about 8 minutes to find my Palsonic. then release the off/on button!
Jul 11, 2011 | Televison & Video
Televison & Video Logo
Top Televison & Video Experts
