Question about Fisher and Paykel Washing Machines
Where is the pump and filter situated in a fisher and paykel 501 washing machine
Washed a pillow and it fell to bits, so am guessing the filter is blocked as machine wont drain
  • Fisher and P... Expert
  • 555 Answers
These machines don't have filters,
All lint is pumped out with the grey water.
Turn off power & water taps before you remove the pump.
To remove pump tilt machine back on a 45 degree angle
against a wall, locate the white plastic pump lock tab push out and turn pump anticlockwise.
where is the pump and filter situated in a fisher  - 25306173-ei0rt0v231vo43kgyqwiblfx-4-0.jpg
Posted on Dec 14, 2014
Fisher Paykel GWL11- US Washer
- Motor control module fault:
Fisher and Paykel washing machine error 1:
Primary Source: Motor control module.
Action: Replace motor control module.
3 - Motor control module fault:
Fisher and Paykel washing machine error 3:
9 - Size setting fault:
Fisher and Paykel washing machine error 9:
Action: Reset machine size as per service manual instructions. If fault repeats replace Motor control module.
10 - Temperature Sensor (Thermistor) Error:
Fisher and Paykel washing machine error 10:
Primary Source: Thermistor.
Action: Replace Thermistor.
11 - Pressure Sensor Fault:
Fisher and Paykel washing machine error 11:
Primary Source: Pressure Tube.
Action: 1 - Empty all water from the machine. Remove pressure tube from pressure sensor, clear pressure tube of any water and reconnect tube (blow down the tube is necessary). 2 - If fault repeats, replace Motor Control Module.
12 - Flood Protection Error:
Fisher and Paykel washing machine error 12:
Primary Source: Water Valves.
Action: If the water valves are on continuously, check that the water valves turn off mechanically by disconnecting power to the machine.
Secondary Source: Pump System.
Action: Check pump for blockage and drain hose for correct height(end not immersed in water) or kinked.
Tertiary Source: motor control module.
Action: If water valves are been driven on electrically, replace motor control module.
36 - Water Leak Fault:
Fisher and Paykel washing machine error 36:
Motor control module has needed to top up the water level more than 4 times during wash/rinse cycle. Most likely cause is waster siphoning out or the machine has developed a leak.
Primary Source: Drainage system.
Action: Check that the hose is not less than 850mm from the ground
Secondary Source: Pressure tube.
Action: Make sure the pressure tube is fitted correctly and doesnt have any holes.
37 - Blocked pump:
Fisher and Paykel washing machine error 37:
Primary Source: Drain System.
Action:
1. Check that the drain hose has not been kinked.
2. Check the length of the hose. 1m is maximum extension.
3. Check drain pump winding for open circuit.(Note: Pumps are fitted with a thermal cut out and will reset after cooling)
4. Check for physical blockage to pump and hoses.
38 - Pressure Sensor Fault(empty reading during wash cycle):
Fisher and Paykel washing machine error 38:
Primary Source: Pressure tube.
Action: Check if tube is fitted correctly, check for blockages or holes in the pressure tube.
Secondary Source: Motor Control Module
Action: Replace the module.
39 - Pressure Tube Fault:
Fisher and Paykel washing machine error 39:
Same as fault 38.
40 - Bowl Dis-engage Fault:
Fisher and Paykel washing machine error 40:
Primary Source: Mechanical.
Action:
1. Check that there are no clothes or other foreign objects preventing the clutch from re-engaging. Excessive suds can also stop the bowl rotating.
2. Check the clutch splines for physical damage.
3. Check that the pressure tube has not come off, kinked or blocked(blow down the tube.
Secondary Source: Motor Control Board.
Action: Change Board.
43 - Out Of Balance Switch Fault:
Fisher and Paykel washing machine error 43:
Motor control module has found that signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected.
Action:
1. Check the level of the machine.
2. Check wiring to the switch.
3. Check switch for continuity and corrosion.
44 - Water in Bowl During Spin:
Fisher and Paykel washing machine error 44:
Primary Source: Drain system.
Action: Check for blockages/kinks in drain hose and function of the drain pump.
48 - Hot and Cold Inlet Valve Incorrect Signal:
Fisher and Paykel washing machine error 48:
Primary Source: Wiring.
Action: Check the wiring.
Secondary Source: Inlet Valves.
Action: Check the resistance of the coils.
Tertiary Source: Motor Control Module.
Action: Change Module.
49 - Cold Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 49:
Action: See fault 48.
50 - Hot Water Inlet Valve Faulty:
Fisher and Paykel washing machine error 50:
51 - Diverter Valve Fault:
Fisher and Paykel washing machine error 51:
Primary Source: Blocked diverter valve.
Action: Check for foreign objects in the valve.
Secondary Source: Motor Control Module & Diverter Valve
Action: Plug the machine into the power point but off at the control panel. Check voltage on the plugs at the diverter valve. If voltage around 230V, change diverter valve and motor control module
Oct 07, 2016 | Fisher and Paykel Washing Machines
How to clean pump from smartdrive 501?
there is no cleaning as such,but if your havig drainage problems then remove pump check for anythining that might jam it and lookat the electrical windings for any discoloutation if there is replace pump
Jul 06, 2014 | Fisher and Paykel Fisher & Paykel Washer
Elba washing machine wont drain or spin
The pump filter is blocked ,so it wont empty,remove filter cap and clear out lint, coins etc.
Jan 03, 2014 | Fisher Paykel Fisher & Paykel Elba 3.7 cu...
MW512 Fisher & Paykel Washer Machine...Where is the lint filter located?
Fisher & Paykel machines don't have a lint filter.
Manual cleaning of agitator and s/steel bowl will make your washing cleaner.
Oct 12, 2012 | Fisher and Paykel Washing Machines
Fisher and paykel kelvinator II smart drive 501 washing machine stops washing mid wash
Check the out of balance switch under the blue motor controller
for corrosion replace if corroded.
Sep 27, 2012 | Fisher and Paykel GWL11 Top Load Washer
MY FISHER & PAYKEL WASHER STOPPED AFTER RINSE WHEN I WASHED BATH RUGS THAT FELL APART. IT WON'T DRAIN AND MAKES A WHINING NOISE WEN ADVANCED TO SPIN CYCLE. WHAT SHOULD I DO?
Your pump is blocked with the bits from your wash. A handyman may be able to service the pump, but it would be a quick job for a tech. The pump us accessed from under the machine and can be inclipped like a light bulb. Inspect carefully first. look for small latch clip before twisting. Make sure the machine has been bailed out first. lean the machine back againt the wall to give access and to keep what little water remains, away from the drain/pump hole. Good luck....Nomess
Jul 13, 2010 | Fisher and Paykel Washing Machines
Fisher & paykel 501 smart drive washing machine
It does not seem like a problem of the unit. It might be a loose connection of supply code. Keep the supply code pressed to the unit in different directions and see if the unit takes power. If so, replace the supply code. It's not that expensive.
Jul 05, 2010 | Washing Machines
Fisher and paykel washing machine will not spin
Most likely something stuck in the pump, you need to look underneath to get to it, the pump turns anti clockwise to remove it.
Apr 12, 2010 | Fisher and Paykel GWL11 Top Load Washer
Blocked filter in Fisher & Paykel washing machine top loader
Fisher & Paykel washers do not have lint filters inside the tubs as they are designed to drain away any debris from the wash during the drain cycle.
Mar 10, 2009 | Fisher and Paykel IWL12 Top Load Washer
Have a fisher & Paykel GW 501 - u Washing Machine which has gone dead. No power is coming and the diplay p.anel is also dead
Go to similar problem posted by ronnelini on Sept 8 2008, and see my suggested solution.
If you're lucky it could be a quick and cheap fuse replacement.
Good luck.
DIY Eddie.
Aug 10, 2008 | Fisher and Paykel Washing Machines
Washing Machines Logo
171 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
michael_t919
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
