Question about La Crosse LaCrosse Atomic Digital Wall Clock with Wireless Temperature Sensor
Why are my batteries only lasting about a week
Replacing batteries
Received a watch last Christmas. Have replaced the battery several in this past year???? Last time I replaced....watched & stopped running in last than 2 weeks??
Two things spring to mind.
Most likely is that it needs a lithium battery which are more powerful and have a longer life. Someone is replacing is with a standard silver oxide battery.
It is has a leakage drain fault and needs to go back under warranty.
Dec 05, 2017 | The Watches
Why do I have to replace the 9 volt battery in my guitar every 2 weeks?
Either the batteries that you put in as new were already on their way out or you have a current drain that is depleting the battery. Use an ammeter to determine when guitar is off if there is any drain on the battery. If so, that is the culprit.
Sep 06, 2015 | Takamine EG523SC12 Jumbo 12 String Cutaway...
SHOULDN'T MY BATTERY LAST MORE THAN A WEEK
Do you mean that it goes dead after sitting a week or goes dead after a week while driving it?
Dec 23, 2014 | Cars & Trucks
New batteries only last 1 week.
You need a new remote sent to you. This is the only fix for this issue. Thanks for using fix ya.
Mar 06, 2010 | DISH Network IR Remote Control
Not charging after replacing batteries
dear sir
i changed my battery last year on mars 2008 last week i have problem my battery is very low
brahim ghachi
best regards
Oct 09, 2009 | HP Compaq R3000XR Shuko (192186-B33)...
Dead battery
Charge the battery using the supplied USB cable. The salesperson meant that the battery would last for years before it will no longer take a charge and need to be replaced.
Apr 06, 2009 | Sony NWZ-E438F Digital Media Player
Why won't the key turn in the ignition battery replaced last week
it might need reprogramming depends how long u took to replace the battery.
Jan 04, 2009 | 2002 Mercedes-Benz C-Class
Smoke fume from canon sd400
You should send the camera with the battery for service to find out if there is a defect on any internal circuit boards, or if the fault is actually the battery. There is no reliable way for you to determine this yourself, unless you have the proper setup and training to service these cameras.
Jerry G.
Dec 28, 2008 | Canon PowerShot SD400 / IXUS 50 Digital...
Dell inspiron 6400 system responding very slow on ac adaptor
FIRST REPLACE YOUR BATTERY, THEN ALSO CHECK VIRUS WITH AN UPDATED VIRUS CLEANER.
Nov 20, 2008 | Dell Inspiron 6400 Notebook
La Crosse LaCrosse Atomic Digital Wall Clock with Wireless Temperature Sensor Logo
47 people viewed this question
Top La Crosse Measuring Tools & Sensors Experts
john milligan
Oloyede Monsuru
Are you a La Crosse Measuring Tool and Sensor Expert? Answer questions, earn points and help others
